mesa 7i96 connection refused
20 Apr 2021 02:30 #206494
by Aaron3309
Replied by Aaron3309 on topic mesa 7i96 connection refused
So i tried removing wcid and using netmanager and similar results. I managed to find the flash drive with the EXACT same linux debian wheezy iso that worked on my previous computer, i put it on the new pc, i used a backup of my machine configuration that is EXACTLY the same that worked on my previous computer and i get and error that resource is not available. with this new installation i no longer have the ip address issues but i cannot ping the card in the 192.168.1.121 setting or the 10.10.10.10 it says no response . is it possible that the ethernet on my mesa 7i96 is not working if its that i will gladly buy another card and be done with all this.
- BeagleBrainz
- User is blocked
- Thank you received: 570
20 Apr 2021 12:01 #206520
by BeagleBrainz
Replied by BeagleBrainz on topic mesa 7i96 connection refused
Have you checked your cable ?
- Thank you received: 5983
20 Apr 2021 12:28 #206524
Also editing the interfaces file and using the network manager/wicd to edit the network stuff always ends in non functional networking. Choose one and edit, never both.
Replied by tommylight on topic mesa 7i96 connection refused
+1Have you checked your cable ?
20 Apr 2021 12:37 #206528
by Aaron3309
Yeah the first thing I tried when I started having trouble was a brand new cable and I’ve tried 3 others, no change.
20 Apr 2021 13:18 - 20 Apr 2021 13:19 #206531
by bevins
Replied by bevins on topic mesa 7i96 connection refused
Try connecting to your office network and get that running. That will decipher if it is hardware or not.
Try getting dhcp from your router working on it.
Last edit: 20 Apr 2021 13:19 by bevins.
20 Apr 2021 14:30 #206532
by Aaron3309
So i have wifi disabled on the computer so it does not interfere, i hooked the ethernet port directly to my router and i can open the internet, i am sending this message from the pc but when i click on network manager in the top corner it says no valid connections even though i clearly am connected
20 Apr 2021 14:53 #206535
Replied by PCW on topic mesa 7i96 connection refused
Its possible the 7I96 is bad though its unusual to have a good link (ip a says "UP")
and no communication.
If the card is less that 2 years old its under warranty so can be repaired/replaced
Time to create page: 0.205 seconds
