Simulating a machine for testing?
08 Feb 2011 16:49 #7080
by greeder88
Replied by greeder88 on topic Re:Simulating a machine for testing?
I have comp but it looks like a program you feed a file into and get another file out .
08 Feb 2011 18:10 #7081
by BigJohnT
Replied by BigJohnT on topic Re:Simulating a machine for testing?
Yep, that's what comp does. You type up a simple file and comp creates the component and makes it available for you to use in your program.
Next you need to get the names of the pins that your pluto card makes so you can simulate them.
Run your config (on a machine with a pluto card) from the terminal window. After it starts type:
show pin *pluto*
copy all the pin names to a text file. I assume the pins have pluto or something similar...
Now follow the constant example here www.linuxcnc.org/docview/html/hal_comp.html#r1_14_1 and try and create your pluto comp file. Adding your pluto pins with proper direction and type where you see the pins. I would just add one in and one out pin to start to make sure you have everything else correct and make sure it compiles.
Then compile the .comp file following this:
www.linuxcnc.org/docview/html/hal_comp.h...-realtime-components
So in a nutshell you create a pluto.comp file that makes the proper pluto pins available so your configuration will run without errors and compile it then change a couple of lines in your .hal file so the pluto component loads instead of the pluto card.
See how far you get with this.
show pin *pluto*
10 Feb 2011 07:35 #7103
Replied by andypugh on topic Re:Simulating a machine for testing?
As an alternative, why not use the actual CNC machine, but with the drives disabled?
You can use VNC or ssh -X to show the garage-machine gui on your indoor machine.
10 Feb 2011 12:42 #7111
by BigJohnT
That's why you get paid the big bucks Andy!
Always thinking outside of the box.
Time to create page: 0.430 seconds
