reading pwm signal input parallel port
- Thayloreing
22 Apr 2024 11:34 #298834
by Thayloreing
reading pwm signal input parallel port was created by Thayloreing
Good morning, do you know how I can read a pwm entry in linuxcnc? I have a bit input that will work with a variable frequency, I need some component that reads this frequency and transforms it to floating point, I didn't find anything like that in the manual, does anyone have an idea?
- Thank you received: 5944
22 Apr 2024 12:00 #298835
Replied by tommylight on topic reading pwm signal input parallel port
PWM probably not, frequency yes for sure, use encoder
linuxcnc.org/docs/2.9/html/man/man9/encoder.9.html
The following user(s) said Thank You: Thayloreing
Time to create page: 0.078 seconds
