automatic initialization of the axis interface in full screen
- Thayloreing
17 Mar 2024 12:27 #296125
by Thayloreing
Good morning, I am assembling an industrial machine. I made Linuxcnc start at system startup, but the axis interface only opens in a corner of the screen and I have to press it every time to occupy the entire screen, I was wondering if you could help me with this, I want Linuxcnc to open taking up the entire screen when I start the system
- Thank you received: 5972
17 Mar 2024 13:21 #296135
Replied by tommylight on topic automatic initialization of the axis interface in full screen
When you made the config, wizards have a setting to choose from what size the screen should be or to fully maximize it.
Use the wizard to edit the config and select maximize, but only if you did not hand edit the configuration files.
For Axis GUI, the is a hidden file in the home folder named .axisrc or similar that you can edit to do that.
There are probably other ways, but i do not know them.
The following user(s) said Thank You: Thayloreing
