7i76e , 2.8.0 , Raspberry , hung configuring VFD
- merlinfive
- Thank you received: 3
03 Nov 2020 22:32 #188276
by merlinfive
7i76e , 2.8.0 , Raspberry , hung configuring VFD was created by merlinfive
Hi ,
I'm new to linuxcnc and Mesa cards , I'm reading now for some hours here , found how to cable the Huanyang 2,2KW VFD but got stuck configuring in PnCConf.
I have already configured 3 axes (JMC Servos) which work fine for now , I have configured 3 limit/home switches but were can I configure the spindle ?
In PnCConf I can see three tabs with I/O but in some thread I have read about "midi tab" ? how do I get it ?
the 7i76e is out of the box , and I even tried mesaflash from github but I guess on raspberry it is not available (got a lib error during make)
all help appreciated, please point me into the right direction
03 Nov 2020 22:47 #188277
by oldtech
Replied by oldtech on topic 7i76e , 2.8.0 , Raspberry , hung configuring VFD
You have to select the spindle option early in the config. Then you will be able to add your spindle info at the end.
- merlinfive
03 Nov 2020 22:53 #188279
by merlinfive
Replied by merlinfive on topic 7i76e , 2.8.0 , Raspberry , hung configuring VFD
Yes I have selected the checkbox for Spindle , guess in one of the first pages .
just read in another thread that german language might be an issue , will change to english tomorrow and check again.
- merlinfive
04 Nov 2020 13:50 #188310
by merlinfive
Ok that was the problem , after changing to englisch I got the additional tab 7I/& I/O and sub tabs for TB4 / 5 / 6 Spindel is working
Maybe in the documentation should be pointed out to always use englisch
Time to create page: 0.087 seconds
