Probe Question
- gardenweazel
- Thank you received: 5
06 Apr 2024 22:16 #297716
by gardenweazel
Probe Question was created by gardenweazel
Folks,
Is there an easy tool touch/setter GUI for AXIS that is simple to set up and doesn't require troubleshooting for ages to get it running?
Something preferably something that has written setup instructions.
Thanks in advance
Thanks in advance
08 Apr 2024 13:57 #297812
Replied by andypugh on topic Probe Question
To be honest, I can't guarantee that you won't be troubleshooting for ages.
But you could try
github.com/verser-git/probe_screen_v2.8
If you follow the instructions in the readme there carefully, and step by step, it ought to work.
But you could try
The following user(s) said Thank You: gardenweazel
08 Apr 2024 14:17 #297814
Replied by rodw on topic Probe Question
its not axis but qtdragon has probing built in and is very well documented
- gardenweazel
17 Apr 2024 18:10 #298477
by gardenweazel
Replied by gardenweazel on topic Probe Question
Thanks Gents for the feedback.
I've already tried ProbeScreen. Thanks but no thanks on that one.
I'll give QTDragon a try.
17 Apr 2024 18:35 #298480
by Mecanix
Yes. There is. And it just won't get any better than that one.
github.com/hausen8/EasyProbe/tree/v1.3
Replied by Mecanix on topic Probe Question
The following user(s) said Thank You: tommylight, gardenweazel
- gardenweazel
17 Apr 2024 20:49 #298491
by gardenweazel
So, question on this Easy Probe.
I have one of these: Edge Finders
And I have one of these: Tool Setters
Will either of these work with Easy Probe?
17 Apr 2024 21:04 #298493
by Mecanix
Got influenced by the thread title more than the content, fast reader my bad. Was sure you had a probe and was looking for easy subs that fits in AXIS in a 5min set-up time.
In that case you simply need a custom touch subroutine/call imho. More or less 10~15 lines of code in its most simplistic mean. No need for fancy gui buttons & calibration...
I swear I've seen countless "touch" subs on this forum. Shares from several members. Pick your poison!
- gardenweazel
17 Apr 2024 21:30 #298498
by gardenweazel
No problem, undo is a quick as setup!
Thanks for your feedback!
Time to create page: 0.207 seconds
