7i76E - Starting
- MarcoGaspar
04 Nov 2018 01:37 #119906
by MarcoGaspar
Replied by MarcoGaspar on topic 7i76E - Starting
Done that, and its the same...
swaped to old chinese db25 and works ok.... but on 7i76e not
Can you include you current hal/ini files?
04 Nov 2018 01:39 #119907
Replied by PCW on topic 7i76E - Starting
looks like you only changed 1 axis...
- MarcoGaspar
04 Nov 2018 01:43 #119908
by MarcoGaspar
yes i only have X axis connected to mesa
04 Nov 2018 01:59 #119909
Looks like that should work, is it possible you have the step polarity wrong?
The following user(s) said Thank You: MarcoGaspar
- MarcoGaspar
04 Nov 2018 11:56 #119927
by MarcoGaspar
All working it was a accidental driver dipswitch touch when changing the wires.
- MarcoGaspar
04 Nov 2018 12:34 #119928
by MarcoGaspar
i have longs stepper motor 23hS9430B with DM860A drivers i have some resonance noise at lower feedrate is any parameter to eliminate or reduce that?
04 Nov 2018 14:52 #119931
You can often reduce resonance issues by raising the drives microstep ratio
(and adjusting LinuxCNCs scale parameters in the ini file accordingly)
04 Nov 2018 20:30 #119937
Replied by rodw on topic 7i76E - Starting
Your drives should handle microstepping easilly with that driver. If you haven't already, you should be using some kind of reduction drive on your motor. They are fairly easy to make with a timing belt. See this thread for more info.
forum.linuxcnc.org/30-cnc-machines/31509...pinion-drive?start=0
I ended up with a 3:1 drive on my Z axis after people here told me I would have troubles with direct drive.
05 Nov 2018 15:27 #119993
That was a bug. Fixed here:
github.com/LinuxCNC/linuxcnc/commit/f203...b766df37a81b747caf48
The fix won't be in a released version quite yet, but you can hand-edit /usr/bin/pncconf, (no need to recompile)
Replied by andypugh on topic 7i76E - Starting
- Start PNCCONF and when i try to test axis i get error (IMG_20181103_212410.jpg)
Time to create page: 0.098 seconds
