punching machine
03 Jan 2011 12:23 #6404
by anpe
Replied by anpe on topic Re:punching machine
Hi, andypugh
I like way number 3 (Do you want the G-code program to know (then see the M66 command))
I've linked pin12 with digital-in-00
Is it possible to show value of variable #5399 by (MSG, ...)?
03 Jan 2011 12:28 #6406
by BigJohnT
Replied by BigJohnT on topic Re:punching machine
14 Jan 2011 13:45 #6683
by anpe
Hi All
Another question.
My machine has jumping guideners and they change position depends on X coord. I can solve this problem using G-code but I'd like to use HAL.
Guideners have two positions (up and down).
I tested in HAL CONFIGURATION and noticed that Xpos-cmd keeps wrong value. I need absolute coordinate after homing.
Thanx
Another question.
Thanx
14 Jan 2011 17:00 #6685
Replied by andypugh on topic Re:punching machine
What is XPos-cmd linked to? Signal names are unique to your setup.
I thought that the motor positions were in absolute coordinates.
Can you be a bit more clear about what you are trying to do, and how you hope to do it?
14 Jan 2011 17:31 #6686
by anpe
I used example from integrator manual. I dont need accuracy with X coordinate, but while homing coord. value become negative and doesnt correspond to real value. Maybe it's because i use HAL CONFIGURATION.
I try to link specified x-coordinate value with parport.0.pin-05-out.
Sorry,
I cannot explain better
Sorry,
15 Jan 2011 00:18 #6693
When you say "absolute position" do you really mean "relative position"?
Do you want to toggle a pin when the X coordinate passes through a certain value?
15 Jan 2011 09:41 #6703
by anpe
Yes, I need to toggle signal on pin-05 when phisical distance between current axe x position and home switch more then certain value.
I've fount that halui.axis.0.pos-commanded is right for my purpose. Am I right?
Using comp9 is enough?
15 Jan 2011 14:50 #6706
Look at wcomp. (sorry,on iPhone)
17 Jan 2011 06:48 #6738
by anpe
Thanks andypugh
It works.
My code:
setp timedelay.0.on-delay 10.0
setp timedelay.0.off-delay 10.0
net x-cur <= halui.axis.0.pos-commanded
setp wcomp.0.min 500.0
setp wcomp.0.max 6000.0
net x-cur => wcomp.0.in
net pneu wcomp.0.out => halui.program.pause timedelay.0.in
#net pneu wcomp.0.under => halui.program.pause timedelay.0.in
net delay timedelay.0.out => halui.program.resume
When I uncomment commented string, emc says : halui.program.pause was already linked
My aim is: When x-cur > 500 mm program is paused, delayed for 10 sec parport.0.pin-05-out toggled to 1, then program resumed.
When x-cur < 500 mm program is paused, delayed for 10 sec parport.0.pin-05-out toggled to 0 then resumed
It works.
My code:
17 Jan 2011 12:06 #6739
by BigJohnT
As you have found out you can only link a pin once.
Here is a pretty good explanation on how the net command works.
www.linuxcnc.org/docview/html/hal_basic_hal.html#r1_1_4
