Mesa 7i96 and LinuxCNC 2.8 PnCConf
06 Jul 2018 11:12 #113558 by ikkuh
Wow, this gets better and better. Thanks to all who make this possible!
Question:
Using latest 2.8 pncconf and mesaflash I get this message when using autodiscovery on my 7i96:
PNCconf encountered an error.  The following information may be useful in troubleshooting:
  File "/usr/lib/pymodules/python2.7/pncconf/pages.py", line 897, in on_mesa0_discovery_clicked
    self.a.discovery_selection_update(info,0)
  File "/usr/bin/pncconf", line 2598, in discovery_selection_update
    driver, boardname, firmname, path = self.parse_discovery(info,boardnum=bdnum)
  File "/usr/bin/pncconf", line 2563, in parse_discovery
    SECFNCTN = pin_line[3]
IndexError: list index out of range
ton@Ton-CNC:~$ mesaflash --device 7i96 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: Transformer
  There are 1 of Transformer in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
14      1   IOPort       None
 2      2   IOPort       None
15      3   IOPort       None
 3      4   IOPort       None
16      5   IOPort       None
 4      6   IOPort       None
17      7   IOPort       None
 5      8   IOPort       None
 6      9   IOPort       None
 7     10   IOPort       None
 8     11   IOPort       Transformer      0        Drive           (Out)
 9     12   IOPort       Transformer      0        Ref             (Out)
10     13   IOPort       Transformer      0        Null3           (Out)
11     14   IOPort       Transformer      0        Null4           (Out)
12     15   IOPort       Transformer      0        Null5           (Out)
13     16   IOPort       Transformer      0        Null6           (Out)
IO Connections for TB1
 1     17   IOPort       StepGen          0        Step/Table1     (Out)
14     18   IOPort       StepGen          0        Dir/Table2      (Out)
 2     19   IOPort       StepGen          1        Step/Table1     (Out)
15     20   IOPort       StepGen          1        Dir/Table2      (Out)
 3     21   IOPort       StepGen          2        Step/Table1     (Out)
16     22   IOPort       StepGen          2        Dir/Table2      (Out)
 4     23   IOPort       StepGen          3        Step/Table1     (Out)
17     24   IOPort       StepGen          3        Dir/Table2      (Out)
 5     25   IOPort       StepGen          4        Step/Table1     (Out)
 6     26   IOPort       StepGen          4        Dir/Table2      (Out)
 7     27   IOPort       QCount           0        Quad-A          (In)
 8     28   IOPort       QCount           0        Quad-B          (In)
 9     29   IOPort       QCount           0        Quad-IDX        (In)
10     30   IOPort       SSerial          0        RXData1         (In)
11     31   IOPort       SSerial          0        TXData1         (Out)
12     32   IOPort       SSerial          0        TXEn1           (Out)
Segmentation fault
06 Jul 2018 23:17 #113614 by cmorley
Thanks for the print out. I was curious what problems may come up with the autodiscovery option.
I am not familiar with the 7i96 card.
Hmm whats a transformer for?
Segmentation fault is not good either - that is probably what caused the error in pncconf - I'll try to see what can be done about that.
Chris M
07 Jul 2018 02:59 - 07 Jul 2018 12:33 #113626 by PCW
You need the latest mesaflash to deal with the 7I96
you might try re-fetching the package
Heres what the current mesaflash prints with a readhmid command:
File Name: 7i96_2018-07-07.txt
File Size:5 KB
Last edit: 07 Jul 2018 12:33 by PCW. Reason: old pinout fixed
08 Jul 2018 10:36 - 08 Jul 2018 10:38 #113799 by ikkuh
Mesaflash version 3.3.0~pre (built on Jun 28 2017 04:21:23 with libpci 3.1.8)
Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB boards
(C) 2013-2015 Michael Geszkiewicz (contact: micges@wp.pl)
(C) Mesa Electronics
Try 'mesaflash --help' for more information
strange, should be the latest........
ton@Ton-CNC:~$ which mesaflash
/usr/bin/mesaflash
ton@Ton-CNC:~$ sudo updatedb
[sudo] password for ton:
ton@Ton-CNC:~$ locate mesaflash
/usr/bin/mesaflash
/usr/share/doc/mesaflash
/usr/share/doc/mesaflash/changelog.Debian.gz
/usr/share/doc/mesaflash/copyright
/var/cache/apt/archives/mesaflash_3.3.0~pre0+dfsg-0_i386.deb
/var/lib/dpkg/info/mesaflash.list
/var/lib/dpkg/info/mesaflash.md5sums
Last edit: 08 Jul 2018 10:38 by ikkuh.
08 Jul 2018 12:44 #113802 by PCW
Yeah, that's about a year behind the latest mesaflash changes (in 3.3)
have you tried:
sudo apt-get update && sudo apt-get install mesaflash
The following user(s) said Thank You: ikkuh
08 Jul 2018 13:46 #113806 by ikkuh
have you tried:
Get:3 http://buildbot.linuxcnc.org wheezy Release.gpg [490 B]
Hit http://security.debian.org wheezy/updates/main Translation-en
Hit http://security.debian.org wheezy/updates/non-free Translation-en
Hit http://software.virtualmin.com virtualmin-universal Release.gpg
Get:4 http://buildbot.linuxcnc.org wheezy Release [86.7 kB]
Hit http://software.virtualmin.com virtualmin-wheezy Release
59% [Sources 25.5 MB] [Waiting for headers] [4 Release 28.4 kB/86.7 kB 33%]
Hit http://software.virtualmin.com virtualmin-wheezy/main i386 Packages
Hit http://buildbot.linuxcnc.org wheezy/master-rt Sources
Hit http://buildbot.linuxcnc.org wheezy/master-rt i386 Packages
Hit http://software.virtualmin.com virtualmin-universal/main i386 Packages
Ign http://buildbot.linuxcnc.org wheezy/master-rt Translation-en_US
Ign http://software.virtualmin.com virtualmin-wheezy/main Translation-en_US
Ign http://software.virtualmin.com virtualmin-universal/main Translation-en_US
Fetched 141 kB in 7s (19.3 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
mesaflash is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Could it be that I am not getting the latest version because the machine is still configured for
ton@Ton-CNC:/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc$ uname -a
Linux Ton-CNC 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
. So I am using the wrong architecture? (which makes sense since this is a working machine with a Chinese parallel port bob. )The new machine is ordered and should be here soon.
08 Jul 2018 14:05 #113809 by PCW
Yes, that is a RTAI kernel and RTAI verison of linuxcnc, it wont work with the 7I96
Not sure if the mesaflash package is synced with linuxcnc, it may be necessary to build it from source if the latest LinuxCNC master does not reference the current version
09 Jul 2018 21:52 #113897 by cmorley
File Size:5 KB
Thanks for the pinout Peter.
What is the ac ref pin for?
Chris M
09 Jul 2018 22:07 #113899 by PCW
Its part of the transformer coupled SSR hardware, nothing that hal need touch
09 Jul 2018 22:12 #113900 by cmorley
oh great.
The SSR are just outputs as far as HAL is concerned?
Are the HAL pin names different from GPIO pin names?
Chris M
Time to create page: 0.094 seconds
