Mesa 5i25 + 7i77D can't cofig
23 Apr 2021 08:39 - 23 Apr 2021 08:40 #206854
by Taichi
Mesa 5i25 + 7i77D can't cofig was created by Taichi
Hi, sorry for bad English.
I try to config 5i25 and 7i77D in pnccofig.
Diod 15 will blink green and in show command i see all pins, serials and encoders
But if i done PnCConfig i get error - "Parameter or Pin not found: hm2_5i25.0.7i77.0.1.analogout0-scalemax not found "
What i did wrong? Thx
If i write in console halrun:
loadrt trivkins
loadrt motmod servo_period.....
loadrt hostmot2
loadrt hm2_pci
addf ******read servo-thread
addf ******write servo-thread
start
Last edit: 23 Apr 2021 08:40 by Taichi.
- Thank you received: 5966
23 Apr 2021 10:22 #206858
Replied by tommylight on topic Mesa 5i25 + 7i77D can't cofig
Can you please upload the hal and ini file, or the config folder here ?
23 Apr 2021 11:07 #206860
by Taichi
Replied by Taichi on topic Mesa 5i25 + 7i77D can't cofig
its created by pncconf
23 Apr 2021 14:58 #206876
Replied by PCW on topic Mesa 5i25 + 7i77D can't cofig
Can you post the result of:
halcmd -kf
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
halcmd: show all
as a text file?
halcmd -kf
halcmd: show all
as a text file?
23 Apr 2021 18:19 - 23 Apr 2021 18:19 #206882
by bevins
Replied by bevins on topic Mesa 5i25 + 7i77D can't cofig
looks like he messed something up with his pncconf config.
He's got analogout1 connecting to [JOINT_0]
I've never seen pncconf do that.
Last edit: 23 Apr 2021 18:19 by bevins.
23 Apr 2021 19:22 #206887
You can map analog outputs and encoders to any joint you wish
though I personally prefer them in joint order as it make the hal file
more readable for me.
24 Apr 2021 00:31 #206905
by bevins
Yes I know by hand editing the hal but he said he got this from pncconf.
24 Apr 2021 02:43 #206929
You can assign encoders and analog channels in any order you like in pncconf.
That is, there is nothing to stop you from assigning analog 0 and encoder 4
to the Z axis. Reading the hal file would give you a headache but its possible.
The following user(s) said Thank You: bevins
24 Apr 2021 04:16 #206934
by Taichi
I tried any variant in pncconfig.
At last i try change pins.
Axis X pwm - analogout1
Axis Y pwm - analogout0
When i use terminal everything ok.
But when i start linuxcnc i get error.
I think motmod not loading.
Maybe better reinstall Linux CNC?
24 Apr 2021 12:28 #206948
by bevins
Probably not needed. Dont think its Linuxcnc the problem. Post what PCW was asking.
Time to create page: 0.111 seconds
