Teco FM50 and Mesa 7i77
17 Apr 2020 20:53 #164328
by Catch22
Teco FM50 and Mesa 7i77 was created by Catch22
So I wired up my Teco VFD to 7i77
7i77 pin 21 ENA5- -> Inverter 3 (FWD)
7i77 pin 22 ENA5+ -> Inverter 6 (+12V)
7i77 pin 23 GND -> Inverter 10 ( 0V)
7i77 pin 24 AOUT5 -> Inverter 9 (MVI)
And I got the spindle to turn on in Linuxcnc but no reverse and I can't control the spindle speed up and down.
Any suggestions on what I'm doing wrong?
Thanks Mike
Thanks Mike
17 Apr 2020 22:03 #164338
Replied by PCW on topic Teco FM50 and Mesa 7i77
Did you measure the AOUT5 pin as you set various speeds
to verify that the scaling is correct?
The following user(s) said Thank You: Catch22
17 Apr 2020 22:11 #164339
by Catch22
Don't know how to do that.
Replied by Catch22 on topic Teco FM50 and Mesa 7i77
17 Apr 2020 22:14 #164340
1. set spindle on and speed 1/2 of full speed
2. (assuming 10V is full speed) check that you have 5V on AOUT
17 Apr 2020 23:10 - 17 Apr 2020 23:11 #164353
by Catch22
I'm not getting any volts at all.
Should there be another wire on the VFD? [attachment=25814]15871649155995057958970318230092.jpg
Last edit: 17 Apr 2020 23:11 by Catch22.
17 Apr 2020 23:47 #164357
Is red AOUT5? if so you are shorting the analog out to ground
17 Apr 2020 23:50 #164358
by Catch22
No it's black and goes to vi on the VFD.
17 Apr 2020 23:59 #164359
Was the spindle enabled?
What was the spindle speed?
When you have LinuxCNC running and the spindle
enabled and set to 1/2 speed can you post the results of
halcmd show all | grep spin
(typed in a terminal window)
18 Apr 2020 00:27 #164362
by Catch22
Ok I started up the spindle and the speed doesn't change until you hit 0% it stops.
I had to take pictures of the Hal file, my internet isn't working in the garage.
18 Apr 2020 00:50 - 18 Apr 2020 00:51 #164372
Notice that you are commanding a negative spindle speed?
This will likely not work with the TECO as it probably expects 0 to 10V
_not_ -10 to +10
So to test further, select a positive spindle speed
If the TECO VFD is 0 to 10V you will need to connect the spindle
to the absolute RPM pin in hal rather than the signed RPM pin
_not_ -10 to +10
Last edit: 18 Apr 2020 00:51 by PCW.
Time to create page: 0.242 seconds
