Mesa 7i96 and LinuxCNC 2.8 PnCConf
05 Nov 2018 16:11 - 05 Nov 2018 16:13 #120002
Replied by PCW on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
Actually they are in_not, but there's no need to guess, you can read the hostmot manual page:
man hostmot2
or run a command like:
halcmd show pin | grep gpio
when have LinuxCNC running
The easiest way to verify switch operation (unless you enjoy guessing games) is to read the actual live pin states with halshow and verify that all your switches are working and the polarity is correct
man hostmot2
Last edit: 05 Nov 2018 16:13 by PCW.
The following user(s) said Thank You: tommylight, snugglylovemuffin
- Thank you received: 5979
05 Nov 2018 16:15 #120004
Replied by tommylight on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
Sorry i was not aware of the change and i know it works with - as i am using them on at least 3 installs right now.
Thanks for the heads up.
05 Nov 2018 16:27 #120006
Mesa GPIO has always used _ for in_not
- snugglylovemuffin
- Thank you received: 11
05 Nov 2018 18:02 #120016
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
Why oh why is linuxcnc so picky?
- snugglylovemuffin
05 Nov 2018 18:26 - 05 Nov 2018 18:27 #120019
I'm getting an error that says "hm2_7i96.0.gpio.034.in-not" does not exist
@PCW, what's my move here?
Last edit: 05 Nov 2018 18:27 by snugglylovemuffin.
- snugglylovemuffin
05 Nov 2018 18:29 #120020
@PCW I've changed it back to in_not and will try halshow again
05 Nov 2018 18:29 - 05 Nov 2018 18:31 #120021
Because if it was not picky/precise about pin names you could not trust its behavior.
Its easy to get pin/parameter/signal names right, just use the available tools to list the actual pin/parameter names.
For example to list all pins/parameters and functions, you can runs this command:
halcmd show all
to show just 7I96 pins/parameters you could type
halcmd show all | grep 7i96
You can also re-direct the output of these commands to a "donor" file to copypast from, so you never need to actually type pin/parameter names:
halcmd show pin | grep 7i96 > 7i96pins.txt
halcmd show all
Last edit: 05 Nov 2018 18:31 by PCW.
The following user(s) said Thank You: snugglylovemuffin
05 Nov 2018 18:48 #120024
Replied by andypugh on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
Or halcmd show all *7i86* (halcmd accepts wildcards)
05 Nov 2018 19:14 #120027
Unfortunately that does not always work, not sure why
- snugglylovemuffin
05 Nov 2018 23:49 #120057
Pulled up halshow, put pins 34-39 on "watch" and actuated the limit; no indication of anything happening. I can run 24v into TB3 1-11 to switch low right? Just asking because there doesn't seem to be much of a reason for the limits to not work.
hm2_7i96.0.gpio.034.in_not is the proper way to wire the pin to switch low in mesa, yes?
Time to create page: 0.319 seconds
