How to add a new Mesa card to pncconf?
30 Oct 2019 07:12 #149119
Replied by cmorley on topic How to add a new Mesa card to pncconf?
And what version of linuxcnc are you using?
30 Oct 2019 07:25 - 30 Oct 2019 07:27 #149125
by terry1992
Replied by terry1992 on topic How to add a new Mesa card to pncconf?
Yes, I use the 7i90HD card in EPP mode.
And I connect it to the only parallel port of my computer.
The linuxcnc version is 2.7.14.
Last edit: 30 Oct 2019 07:27 by terry1992.
30 Oct 2019 07:32 #149128
Ok do you know what firmware was uploaded to the card?
You can use mesaflash to find out if you don't know
30 Oct 2019 07:35 #149131
by terry1992
The firmware is SVST4_8.bit
I just flash it today.
30 Oct 2019 07:44 #149133
The 7i80HD card gets you the closest - It will need editing to work.
I would make a minimum config first to see what needs to be adjusted.
The following user(s) said Thank You: terry1992
30 Oct 2019 08:05 #149135
one line that will need to be changed is in the main HAL file:
it will look similar to this:
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=8 num_pwmgens=8 num_stepgens=4" l
should be something like this (change to the actual parport address)
loadrt hm2_7i90 ioaddr=0
Chris
Chris
28 Jan 2022 08:53 #233353
by BigDo
Replied by BigDo on topic How to add a new Mesa card to pncconf?
i tried the discovery mode with my 7I98 and it worked perfectly.
Very usefull.
Niko
Very usefull.
Niko
- garrettmin
21 Mar 2022 05:52 - 21 Mar 2022 17:28 #237875
by garrettmin
Replied by garrettmin on topic How to add a new Mesa card to pncconf?
I need to add the 7i88 to LinuxCNC 7i92.
7i88 isn't in the PNCConf for 7i92.
What do I need to do?
Last edit: 21 Mar 2022 17:28 by garrettmin.
Time to create page: 0.173 seconds
