Jog speed is very slow
11 Mar 2016 17:45 #71440
by Clive S
Jog speed is very slow was created by Clive S
I have set up my mill with Pncconf with a 7i76 the mill responds correctly with the (test the axis screen) but when in axis the jog speed is very slow 60mm/min. I have tried changing max_vel in the ini file to 4000 but the jog rate is still the same.
What am I missing I have changed my setup from a pp to a mesa 5i25 and have not used PnCConf before as I used stepconfig.
where do I change the parameters to correct this. Also I take it that I can delete all the pid tuning stuff out of the ini.
config attached
config attached
12 Mar 2016 03:54 - 12 Mar 2016 03:54 #71480
Replied by cmorley on topic Jog speed is very slow
in the {DISPLAY] section of the INI try editing to something higher.
MAX_LINEAR_VELOCITY = 1.000000
1 represents 60mm/m
PID settings are required. PNCconf sets up PID driven step generators...It gets better performance.
Also Peter recommends seting the PID P term to 1000 ( well actually P = 1 / (servo_thread) )
Chris M
1 represents 60mm/m
Chris M
Last edit: 12 Mar 2016 03:54 by cmorley.
12 Mar 2016 04:14 #71481
would 1500 mm/m for max jog velocity and
380 mm/m for default jog velocity
Be reasonable metric defaults?
Chris M
Chris M
12 Mar 2016 05:01 #71482
well I pushed fixes to pncconf to set more reasonable defaults for metric and angular jogs.
will be included in 2.7.5
Chris M
Chris M
The following user(s) said Thank You: Amedee
12 Mar 2016 08:07 - 12 Mar 2016 08:26 #71486
by Clive S
I also notice that MAX_LINEAR_VELOCITY is also in the [TRAJ] section at 66.67 yet in the Display section it is 1.000 so which is the correct place to change the number. What am I not understanding
You mention PID does that mean I cannot take out all the PID stuff in the ini file?
Clive
Replied by Clive S on topic Jog speed is very slow
Chris Thanks for the info. What is the relationship between MAX_LINEAR_VELOCITY (in display) and MAX_VELOCITY (in axis section) I did try altering the MAX_VELOCITY to 4000 but that made no difference.in the {DISPLAY] section of the INI try editing to something higher.
1 represents 60mm/m
Chris M
Clive
Last edit: 12 Mar 2016 08:26 by Clive S.
12 Mar 2016 08:59 #71489
[DISPLAY]
is the one to change.
don't remove the PID stuff.
Chris M
Chris M
12 Mar 2016 09:57 #71491
by Clive S
Ok Chris that works thanks. The stepper make a ticking noise at the end of a movement and the dro moves very slowly after the motors appear to have stopped. ie it appears to be finding it exact position. Is this another PID setting So what is the parameter to change?[DISPLAY]
Chris M
12 Mar 2016 15:04 #71495
Replied by PCW on topic Jog speed is very slow
Settting all the P terms to 1000 in the INI file should fix this
12 Mar 2016 19:29 #71497
by Clive S
Thanks Peter. Is there any reason for me not to use steconfig instead of pncconf as I am using steppers on a small mill.
12 Mar 2016 19:34 #71499
stepconf does not support Mesa cards so it won't work for you.
Chris M
Chris M
