mesa 7i96 connection refused
19 Apr 2021 16:52 #206420
by Aaron3309
Replied by Aaron3309 on topic mesa 7i96 connection refused
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
auto enp3s0
iface enp3s0 inet static
address 10.10.10.100/24
auto lo
auto enp3s0
19 Apr 2021 17:33 - 19 Apr 2021 17:41 #206426
Replied by PCW on topic mesa 7i96 connection refused
Are you editing the correct file?
The file would be
and you need to use sudo when launching the editor
sudo gedit /etc/network/interfaces
(substitute your own text editor for gedit if you dont have gedit)
You can also check for syntax errors in the interface file with:
sudo ifup --no-act enp3s0
The file would be
Last edit: 19 Apr 2021 17:41 by PCW.
19 Apr 2021 17:39 #206427
by Aaron3309
i typed in sudo nano /etc/network/interfaces and the file said only
auto lo
under which i added the text you provided, i wrote to the file closed and came back to make sure it was there. I dont know why it only had the loopback when i first went in, all the examples i have seen online have all the network connections that are shown under ip a in the file but mine does not.
auto lo
19 Apr 2021 17:42 #206428
what does
return?
return?
19 Apr 2021 17:43 #206430
by bevins
Your network connections that the gui sets are here: /etc/NetworkManager/system-connections it will have a file for your wired connections. post the contents of that file here.
Replied by bevins on topic mesa 7i96 connection refused
auto lo
19 Apr 2021 18:00 #206435
by Aaron3309
sudo ifup --no-acr enp3s0 returns ifup: interface enp3s0 already configured
/etc/NetworkManager/system-connections returns no such file or directory exists
19 Apr 2021 18:11 #206438
So if you do (with the 7i96 connected)
sudo ifdown -a
sudo ifup -a
ip a
What do you get?
sudo ifdown -a
sudo ifup -a
ip a
What do you get?
19 Apr 2021 18:15 #206439
by bevins
Yeah sorry, thats was for linux mint. Your using debian I just read.
19 Apr 2021 18:24 #206443
by Aaron3309
When i did that the ip address seemed to change:
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f0:4d:a2:fe:86:3e brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/24 brd 10.10.10.255 scope global enp3s0
valid_lft forever preferred_lft forever
inet6 fe80::f24d:a2ff:fefe:863e/64 scope link
Then when i tried to open my machine it said resource temporarily unavailable (-11) and now ip a returns the 10.10.10.10/8 ip again
19 Apr 2021 18:25 #206444
by Aaron3309
the ip address only reverted after cycling the power on my mesa card
Time to create page: 0.174 seconds
