5v for Mesa 7i76
05 Jul 2020 10:36 #173661
by Desertboy
5v for Mesa 7i76 was created by Desertboy
Can I use the 5v from a USB on the PC?
Or should I get a dedicated 5v one in which case what amps?
I have a few 2 amp usb chargers any good?
05 Jul 2020 10:51 #173662
Replied by rodw on topic 5v for Mesa 7i76
you may not even need a 5v power supply. Can you tell us more?
The following user(s) said Thank You: Desertboy
05 Jul 2020 13:03 #173667
Replied by PCW on topic 5v for Mesa 7i76
Normally the 7I76 should be setup to get 5V power from the FPGA card
(and the FPGA card setup to supply 5V power)
05 Jul 2020 13:17 #173668
by Desertboy
Replied by Desertboy on topic 5v for Mesa 7i76
The 5v for the step
06 Jul 2020 06:35 #173710
As Peter said, the 5 volt comes from an onboard step down regulator if you set the links as per the manual.
The 5v for the step
- Thank you received: 5944
06 Jul 2020 08:13 #173727
Replied by tommylight on topic 5v for Mesa 7i76
7i76 has 5V and GND terminals for all 5 drives.The 5v for the step
06 Jul 2020 08:21 #173731
Plus I have stolen 5 volt from the Mesa for other uses. Like powering a thcad or using stepper drive enable signals.
Time to create page: 0.095 seconds
