- General
- General LinuxCNC Questions
- 2 Parallel Ports - 1 Intenal, 1 PCI Parallel Port Card not configuring
- Thank you received: 5934
25 Mar 2024 18:00 #296753
Replied by tommylight on topic 2 Parallel Ports - 1 Intenal, 1 PCI Parallel Port Card not configuring
The add on card is being listed by lspci, in both cases, but the OP keeps failing to use
sudo lspci -v
As that gives info for stuff that normally shows with access denied or does not show at all.
Without that, i can not say with greater certainty what is wrong, but so far having the card listed by lspci and no driver loaded usually means dirty slot/card contacts or malfunctioning card.
First, do what Todd suggested, in that order. Might need to reboot the PC if the first fails to work and the second try reports "recourse busy".
sudo lspci -v
25 Mar 2024 20:58 #296771
by cornholio
Replied by cornholio on topic 2 Parallel Ports - 1 Intenal, 1 PCI Parallel Port Card not configuring
From what I see is that there’s no driver being loaded, this may or may not be a problem. It may be a problem if the card requires a driver to setup any registers in the chip.
But the easiest course maybe to try another card.
The following user(s) said Thank You: moazzam
25 Mar 2024 22:20 #296775
by moazzam
Replied by moazzam on topic 2 Parallel Ports - 1 Intenal, 1 PCI Parallel Port Card not configuring
No ... The card is PCI not PCIe. I will try as you said. I have checked the IC on the card it is a CH351G based card with "A351SSP1@1306" inscribed ( possibly as model of the card). I visited the manufacturer page "www.wch-ic.com/downloads" and found a linux driver in CH35XDRV.ZIP file with following instructions:
1. open "Terminal"
2. cd "driver" directory
3. compile the driver using "make", you will see the module "wch.ko" if successful
4. "insmod wch.ko" to load the driver dynamically
5. "make install" to make the driver work permanently
However upon inspection of the .c and .h files in the DRV_1PA , DRV_1PB directories only mention with CH351 was 2S (meaning 2 Serial Ports Card). Whereas the Card I have is 1P (Only 1 Parallel port no serial port). I will compile and follow these instructions also while booting into Live version of LinuxCNC and see how it goes. May be I am missing something.
1. open "Terminal"
25 Mar 2024 23:25 - 25 Mar 2024 23:45 #296782
by cornholio
I wouldn’t bother with vendor supplied drivers.
They are really only for some of the manufacturer’s specific features of the chipset relating to the serial port.
From memory this card should be supported by parport_serial. The fact that there doesn’t seem to be a driver loaded is curious. I was wrong on this account whilst 1C00 does show up there is no entry for 1c00:2170, 1c00:3050 & 1c00:3250 are.
before we go too far have you established that the latency is adequate for software step generation ?
Have you tried the Parallel Port tester utility ? There are quite a few references to it in other threads dealing with Parallel Port issues. This topic usually comes up a few times a month. There’s a wealth of information on the forum but it seems the search function isn’t used.
What is still curious is that you haven’t supplied any error messages given by linuxcnc when starting a basic config. I’m pretty sure there is a supplied config for using a Parallel Port when running linuxcnc from the menu.
This maybe a solution, whilst the chipset is not the same it may just work.
www.linuxquestions.org/questions/linux-h...5657555/#post6018828
Last edit: 25 Mar 2024 23:45 by cornholio.
26 Mar 2024 19:11 #296827
by moazzam
Tried both commands and got the following:
halcmd: loadrt hal_parport cfg="0xd000 out 0x378 out"
Waiting for component 'hal_parport' to become ready....Waited 3 seconds for master. giving up.
.Note: Using POSIX realtime
config string '0xd000 out 0x378 out'
No parport registered at 0xd000. This is not always an error. Continuing.
halcmd: loadrt hal_parport cfg="0xd010 out 0x378 out"
hal_parport: already exists
<stdin>:2: waitpid failed /usr/bin/rtapi_app hal_parport
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hal_parport failed, returned -1
halcmd:
Now frankly I don't have a clue but my guess is 'No parport registered at 0xd000' indicates that system knows there is a parallel port at that address but is unable to load a driver for it.
halcmd:
- Thank you received: 1369
26 Mar 2024 19:44 #296829
Replied by Todd Zuercher on topic 2 Parallel Ports - 1 Intenal, 1 PCI Parallel Port Card not configuring
Like that error says, it isn't always an error for Linuxcnc and the port may still work. Were you trying this command line in a Linuxcnc configuration? Did you test to see if you were able to input and output signals via the port?
The 2nd error when you tried the 2nd address is because you did not clear out the hal system from you trying the previous parallel port test. Often this requires rebooting the computer if previous test commands crashed and did not exit properly.
A test configuration can either be a basic machine configuration, or the parallel port test tool. (You must edit the test tool's config files to set it up to use the parallel port address that you wish to test.)
27 Mar 2024 11:44 #296885
by moazzam
After checking lot of information and guidance from you guys finally I got a new card with MOSCHiP MSC9805CV and it straight away came up
mm1@mm1:~$ sudo cat /proc/ioports | grep parport
[sudo] password for mm1:
0378-037a : parport0
037b-037f : parport0
d050-d052 : parport1
d053-d057 : parport1
mm1@mm1:~$
Thankyou all for guidance...
mm1@mm1:~$
The following user(s) said Thank You: tommylight, cornholio
27 Mar 2024 11:49 #296886
Is that a PCI or PCI-E card?
Any link to it?
There are often members here asking for something that works and i usually say "anything with NetMOS or MOSChip should work" but all i have are PCI, so it would be nice to have something PCI-E that works out of the box.
Thank you.
Any link to it?
Thank you.
27 Mar 2024 11:56 - 27 Mar 2024 12:00 #296889
by moazzam
Its a PCI .... I bought it for Rs 400 that is like 1.1USD from a used item store.
I will check it up if they have more of them I will buy them and any one needs it can contact me.
Last edit: 27 Mar 2024 12:00 by moazzam.
27 Mar 2024 15:26 #296905
by cornholio
I have a few PCIe cards around somewhere, don’t think the rest of the house is going be happy if I start rummaging thru all the “useful boxes” at 2:15 in the morning.
It can be such a mixed bag as well, a vendor might show a picture with one chip and then send a card with a different one.
It still can be a little plug and pray.
As the OP discovered it can be frustrating. No doubt in another couple of weeks this topic will come up and we’ll just be repeating the same stuff.
I’ve often thought of having an eBay store just to sell known working Parallel Port cards, but shipping from Down Under would be horrible and I lack certain skills when dealing with people.
Could be an idea for someone based in Europe, the UK or Canada to take on.
- General
Time to create page: 0.158 seconds
