Mesa 7i96 and LinuxCNC 2.8 PnCConf
- Thank you received: 5988
09 Nov 2018 20:30 #120350
Replied by tommylight on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
Ya think !!!???
The following user(s) said Thank You: snugglylovemuffin
- Aldenflorio
- Thank you received: 13
31 Aug 2020 18:03 #180203
by Aldenflorio
Replied by Aldenflorio on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
I know this is an old topic but I’m having similar issues I think. All the limit switches on the inputs are lit up yellow. I used shielded wire and grounded them but now they are just brighter.
31 Aug 2020 18:11 #180205
Replied by PCW on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
The inputs LEDS would be on if you have NC limit switches
(and go off when tripped)
- Aldenflorio
31 Aug 2020 18:13 - 31 Aug 2020 18:14 #180206
by Aldenflorio
Yeah, but they are NO and are all lit. When I manually push one then the others get darker and that one gets brighter. I think it sounds like a electrical noise issue but the wires are grounded
Last edit: 31 Aug 2020 18:14 by Aldenflorio.
31 Aug 2020 20:05 #180215
what is the input common connected to?
Sounds more like a wiring error of some kind
(missing common connection?)
- Aldenflorio
31 Aug 2020 20:30 #180221
by Aldenflorio
The common is connected to the V-
31 Aug 2020 20:45 #180226
is V- connected to frame ground?
It really sounds like some kind of wiring error
- Aldenflorio
31 Aug 2020 20:47 - 31 Aug 2020 20:47 #180227
by Aldenflorio
No v- isn’t. It goes from v+ to limit switch, other wire from limit switch to input on Mesa. Then com is v-
Last edit: 31 Aug 2020 20:47 by Aldenflorio.
31 Aug 2020 20:54 #180229
My guess would be that you have a large AC (maybe HF)
voltage from V- to frame ground.
- Aldenflorio
31 Aug 2020 20:55 - 31 Aug 2020 20:56 #180230
by Aldenflorio
I’m not sure. I’m going to make a larger control box and see if that helps. Things are a bit close. But is the wiring right with what I said?
Last edit: 31 Aug 2020 20:56 by Aldenflorio.
Time to create page: 0.204 seconds
