How to add a new Mesa card to pncconf?
02 Sep 2019 03:26 #143854 by phillc54
A while back I had problems with a config from Johns 7i96 config tool.
It loaded the driver like:
loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](IPADDRESS) config="num_encoders=[HOSTMOT2](ENCODERS)num_stepgens=[HOSTMOT2](STEPGENS)"sserial_port_0=[HOSTMOT2]
TWOPASS didn't like it so the PlasmaC Configurator changes it to:
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_stepgens=4 sserial_port_0=1"
I was thinking that I may have to do the same...
02 Sep 2019 03:31 #143855 by cmorley
naw that's pretty carazy to try to read.
pncconf would looks like this
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=8 num_pwmgens=8 num_stepgens=4"
setp    [HMOT]CARD0.pwmgen.pwm_frequency 20000
setp    [HMOT]CARD0.pwmgen.pdm_frequency 6000000
setp    [HMOT]CARD0.watchdog.timeout_ns 5000000
02 Sep 2019 03:32 #143856 by phillc54
Cool, no work for me. :)
02 Sep 2019 03:51 #143857 by rodw
Personally I would really dislike using joint names for everything. When I look at the HAL code I want to first know what axis I am looking at then which motor (x or x2) on that axis.
But if someone wanted to code a more joint-centric pncconf I would consider their proposal.
Chris
But with V 2.8/9 you will know what joint is attached for each axis as you have to allocate them.
I've got no history before V 2.8 so I've seen it with new eyes. But I've never used pncconf other than for that one test for you. I hand coded everything becasue the 7i76e was not well supported and back then I would have needed to create a XYZA and and edit.
It was frustrating back then becasue the support for everything I needed to do was still unfolding. Now it would be a piece of cake by comparison...
Oops and Chris sorry for calling you Cam, I knew a Cam Morley once....
02 Sep 2019 04:07 #143865 by cmorley
Well first I could reverse that argument for you as well - you allocated the Axis so you know what the joints are.
By having axes names in the HAL file I don't need to reference the INI file to know what parts are what.
If everything said joints I would need to reference the INI to see what part of the machine we are talking of.
Keep in mind we can also be just looking at someones HAL file online - we don't always have the machine handy.
It's probably just how I think ...
Since I don't use joints in my personal machines (lathe and regular xyz mill) I don't even think in joints I think axes.
In fact it drives me nuts that I get error messages that mention joints and axes. :)
Anyways AFAICT it's a huge change that I'm not interested in tackling - heck I was very close to pulling pncconf from master...
If someone put in a reasonably equivalent config program in linuxcnc I would pull it for sure.
Or better yet someone interested in continuing pncconf's development.
Chris
Ps I'm sure Cam is a nice guy too :)
02 Sep 2019 04:11 #143867 by phillc54
The never ending problem for developers, rocks and hard places...;)
02 Sep 2019 04:18 #143868 by rodw
I do know the feeling when I get a Joint n is on limit or something, but I count it down!
He had to be as he was an Aussie! Anyway, I renamed you while I was thinking of this!
I think it would be a shame to see pncconf pulled and I know you have not enjoyed maintaining it. I did look at the source code once when you said you had had enough but I just don't know Python well enough and lets face it 5000 lines or so in one file is not really the easiest code to maintain.. Gmocappy is similar.
02 Sep 2019 04:21 #143870 by rodw
Yeh, I try not to write code these days and leave it for people like you and Chris but I do know that if I ever took a shortcut, it would come back to bite me!. Mostly with database design when you had a little lookup table and you never took the time to add a unique key field. Eventually I redid them all.
02 Sep 2019 04:28 #143873 by phillc54
The only thing that annoys me about developing is that no matter how you phrase you documentation or how much documentation you have, not everyone seems to understand it.
02 Sep 2019 04:36 #143875 by cmorley
Not to whine too much ... The linuxcnc project is not like an organized business - things just happen or don't you never know. Pncconf is one of those apps that always sits at the cutting edge of what is new in the project - usually things not documented or mentioned right away. Put that together with devs don't use it (I wish they would try it once in a while) so the little critical bugs aren't usually found until it's released... crazy stuff like PID; if you connect a signal to one specific pin that isn't driven -it is bad- it must be driven or no signal connected. Peter of Mesa figured that one out and let me know.
But that was in a already released version. It just sucks that the program that is supposed to help new users can actually lead them down the wrong path with little bugs until (usually) a year after release of a new version of linuxcnc.
And ya the code is ugly and big. and only one guy knows much about it and he is much more interested in qtvcp ....
Whine off... :)
Chris
Time to create page: 0.101 seconds
