axis window size
- Thank you received: 5928
27 Nov 2016 17:47 #83371
Replied by tommylight on topic axis window size
Have you tried one of these options?
forum.linuxcnc.org/21-axis/29735-axis-modifications
The following user(s) said Thank You: Tchefter
27 Nov 2016 19:30 #83381
by gmouer
That worked ! I ended up setting it at 1650x1000 in the .axisrc file. I had problems for a while with .axisrc, it wouldn't let me create that file, it already existed but I couldn't find it. Apparently its a hidden file. I used the locate command and it found it but it did not show in file manager. I ended up doing a sudo mousepad and that opened the hidden file which I modified and saved to get the job done. Those instuctions should be updated to reflect that .axisrc is a hidden file so newcomers to linux like me don't run into problems.
George
Replied by gmouer on topic axis window size
George
27 Nov 2016 19:34 #83383
Anything with a " . " in front of it is hidden under linux, so pressing ctrl+h in most file explorers will show them.
Glad you got it working.
Time to create page: 0.180 seconds
