Known Software Bug in PnCConf Wizard.
10 Feb 2019 08:03 - 11 Feb 2019 07:41 #126132
by Ferdl
Known Software Bug in PnCConf Wizard. was created by Ferdl
Hi all,
I'm new in this forum but I use the linuxcnc a few years. Recently I'm building a new machine and during my machine setup configuration I found an software bug in the PnCConf Wizard.
My software programming experience let me identify the problem fast.
If the linuxcnc installation is in german language, the PnCConf Wizard has a problem to calculate the right Step-Motor-Scale values. The result will always a huge number the config will not run as expected.
Here is a example from Jan, he had the same problem:
forum.linuxcnc.org/39-pncconf/33320-how-...i25-7i76-setup#99165
I changed my linux installation from german to english language and the problem is gone. The PnCConf Wizard cannot interpret the decimal dot "." and comma "," in a right way. Therefore the calculation is totally wrong.
I hope this can help some user....
Maybe someone from the developer can read this and maybe solve the problem in the next software release. In the meantime - just use the english language
good luck
Ferdl
good luck
Ferdl
Last edit: 11 Feb 2019 07:41 by Ferdl.
11 Feb 2019 00:54 #126184
Replied by cmorley on topic Known Software Bug in PnCConf Wizard.
What version of linuxcnc are you using?
Chris M
Chris M
11 Feb 2019 07:37 - 11 Feb 2019 07:57 #126190
by Ferdl
Replied by Ferdl on topic Known Software Bug in PnCConf Wizard.
I use the latest release 2.7.14
Last edit: 11 Feb 2019 07:57 by Ferdl.
Time to create page: 0.082 seconds
