Test LinuxCNC without motors and encoders connected
20 Jun 2019 18:39 #137405
Replied by andypugh on topic Test LinuxCNC without motors and encoders connected
A standard coordinate system is
X + to the right
Y + away from you
Z + up.
(or, other directions, depending on where you stand)
The WCS in Fusion is this way round, and that is what all G-code assumes.
This is all tool-movement-relative-to-work.
If the work moves (like on a knee mill, or some gantries, then this can be confusing, but if you look at the tool relative to the work it will always be the same.
X + to the right
Y + away from you
Z + up.
- Peterdeleu
20 Jun 2019 18:55 #137409
by Peterdeleu
Replied by Peterdeleu on topic Test LinuxCNC without motors and encoders connected
And what does this mean in my situation?
This is indeed the WCS in Fusion.
If I use this WCS, and I position the workpiece against the stop on the Biesse (left-rear), what will happen?
I don't have the machine running yet. I'm only make some simulations on LinuxCNC. and when I load the G-code that has been created in Fusion into in LinuxCNC, the workpiece is positioned outside the work area.
20 Jun 2019 19:08 #137412
You can place the WCS anywhere in Fusion.
And then you can place the LinuxCNC G-code origin anywhere on the bed in LinuxCNC.
It's really a non-issue.
I very often place my WCS on a hole in Fusion and then probe that hole on the machine, make that my origin, and continue the part, for example.
The LinuxCNC G-code X=0, Y=0, Z=0 can be anywhere inside (or even outside) the machine envelope. It is offset from the absolute position, but you never use that.
If I use this WCS, and I position the workpiece against the stop on the Biesse (left-rear), what will happen?.
- Peterdeleu
21 Jun 2019 10:50 #137482
by Peterdeleu
I'll tried to simulate the WCS problem, and it looks like this is indeed a non-issue.
But I have another problem (again )
During the execution of a program, the "Preview" stops showing movements at the begin of each line. Everything is "shocking".
It looks like the preview is only refreshed after an instruction is completed. The strange thing is.. when I make small movements with the mouse (left button pressed) over the preview, then the preview is ok.
Is this something that I can solve, or is this normal?
Something to do with the fact that there are no servo's and encoders are connected yet? (FERROR and MIN_FERROR = 1000)
22 Jun 2019 23:07 #137615
I am not sure what you are describing, but it does not sound normal.
The graphical preview uses OpenGL and sometimes that can be a bit funny without the right graphics drivers installed.
Is this onboard video or an add-in card?
- Peterdeleu
26 Jun 2019 10:50 #137880
by Peterdeleu
Sorry for my late respons, but I was away for a few days.
I'm using the onboard graphic card.
The motherboard is a M2NPV-VM ASUS
And it is a - NVIDIAR GeForce 6150 + nForce 430
I'll try to explain the behavior..
LinuxCNC is working normal.
The G-code instructions are scrolling like it should be.
Only when there's a G-code witch requires a long movement of the axes, the preview shows only the movement when the movement is done. I mean, when for example the X-axis needs to move 100mm, I can only see in the preview the result of the movement when the move is complete. So the preview "shocks". I should expect that the preview shows the movement while the X-axis is moving, and not only when it is completed.
But when I move the cursor above the preview (with the left mouse button pressed, so move the image in the preview box) I see the tool moving in the preview).
26 Jun 2019 11:44 #137885
This goes against some of what you might have read on the Wiki (but a lot of that is outdated). I would be tempted to try the on-board graphics and see if that works better. It will, at least, save some space and power .
- Peterdeleu
26 Jun 2019 11:46 #137886
by Peterdeleu
Maybe I was not clear (English is not my native language )
I'm using the onboard graphic. There's no the video card installed.
26 Jun 2019 11:50 #137888
You _could_ try software OpenGL. This used to be common advice a long time ago, I am not sure how relevant it still is:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
It is mine, I have no excuse at all for my lack of reading comprehension there.Maybe I was not clear (English is not my native language )
- Peterdeleu
26 Jun 2019 12:44 #137890
by Peterdeleu
I've tried to install the OpenGL (or update)
But it is not possible because it was already installed an a many more blablabla...
I've tested my OpenGL whit that OpenGL geartest.. I have 950 frames per second.. that should be sufficient I guess
Time to create page: 0.312 seconds
