Time to setup my lathe with 7i76e
30 Oct 2017 20:32 #101029
by tecno
Replied by tecno on topic Time to setup my lathe with 7i76e
Thanks,
everything goes in slow-motion here now as I've been suffering of kidney stones for a couple weeks but hopefully this will be over soon.
06 Nov 2017 11:20 #101409
by tecno
As my SSD went south I will have to do a fresh install, so what to install as I have 7i76e and 32-bit?
Lost the link I used earlier, where are these files?
06 Nov 2017 13:52 #101422
by tecno
Found the link
- Thank you received: 1370
06 Nov 2017 14:20 #101426
Replied by Todd Zuercher on topic Time to setup my lathe with 7i76e
I think I would start with one of the new experimental live iso images using Stretch. They have Preemt-RT and Linuxcnc pre-installed and are supported on Buildbot.
There are both 32 and 64-bit versions.
www.linuxcnc.org/testing-stretch-rtpreempt/
(The 2nd thing I would do is change the DE. I despise XFCE.)
06 Nov 2017 16:08 #101432
by tecno
Install via WiFi OK but...... forum.linuxcnc.org/pathpilot/33493-relia...wifi?start=50#101431
06 Nov 2017 17:44 #101443
by calvin.d
Replied by calvin.d on topic Time to setup my lathe with 7i76e
can someone either explain or point me to instructions for changing out the desktop environment ? This is for the new stretch ISO's
sorry to hijack the thread
C
C
06 Nov 2017 17:58 #101445
Which DE do you want to use?
I usually just use Synaptic to install the one I want (such as Mate)
17 Nov 2017 03:35 #101915
by calvin.d
gnome is the standard that I want to get back to
when I use the new ISO it boots into XFCE
17 Nov 2017 13:20 #101928
You'll need a decent internet connection, then either use Synaptic to install Gnome, or from a command line type "sudo apt-get install gnome". That should get it installed so you can use it, but XFCE will still be set as the default DE, you'll have to chose Gnome when you log in. Then you can either just uninstall XFCE or google up instructions on how to change the default DE.
02 Dec 2017 15:06 #102598
by tecno
Time to create page: 0.289 seconds
