new pnc.config won't load in linuxcnc
- mjones@welfab.ca
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/hard/linuxcnc/configs/SuperSlant'
Machine configuration file is 'SuperSlant.ini'
INIFILE=/home/hard/linuxcnc/configs/SuperSlant/SuperSlant.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
CANNOT FIND FILE FOR:BigGrayBeast.hal
Debug file information:
4420
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000daf0a000 (usable)
[ 0.000000] BIOS-e820: 00000000daf0a000 - 00000000db000000 (reserved)
[ 0.000000] BIOS-e820: 00000000db000000 - 00000000db74e000 (usable)
[ 0.000000] BIOS-e820: 00000000db74e000 - 00000000db800000 (reserved)
[ 0.000000] BIOS-e820: 00000000db800000 - 00000000dbfb4000 (usable)
[ 0.000000] BIOS-e820: 00000000dbfb4000 - 00000000dc000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000dc000000 - 00000000dd70e000 (usable)
[ 0.000000] BIOS-e820: 00000000dd70e000 - 00000000dd800000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000dd800000 - 00000000deee1000 (usable)
[ 0.000000] BIOS-e820: 00000000deee1000 - 00000000df0df000 (reserved)
[ 0.000000] BIOS-e820: 00000000df0df000 - 00000000df122000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df122000 - 00000000df800000 (usable)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000041e000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 7010/0773VG, BIOS A13 03/25/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xdf800 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask C00000000 write-back
[ 0.000000] 1 base 400000000 mask FF0000000 write-back
[ 0.000000] 2 base 410000000 mask FF8000000 write-back
[ 0.000000] 3 base 418000000 mask FFC000000 write-back
[ 0.000000] 4 base 41C000000 mask FFE000000 write-back
[ 0.000000] 5 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fda80] fda80
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36410000 - 37200000
[ 0.000000] ACPI: RSDP 000ee080 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT dbff4080 0007C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP dbffd7b0 0010C (v05 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT dbff4188 09625 (v02 DELL CBX3 00000022 INTL 20091112)
[ 0.000000] ACPI: FACS dd7fe080 00040
[ 0.000000] ACPI: APIC dbffd8c0 00072 (v03 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT dbffd938 00044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG dbffd980 0003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET dbffd9c0 00038 (v01 DELL CBX3 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT dbffd9f8 00415 (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT dbffde10 009B9 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT dbffe7d0 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: DMAR dbfff268 00080 (v01 INTEL SNB 00000001 INTL 00000001)
[ 0.000000] ACPI: ASF! dbfff2e8 000A5 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.000000] ACPI: SLIC dbfff390 00176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2688MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000df800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000daf0a
[ 0.000000] 0: 0x000db000 -> 0x000db74e
[ 0.000000] 0: 0x000db800 -> 0x000dbfb4
[ 0.000000] 0: 0x000dc000 -> 0x000dd70e
[ 0.000000] 0: 0x000dd800 -> 0x000deee1
[ 0.000000] 0: 0x000df122 -> 0x000df800
[ 0.000000] On node 0 totalpages: 914022
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4820200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 5377 pages used for memmap
[ 0.000000] HighMem zone: 681434 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df800000 (gap: df800000:18800000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 906869
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=9ced5b65-7026-4bca-8241-ab8a8def232c ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 7323520 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000df800)
[ 0.000000] Memory: 3599044k/3661824k available (3495k kernel code, 57044k reserved, 1237k data, 416k init, 2747244k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3392.191 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6784.38 BogoMIPS (lpj=13568764)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000027] Security Framework initialized
[ 0.000030] AppArmor: AppArmor disabled by boot time parameter
[ 0.000040] Mount-cache hash table entries: 512
[ 0.000149] Initializing cgroup subsys cpuacct
[ 0.000151] Initializing cgroup subsys memory
[ 0.000154] Initializing cgroup subsys devices
[ 0.000156] Initializing cgroup subsys freezer
[ 0.000157] Initializing cgroup subsys net_cls
[ 0.000158] Initializing cgroup subsys blkio
[ 0.000161] Initializing cgroup subsys perf_event
[ 0.000179] CPU: Physical Processor ID: 0
[ 0.000180] CPU: Processor Core ID: 0
[ 0.000183] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000183] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000705] mce: CPU supports 9 MCE banks
[ 0.000715] CPU0: Thermal monitoring enabled (TM1)
[ 0.000785] ACPI: Core revision 20120320
[ 0.005176] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.005578] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.045148] CPU0: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz stepping 09
[ 0.152581] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[ 0.152587] ... version: 3
[ 0.152588] ... bit width: 48
[ 0.152589] ... generic registers: 8
[ 0.152590] ... value mask: 0000ffffffffffff
[ 0.152591] ... max period: 000000007fffffff
[ 0.152592] ... fixed-purpose events: 3
[ 0.152593] ... event mask: 00000007000000ff
[ 0.164600] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.176530] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[ 0.176532] Booting Node 0, Processors #1
[ 0.186778] Initializing CPU#1
[ 0.190138] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196476] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.196479] #2
[ 0.206663] Initializing CPU#2
[ 0.210081] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216417] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[ 0.216420] #3 Ok.
[ 0.226604] Initializing CPU#3
[ 0.230023] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.230046] Brought up 4 CPUs
[ 0.230047] Total of 4 processors activated (27137.52 BogoMIPS).
[ 0.232204] devtmpfs: initialized
[ 0.232346] PM: Registering ACPI NVS region [mem 0xdd70e000-0xdd7fffff] (991232 bytes)
[ 0.232371] PM: Registering ACPI NVS region [mem 0xdf0df000-0xdf121fff] (274432 bytes)
[ 0.232434] dummy:
[ 0.232470] NET: Registered protocol family 16
[ 0.232544] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.232546] ACPI: bus type pci registered
[ 0.232581] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.232583] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.232584] PCI: Using MMCONFIG for extended config space
[ 0.232586] PCI: Using configuration type 1 for base access
[ 0.232593] dmi type 0xB1 record - unknown flag
[ 0.232960] bio: create slab <bio-0> at 0
[ 0.233019] ACPI: Added _OSI(Module Device)
[ 0.233020] ACPI: Added _OSI(Processor Device)
[ 0.233022] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.233023] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.234469] ACPI: EC: Look up EC in DSDT
[ 0.236006] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.239058] ACPI: SSDT df086018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239438] ACPI: Dynamic OEM Table Load:
[ 0.239440] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239669] ACPI: SSDT df087a98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240079] ACPI: Dynamic OEM Table Load:
[ 0.240081] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240189] ACPI: SSDT df08dc18 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.240565] ACPI: Dynamic OEM Table Load:
[ 0.240567] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.241063] ACPI: Interpreter enabled
[ 0.241068] ACPI: (supports S0 S3 S4 S5)
[ 0.241086] ACPI: Using IOAPIC for interrupt routing
[ 0.246639] ACPI: No dock devices found.
[ 0.246642] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.246895] \_SB_.PCI0:_OSC invalid UUID
[ 0.246896] _OSC request data:1 8 0
[ 0.246900] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.247286] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.247288] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.247289] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.247291] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.247292] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.247294] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.247295] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.247297] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.247298] pci_root PNP0A08:00: host bridge window [mem 0xe0000000-0xfeafffff]
[ 0.247320] PCI host bridge to bus 0000:00
[ 0.247321] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.247323] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.247324] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.247326] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.247327] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.247328] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.247330] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.247331] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.247333] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff]
[ 0.247340] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.247368] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.247388] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.247428] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.247450] pci 0000:00:14.0: reg 10: [mem 0xf7f20000-0xf7f2ffff 64bit]
[ 0.247505] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.247526] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.247548] pci 0000:00:16.0: reg 10: [mem 0xf7f3c000-0xf7f3c00f 64bit]
[ 0.247607] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.247631] pci 0000:00:16.3: [8086:1e3d] type 00 class 0x070002
[ 0.247648] pci 0000:00:16.3: reg 10: [io 0xf0a0-0xf0a7]
[ 0.247657] pci 0000:00:16.3: reg 14: [mem 0xf7f3a000-0xf7f3afff]
[ 0.247738] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[ 0.247754] pci 0000:00:19.0: reg 10: [mem 0xf7f00000-0xf7f1ffff]
[ 0.247762] pci 0000:00:19.0: reg 14: [mem 0xf7f39000-0xf7f39fff]
[ 0.247771] pci 0000:00:19.0: reg 18: [io 0xf040-0xf05f]
[ 0.247817] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.247841] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.247861] pci 0000:00:1a.0: reg 10: [mem 0xf7f38000-0xf7f383ff]
[ 0.247931] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.247955] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.247968] pci 0000:00:1b.0: reg 10: [mem 0xf7f30000-0xf7f33fff 64bit]
[ 0.248020] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.248045] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.248143] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.248177] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[ 0.248236] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.248266] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.248286] pci 0000:00:1d.0: reg 10: [mem 0xf7f37000-0xf7f373ff]
[ 0.248356] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.248375] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.248429] pci 0000:00:1f.0: [8086:1e47] type 00 class 0x060100
[ 0.248537] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[ 0.248555] pci 0000:00:1f.2: reg 10: [io 0xf090-0xf097]
[ 0.248562] pci 0000:00:1f.2: reg 14: [io 0xf080-0xf083]
[ 0.248569] pci 0000:00:1f.2: reg 18: [io 0xf070-0xf077]
[ 0.248577] pci 0000:00:1f.2: reg 1c: [io 0xf060-0xf063]
[ 0.248584] pci 0000:00:1f.2: reg 20: [io 0xf020-0xf03f]
[ 0.248592] pci 0000:00:1f.2: reg 24: [mem 0xf7f36000-0xf7f367ff]
[ 0.248623] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.248640] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.248654] pci 0000:00:1f.3: reg 10: [mem 0xf7f35000-0xf7f350ff 64bit]
[ 0.248674] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.248722] pci 0000:01:00.0: [1002:6778] type 00 class 0x030000
[ 0.248734] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.248744] pci 0000:01:00.0: reg 18: [mem 0xf7e20000-0xf7e3ffff 64bit]
[ 0.248751] pci 0000:01:00.0: reg 20: [io 0xe000-0xe0ff]
[ 0.248763] pci 0000:01:00.0: reg 30: [mem 0xf7e00000-0xf7e1ffff pref]
[ 0.248780] pci 0000:01:00.0: supports D1 D2
[ 0.248801] pci 0000:01:00.1: [1002:aa98] type 00 class 0x040300
[ 0.248813] pci 0000:01:00.1: reg 10: [mem 0xf7e40000-0xf7e43fff 64bit]
[ 0.248855] pci 0000:01:00.1: supports D1 D2
[ 0.257945] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.257950] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.257954] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.257960] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.258045] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.258136] pci 0000:03:00.0: [104c:8240] type 01 class 0x060400
[ 0.258278] pci 0000:03:00.0: supports D1 D2
[ 0.265927] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 0.265937] pci 0000:00:1c.4: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.266085] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.266113] pci 0000:04:00.0: reg 10: [mem 0xf7d00000-0xf7d0ffff]
[ 0.266338] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.266354] pci 0000:03:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.266434] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.266443] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.266445] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.266446] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.266448] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.266449] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.266451] pci 0000:00:1e.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.266452] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.266454] pci 0000:00:1e.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.266456] pci 0000:00:1e.0: bridge window [mem 0xe0000000-0xfeafffff] (subtractive decode)
[ 0.266475] pci_bus 0000:00: on NUMA node 0
[ 0.266478] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.266625] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.266705] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.266741] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.266776] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.266868] \_SB_.PCI0:_OSC invalid UUID
[ 0.266869] _OSC request data:1 f 0
[ 0.266872] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.271145] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.271185] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.271223] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.271260] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.271299] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.271337] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.271375] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.271412] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.271468] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.271471] vgaarb: loaded
[ 0.271472] vgaarb: bridge control possible 0000:01:00.0
[ 0.271487] PCI: Using ACPI for IRQ routing
[ 0.272901] PCI: pci_cache_line_size set to 64 bytes
[ 0.272980] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.272982] reserve RAM buffer: 00000000daf0a000 - 00000000dbffffff
[ 0.272984] reserve RAM buffer: 00000000db74e000 - 00000000dbffffff
[ 0.272985] reserve RAM buffer: 00000000dbfb4000 - 00000000dbffffff
[ 0.272987] reserve RAM buffer: 00000000dd70e000 - 00000000dfffffff
[ 0.272988] reserve RAM buffer: 00000000deee1000 - 00000000dfffffff
[ 0.272990] reserve RAM buffer: 00000000df800000 - 00000000dfffffff
[ 0.273071] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.273076] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.275088] Switching to clocksource hpet
[ 0.275129] pnp: PnP ACPI init
[ 0.275134] ACPI: bus type pnp registered
[ 0.275343] pnp 00:00: [bus 00-3e]
[ 0.275345] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.275347] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.275348] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.275349] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.275351] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.275352] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.275354] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.275356] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.275357] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.275359] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.275360] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.275361] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.275363] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.275364] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.275366] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.275367] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.275368] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.275370] pnp 00:00: [mem 0xe0000000-0xfeafffff window]
[ 0.275371] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.275404] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.275420] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.275442] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.275444] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.275451] pnp 00:02: [io 0x0000-0x001f]
[ 0.275453] pnp 00:02: [io 0x0081-0x0091]
[ 0.275454] pnp 00:02: [io 0x0093-0x009f]
[ 0.275455] pnp 00:02: [io 0x00c0-0x00df]
[ 0.275457] pnp 00:02: [dma 4]
[ 0.275468] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.275474] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.275487] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.275538] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.275551] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.275559] pnp 00:05: [io 0x002e-0x002f]
[ 0.275561] pnp 00:05: [io 0x004e-0x004f]
[ 0.275562] pnp 00:05: [io 0x0061]
[ 0.275563] pnp 00:05: [io 0x0063]
[ 0.275564] pnp 00:05: [io 0x0065]
[ 0.275565] pnp 00:05: [io 0x0067]
[ 0.275566] pnp 00:05: [io 0x0070]
[ 0.275567] pnp 00:05: [io 0x0080]
[ 0.275569] pnp 00:05: [io 0x0092]
[ 0.275570] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.275571] pnp 00:05: [io 0x0680-0x069f]
[ 0.275572] pnp 00:05: [io 0x1000-0x100f]
[ 0.275573] pnp 00:05: [io 0xffff]
[ 0.275575] pnp 00:05: [io 0xffff]
[ 0.275576] pnp 00:05: [io 0x0400-0x0453]
[ 0.275577] pnp 00:05: [io 0x0458-0x047f]
[ 0.275578] pnp 00:05: [io 0x0500-0x057f]
[ 0.275579] pnp 00:05: [io 0x164e-0x164f]
[ 0.275604] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.275605] system 00:05: [io 0x1000-0x100f] has been reserved
[ 0.275607] system 00:05: [io 0xffff] has been reserved
[ 0.275609] system 00:05: [io 0xffff] has been reserved
[ 0.275610] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.275612] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.275613] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.275615] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.275617] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.275622] pnp 00:06: [io 0x0070-0x0077]
[ 0.275628] pnp 00:06: [irq 8]
[ 0.275642] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.275662] pnp 00:07: [io 0x0454-0x0457]
[ 0.275684] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.275685] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.275743] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.275744] pnp 00:08: [io 0x0a40-0x0a4f]
[ 0.275745] pnp 00:08: [io 0x0a00-0x0a3f]
[ 0.275767] system 00:08: [io 0x0a40-0x0a4f] has been reserved
[ 0.275769] system 00:08: [io 0x0a00-0x0a3f] has been reserved
[ 0.275771] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.275786] pnp 00:09: [io 0x0010-0x001f]
[ 0.275787] pnp 00:09: [io 0x0022-0x003f]
[ 0.275788] pnp 00:09: [io 0x0044-0x005f]
[ 0.275789] pnp 00:09: [io 0x0062-0x0063]
[ 0.275791] pnp 00:09: [io 0x0065-0x006f]
[ 0.275792] pnp 00:09: [io 0x0072-0x007f]
[ 0.275793] pnp 00:09: [io 0x0080]
[ 0.275794] pnp 00:09: [io 0x0084-0x0086]
[ 0.275795] pnp 00:09: [io 0x0088]
[ 0.275796] pnp 00:09: [io 0x008c-0x008e]
[ 0.275798] pnp 00:09: [io 0x0090-0x009f]
[ 0.275799] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.275800] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.275802] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.275827] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.275829] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.275834] pnp 00:0a: [io 0x00f0-0x00ff]
[ 0.275838] pnp 00:0a: [irq 13]
[ 0.275852] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.276669] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.276673] pnp 00:0b: [irq 4]
[ 0.276674] pnp 00:0b: [dma 0 disabled]
[ 0.276707] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.276884] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.276885] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.276886] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.276888] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.276889] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.276890] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.276892] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.276893] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.276894] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.276896] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.276897] pnp 00:0c: [mem 0xf0000000-0xf0000fff]
[ 0.276937] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.276939] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.276941] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.276942] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.276944] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.276946] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.276948] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.276949] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.276951] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.276953] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.276955] system 00:0c: [mem 0xf0000000-0xf0000fff] has been reserved
[ 0.276957] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.277058] pnp: PnP ACPI: found 13 devices
[ 0.277059] ACPI: ACPI bus type pnp unregistered
[ 0.277061] PnPBIOS: Disabled by ACPI PNP
[ 0.312828] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.312831] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.312833] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.312835] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.312839] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.312856] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.312864] pci 0000:03:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.312880] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 0.312886] pci 0000:00:1c.4: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.312893] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[ 0.312939] pci 0000:00:1e.0: setting latency timer to 64
[ 0.312943] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.312944] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.312946] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.312947] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.312949] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.312950] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.312952] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff]
[ 0.312953] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff]
[ 0.312955] pci_bus 0000:00: resource 12 [mem 0xe0000000-0xfeafffff]
[ 0.312956] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.312957] pci_bus 0000:01: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.312959] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.312961] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.312962] pci_bus 0000:04: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.312964] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7]
[ 0.312965] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff]
[ 0.312966] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.312968] pci_bus 0000:05: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.312969] pci_bus 0000:05: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.312971] pci_bus 0000:05: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.312972] pci_bus 0000:05: resource 10 [mem 0x000e0000-0x000e3fff]
[ 0.312974] pci_bus 0000:05: resource 11 [mem 0x000e4000-0x000e7fff]
[ 0.312975] pci_bus 0000:05: resource 12 [mem 0xe0000000-0xfeafffff]
[ 0.313035] NET: Registered protocol family 2
[ 0.313072] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.313179] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.313301] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.313354] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.313356] TCP: reno registered
[ 0.313357] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.313360] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.313410] NET: Registered protocol family 1
[ 0.354902] pci 0000:01:00.0: Boot video device
[ 0.354918] PCI: CLS 64 bytes, default 64
[ 0.354951] Unpacking initramfs...
[ 0.540434] Freeing initrd memory: 14272k freed
[ 0.541962] audit: initializing netlink socket (disabled)
[ 0.541970] type=2000 audit(1626805274.432:1): initialized
[ 0.550295] highmem bounce pool size: 64 pages
[ 0.550305] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.550463] VFS: Disk quotas dquot_6.5.2
[ 0.550481] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.550527] msgmni has been set to 1691
[ 0.550636] alg: No test for stdrng (krng)
[ 0.550656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.550658] io scheduler noop registered
[ 0.550659] io scheduler deadline registered
[ 0.550677] io scheduler cfq registered (default)
[ 0.550862] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.550872] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.550873] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.551186] GHES: HEST is not enabled!
[ 0.551193] isapnp: Scanning for PnP cards...
[ 0.904192] isapnp: No Plug & Play device found
[ 0.904222] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.924826] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.945643] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.965871] 0000:00:16.3: ttyS1 at I/O 0xf0a0 (irq = 19) is a 16550A
[ 0.966029] Linux agpgart interface v0.103
[ 0.966173] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.969078] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.969095] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.969168] mousedev: PS/2 mouse device common for all mice
[ 0.969198] rtc_cmos 00:06: RTC can wake from S4
[ 0.969304] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.969331] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.969405] TCP: cubic registered
[ 0.969457] NET: Registered protocol family 10
[ 0.969591] Mobile IPv6
[ 0.969593] NET: Registered protocol family 17
[ 0.969595] Registering the dns_resolver key type
[ 0.969628] Using IPI No-Shortcut mode
[ 0.969694] PM: Hibernation image not present or could not be loaded.
[ 0.969700] registered taskstats version 1
[ 0.970026] rtc_cmos 00:06: setting system clock to 2021-07-20 18:21:15 UTC (1626805275)
[ 0.970104] Freeing unused kernel memory: 416k freed
[ 0.970186] Write protecting the kernel text: 3496k
[ 0.970201] Write protecting the kernel read-only data: 984k
[ 0.976978] udevd[58]: starting version 175
[ 0.987612] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 0.987614] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 0.987648] e1000e 0000:00:19.0: setting latency timer to 64
[ 0.987702] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 0.987727] usbcore: registered new interface driver usbfs
[ 0.987739] usbcore: registered new interface driver hub
[ 0.989460] usbcore: registered new device driver usb
[ 0.989658] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.990880] SCSI subsystem initialized
[ 0.991857] libata version 3.00 loaded.
[ 0.993537] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x16
[ 1.005436] microcode: CPU0 updated to revision 0x1b, date = 2014-05-29
[ 1.005443] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x16
[ 1.006981] microcode: CPU1 updated to revision 0x1b, date = 2014-05-29
[ 1.006986] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x16
[ 1.008423] microcode: CPU2 updated to revision 0x1b, date = 2014-05-29
[ 1.008432] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x16
[ 1.009897] microcode: CPU3 updated to revision 0x1b, date = 2014-05-29
[ 1.009927] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.245158] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) b8:ca:3a:7e:98:fb
[ 1.245160] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.245195] e1000e 0000:00:19.0: eth0: MAC: 10, PHY: 11, PBA No: 1011FF-0FF
[ 1.245237] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.245241] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.245257] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.245277] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.249157] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.249171] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7f38000
[ 1.260294] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.260322] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.260325] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.260328] usb usb1: Product: EHCI Host Controller
[ 1.260340] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.260341] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.260414] hub 1-0:1.0: USB hub found
[ 1.260417] hub 1-0:1.0: 3 ports detected
[ 1.260479] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.260482] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.260487] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.260505] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.264372] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.264384] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7f37000
[ 1.276248] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.276269] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.276272] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.276275] usb usb2: Product: EHCI Host Controller
[ 1.276277] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.276280] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.276354] hub 2-0:1.0: USB hub found
[ 1.276357] hub 2-0:1.0: 3 ports detected
[ 1.276406] ahci 0000:00:1f.2: version 3.0
[ 1.276474] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
[ 1.276476] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 1.276481] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.284561] scsi0 : ahci
[ 1.284637] scsi1 : ahci
[ 1.284682] scsi2 : ahci
[ 1.284727] scsi3 : ahci
[ 1.284773] scsi4 : ahci
[ 1.284817] scsi5 : ahci
[ 1.285092] ata1: SATA max UDMA/133 abar m2048@0xf7f36000 port 0xf7f36100 irq 19
[ 1.285095] ata2: SATA max UDMA/133 abar m2048@0xf7f36000 port 0xf7f36180 irq 19
[ 1.285096] ata3: DUMMY
[ 1.285097] ata4: DUMMY
[ 1.285098] ata5: DUMMY
[ 1.285099] ata6: DUMMY
[ 1.285140] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.285144] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.285151] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.285245] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.285274] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.285275] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.285277] usb usb3: Product: xHCI Host Controller
[ 1.285278] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.285279] usb usb3: SerialNumber: 0000:00:14.0
[ 1.285343] xHCI xhci_add_endpoint called for root hub
[ 1.285345] xHCI xhci_check_bandwidth called for root hub
[ 1.285363] hub 3-0:1.0: USB hub found
[ 1.285370] hub 3-0:1.0: 4 ports detected
[ 1.285420] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.285423] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.285438] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.285440] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.285441] usb usb4: Product: xHCI Host Controller
[ 1.285442] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.285444] usb usb4: SerialNumber: 0000:00:14.0
[ 1.285489] xHCI xhci_add_endpoint called for root hub
[ 1.285491] xHCI xhci_check_bandwidth called for root hub
[ 1.285506] hub 4-0:1.0: USB hub found
[ 1.285512] hub 4-0:1.0: 4 ports detected
[ 1.535504] Refined TSC clocksource calibration: 3392.292 MHz.
[ 1.535510] Switching to clocksource tsc
[ 1.571397] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.603308] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.603330] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.603991] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.603996] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.604000] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.604064] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.604290] ata1.00: ATA-8: SAMSUNG SSD PM830 2.5" 7mm 128GB, CXM03D1Q, max UDMA/133
[ 1.604293] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.604722] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.604727] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.604731] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.604797] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.605022] ata1.00: configured for UDMA/133
[ 1.607503] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.607507] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.607511] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.607655] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.609512] ata2.00: ATAPI: HL-DT-ST DVD+-RW GT80N, A103, max UDMA/100
[ 1.611383] scsi 0:0:0:0: Direct-Access ATA SAMSUNG SSD PM83 CXM0 PQ: 0 ANSI: 5
[ 1.613232] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.613236] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.613240] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.613386] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.615244] ata2.00: configured for UDMA/100
[ 1.625042] scsi 1:0:0:0: CD-ROM HL-DT-ST DVD+-RW GT80N A103 PQ: 0 ANSI: 5
[ 1.627766] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.627838] sd 0:0:0:0: [sda] Write Protect is off
[ 1.627841] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.627859] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.628429] sda: sda1 sda2 < sda5 >
[ 1.628642] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.629423] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.629427] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.629518] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.630468] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.630493] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.703422] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.703427] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.703558] hub 1-1:1.0: USB hub found
[ 1.703663] hub 1-1:1.0: 6 ports detected
[ 1.814702] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.946721] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.946725] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.946859] hub 2-1:1.0: USB hub found
[ 1.946963] hub 2-1:1.0: 8 ports detected
[ 2.113845] usb 3-2: new full-speed USB device number 2 using xhci_hcd
[ 2.133123] usb 3-2: New USB device found, idVendor=046d, idProduct=c52b
[ 2.133127] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.133130] usb 3-2: Product: USB Receiver
[ 2.133132] usb 3-2: Manufacturer: Logitech
[ 2.135764] usbcore: registered new interface driver usbhid
[ 2.135766] usbhid: USB HID core driver
[ 2.141029] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[ 2.143870] input: Logitech Unifying Device. Wireless PID:401b as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/input/input0
[ 2.143918] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:401b] on usb-0000:00:14.0-2:1
[ 2.145944] input: Logitech Unifying Device. Wireless PID:4016 as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/input/input1
[ 2.145971] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4016] on usb-0000:00:14.0-2:2
[ 2.205735] usb 1-1.6: new high-speed USB device number 3 using ehci_hcd
[ 2.299213] usb 1-1.6: New USB device found, idVendor=058f, idProduct=6362
[ 2.299217] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.299220] usb 1-1.6: Product: Mass Storage Device
[ 2.299223] usb 1-1.6: Manufacturer: Generic
[ 2.299225] usb 1-1.6: SerialNumber: 058F63626420
[ 2.300618] Initializing USB Mass Storage driver...
[ 2.300675] scsi6 : usb-storage 1-1.6:1.0
[ 2.300715] usbcore: registered new interface driver usb-storage
[ 2.300717] USB Mass Storage support registered.
[ 3.295260] scsi 6:0:0:0: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 0
[ 3.295875] scsi 6:0:0:1: Direct-Access Generic- Compact Flash 1.01 PQ: 0 ANSI: 0
[ 3.296373] scsi 6:0:0:2: Direct-Access Generic- SM/xD Picture 1.02 PQ: 0 ANSI: 0
[ 3.296872] scsi 6:0:0:3: Direct-Access Generic- MS/MS-Pro 1.03 PQ: 0 ANSI: 0
[ 3.297205] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 3.297313] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 3.297483] sd 6:0:0:2: Attached scsi generic sg4 type 0
[ 3.297565] sd 6:0:0:3: Attached scsi generic sg5 type 0
[ 3.300968] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 3.302844] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3.308442] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[ 3.309069] sd 6:0:0:3: [sde] Attached SCSI removable disk
[ 6.673062] PM: Starting manual resume from disk
[ 6.673064] PM: Hibernation image partition 8:5 present
[ 6.673065] PM: Looking for hibernation image.
[ 6.673298] PM: Image not found (code -22)
[ 6.673302] PM: Hibernation image not present or could not be loaded.
[ 6.681358] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.820057] udevd[425]: starting version 175
[ 6.858997] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.859003] ACPI: Power Button [PWRB]
[ 6.859032] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 6.859034] ACPI: Power Button [PWRF]
[ 6.864759] iTCO_vendor_support: vendor-support=0
[ 6.865827] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 6.865886] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 6.865931] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 6.876468] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 6.883907] [drm] Initialized drm 1.1.0 20060810
[ 6.884921] ACPI Warning: 0x0000f000-0x0000f01f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 6.884926] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.894735] [drm] radeon kernel modesetting enabled.
[ 6.896871] [drm] initializing kernel modesetting (CAICOS 0x1002:0x6778 0x1028:0x2120).
[ 6.896894] [drm] register mmio base: 0xF7E20000
[ 6.896896] [drm] register mmio size: 131072
[ 6.897138] ATOM BIOS: C26411
[ 6.897163] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 6.897165] radeon 0000:01:00.0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
[ 6.897168] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 6.897170] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 6.897171] [drm] RAM width 64bits DDR
[ 6.897273] [TTM] Zone kernel: Available graphics memory: 433244 kiB
[ 6.897275] [TTM] Zone highmem: Available graphics memory: 1806866 kiB
[ 6.897276] [TTM] Initializing pool allocator
[ 6.897289] [drm] radeon: 1024M of VRAM memory ready
[ 6.897290] [drm] radeon: 512M of GTT memory ready.
[ 6.897298] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 6.897755] [drm] radeon: ib pool ready.
[ 6.897806] [drm] Loading CAICOS Microcode
[ 6.900763] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 6.925709] hda_codec: ALC269VB: SKU not ready 0x411111f0
[ 6.928150] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4
[ 6.931853] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 6.931889] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 6.931921] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 6.931956] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 7.811911] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 7.812021] radeon 0000:01:00.0: WB enabled
[ 7.812024] [drm] fence driver on ring 0 use gpu addr 0x40000c00 and cpu addr 0xff9d7c00
[ 7.812026] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 7.812027] [drm] Driver supports precise vblank timestamp query.
[ 7.812057] [drm] radeon: irq initialized.
[ 7.828251] [drm] ring test on 0 succeeded in 3 usecs
[ 7.828387] [drm] ib test on ring 0 succeeded in 0 usecs
[ 7.828778] [drm] Radeon Display Connectors
[ 7.828779] [drm] Connector 0:
[ 7.828780] [drm] DisplayPort
[ 7.828781] [drm] HPD2
[ 7.828783] [drm] DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[ 7.828784] [drm] Encoders:
[ 7.828785] [drm] DFP1: INTERNAL_UNIPHY1
[ 7.828786] [drm] Connector 1:
[ 7.828787] [drm] DVI-I
[ 7.828788] [drm] HPD4
[ 7.828789] [drm] DDC: 0x6450 0x6450 0x6454 0x6454 0x6458 0x6458 0x645c 0x645c
[ 7.828790] [drm] Encoders:
[ 7.828791] [drm] DFP2: INTERNAL_UNIPHY
[ 7.828792] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 7.828855] [drm] Internal thermal controller without fan control
[ 7.829682] [drm] radeon: power management initialized
[ 7.899875] [drm] fb mappable at 0xE0142000
[ 7.899876] [drm] vram apper at 0xE0000000
[ 7.899877] [drm] size 8294400
[ 7.899878] [drm] fb depth is 24
[ 7.899879] [drm] pitch is 7680
[ 7.899914] fbcon: radeondrmfb (fb0) is primary device
[ 8.309479] Console: switching to colour frame buffer device 240x67
[ 8.312794] fb0: radeondrmfb frame buffer device
[ 8.312796] drm: registered panic notifier
[ 8.312799] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 8.329988] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[ 8.487957] Adding 5105660k swap on /dev/sda5. Priority:-1 extents:1 across:5105660k SS
[ 8.495197] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 8.531141] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.543223] loop: module loaded
[ 8.853372] RPC: Registered named UNIX socket transport module.
[ 8.853374] RPC: Registered udp transport module.
[ 8.853375] RPC: Registered tcp transport module.
[ 8.853376] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 8.856907] FS-Cache: Loaded
[ 8.860932] NFS: Registering the id_resolver key type
[ 8.860942] FS-Cache: Netfs 'nfs' registered for caching
[ 8.863898] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 9.197698] Bluetooth: Core ver 2.16
[ 9.197709] NET: Registered protocol family 31
[ 9.197710] Bluetooth: HCI device and connection manager initialized
[ 9.197712] Bluetooth: HCI socket layer initialized
[ 9.197713] Bluetooth: L2CAP socket layer initialized
[ 9.197716] Bluetooth: SCO socket layer initialized
[ 9.199801] Bluetooth: RFCOMM TTY layer initialized
[ 9.199804] Bluetooth: RFCOMM socket layer initialized
[ 9.199806] Bluetooth: RFCOMM ver 1.11
[ 9.202063] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.202065] Bluetooth: BNEP filters: protocol multicast
[ 9.211174] lp: driver loaded but no devices found
[ 9.213719] ppdev: user-space parallel port driver
[ 9.427862] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.094440] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input10
[ 11.051142] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx
[ 11.051146] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 11.051224] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 228.435866] I-pipe: head domain RTAI registered.
[ 228.435869] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 228.435912] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 228.435914] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 228.435916] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 228.435918] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6182500
[ 228.444326] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 228.444342] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 228.444345] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 228.444347] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 228.444348] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 228.451040] RTAI[math]: loaded.
[ 228.638201] RTAI[math]: unloaded.
[ 228.639059] SCHED releases registered named ALIEN PEDV$D
[ 228.641122] RTAI[malloc]: unloaded.
[ 228.737759] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 228.738666] I-pipe: head domain RTAI unregistered.
[ 228.738713] RTAI[hal]: unmounted.
[ 806.941841] I-pipe: head domain RTAI registered.
[ 806.941844] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 806.941887] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 806.941889] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 806.941890] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 806.941892] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5235000
[ 806.945027] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 806.945043] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 806.945046] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 806.945048] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 806.945049] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 806.949433] RTAI[math]: loaded.
[ 807.124388] RTAI[math]: unloaded.
[ 807.125238] SCHED releases registered named ALIEN PEDV$D
[ 807.127395] RTAI[malloc]: unloaded.
[ 807.223444] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 807.224364] I-pipe: head domain RTAI unregistered.
[ 807.224410] RTAI[hal]: unmounted.
any help or thoughts would be very appreciated.
So it looks like you have a line somewhere in your ini or hal that tells the system to call up a file named "BigGrayBeast.hal" and that file does not seem to exist in your config folder.
- Thank you received: 5979
- mjones@welfab.ca
here is the error message, wish it would let me copy just the debug info. my hal for the connections must be wrong, but im not sure where
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15
Machine configuration directory is '/home/hard/linuxcnc/configs/test4'
Machine configuration file is 'test4.ini'
INIFILE=/home/hard/linuxcnc/configs/test4/test4.ini
TASK=milltask
HALUI=halui
DISPLAY=axis
Found file(REL): ./test4.hal
Running HAL shutdown script
./test4.hal:27: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
9739
[ 0.196479] #2
[ 0.216420] #3 Ok.
[ 0.232434] dummy:
[ 3869.984646] I-pipe: head domain RTAI registered.
[ 3869.984650] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3869.984707] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3869.984710] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 3869.984711] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3869.984713] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 4162500
[ 3869.987905] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3869.987922] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3869.987925] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3869.987927] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 3869.987928] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3869.992714] RTAI[math]: loaded.
[ 3870.003694] config string '0 out'
[ 3870.004270] PARPORT: ERROR: linux parport 0 not found
[ 3879.723387] RTAI[math]: unloaded.
[ 3879.724241] SCHED releases registered named ALIEN PEDV$D
[ 3879.726903] RTAI[malloc]: unloaded.
[ 3879.824639] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3879.825574] I-pipe: head domain RTAI unregistered.
[ 3879.825621] RTAI[hal]: unmounted.
[ 3943.053667] I-pipe: head domain RTAI registered.
[ 3943.053671] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3943.053713] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3943.053715] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 3943.053716] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3943.053718] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5838250
[ 3943.056849] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3943.056866] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3943.056868] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3943.056870] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 3943.056871] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3943.061768] RTAI[math]: loaded.
[ 3943.109315] hm2: loading Mesa HostMot2 driver version 0.15
[ 3943.111508] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3943.111534] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 3943.112128] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3943.116048] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 3943.118719] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 3943.203350] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3943.203352] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 3943.203354] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 3943.203356] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 3943.203357] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 3943.203359] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 3943.203361] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3943.203362] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3943.203364] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3943.203365] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3943.203367] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3943.203369] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3943.203370] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3943.203372] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3943.203374] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3943.203375] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3943.203377] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3943.203378] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3943.203380] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3943.203381] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3943.203382] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3943.203384] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3943.203385] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3943.203386] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3943.203387] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3943.203389] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3943.203390] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3943.203391] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3943.203392] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3943.203394] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3943.203395] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3943.203396] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3943.203397] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3943.203398] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3943.203400] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3943.203444] hm2/hm2_5i25.0: registered
[ 3943.203446] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 3943.330256] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 3943.330260] hm2/hm2_5i25.0: unregistered
[ 3943.330296] hm2_pci: driver unloaded
[ 3943.331167] hm2: unloading
[ 3945.371515] RTAI[math]: unloaded.
[ 3945.372367] SCHED releases registered named ALIEN PEDV$D
[ 3945.374610] RTAI[malloc]: unloaded.
[ 3945.472897] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3945.473792] I-pipe: head domain RTAI unregistered.
[ 3945.473838] RTAI[hal]: unmounted.
[ 4753.983872] I-pipe: head domain RTAI registered.
[ 4753.983876] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4753.983918] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4753.983920] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 4753.983921] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4753.983923] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5400750
[ 4753.987035] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4753.987051] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4753.987054] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 4753.987056] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 4753.987057] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4753.992588] RTAI[math]: loaded.
[ 4754.030973] hm2: loading Mesa HostMot2 driver version 0.15
[ 4754.031964] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4754.031990] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 4754.032852] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4754.036730] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 4754.039399] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 4754.124254] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4754.124256] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 4754.124258] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 4754.124260] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 4754.124262] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 4754.124263] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 4754.124265] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 4754.124266] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 4754.124268] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4754.124270] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4754.124271] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4754.124273] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4754.124275] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4754.124276] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4754.124278] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4754.124280] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4754.124281] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4754.124283] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4754.124284] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4754.124286] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4754.124287] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4754.124288] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4754.124289] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4754.124290] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4754.124292] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4754.124293] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 4754.124294] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 4754.124295] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 4754.124297] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 4754.124298] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 4754.124299] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 4754.124300] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 4754.124302] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 4754.124303] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 4754.124304] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 4754.124353] hm2/hm2_5i25.0: registered
[ 4754.124355] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 4754.131682] classicladder_rt: module license 'LGPL' taints kernel.
[ 4754.131684] Disabling lock debugging due to kernel taint
[ 4754.131796] creating ladder-state
[ 4754.310857] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 4754.310861] hm2/hm2_5i25.0: unregistered
[ 4754.310890] hm2_pci: driver unloaded
[ 4754.311772] hm2: unloading
[ 4756.355733] RTAI[math]: unloaded.
[ 4756.356584] SCHED releases registered named ALIEN PEDV$D
[ 4756.358850] RTAI[malloc]: unloaded.
[ 4756.457708] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4756.458614] I-pipe: head domain RTAI unregistered.
[ 4756.458662] RTAI[hal]: unmounted.
[ 4851.765208] I-pipe: head domain RTAI registered.
[ 4851.765212] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4851.765254] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4851.765256] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 4851.765257] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4851.765259] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6230000
[ 4851.768359] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4851.768376] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4851.768378] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 4851.768380] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 4851.768382] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4851.772778] RTAI[math]: loaded.
[ 4851.950806] RTAI[math]: unloaded.
[ 4851.951656] SCHED releases registered named ALIEN PEDV$D
[ 4851.953814] RTAI[malloc]: unloaded.
[ 4852.052325] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4852.053237] I-pipe: head domain RTAI unregistered.
[ 4852.053284] RTAI[hal]: unmounted.
[ 5207.872767] I-pipe: head domain RTAI registered.
[ 5207.872770] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5207.872812] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5207.872814] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 5207.872816] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5207.872818] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6192750
[ 5207.875955] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5207.875971] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5207.875974] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 5207.875976] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 5207.875977] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5207.880429] RTAI[math]: loaded.
[ 5207.918886] hm2: loading Mesa HostMot2 driver version 0.15
[ 5207.919910] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 5207.919936] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 5207.920795] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 5207.924674] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 5207.927344] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 5208.012402] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 5208.012405] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 5208.012407] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 5208.012408] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 5208.012410] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 5208.012412] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 5208.012413] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 5208.012415] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 5208.012416] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 5208.012418] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 5208.012420] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 5208.012421] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 5208.012423] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 5208.012425] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 5208.012426] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 5208.012428] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 5208.012429] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 5208.012431] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 5208.012433] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 5208.012434] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 5208.012435] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 5208.012436] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 5208.012438] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 5208.012439] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 5208.012440] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 5208.012441] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 5208.012442] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 5208.012444] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 5208.012445] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 5208.012446] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 5208.012447] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 5208.012449] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 5208.012450] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 5208.012451] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 5208.012452] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 5208.012502] hm2/hm2_5i25.0: registered
[ 5208.012503] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 5208.016105] creating ladder-state
[ 5208.177550] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 5208.177554] hm2/hm2_5i25.0: unregistered
[ 5208.177593] hm2_pci: driver unloaded
[ 5208.178670] hm2: unloading
[ 5210.222708] RTAI[math]: unloaded.
[ 5210.223562] SCHED releases registered named ALIEN PEDV$D
[ 5210.225737] RTAI[malloc]: unloaded.
[ 5210.323768] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5210.324748] I-pipe: head domain RTAI unregistered.
[ 5210.324796] RTAI[hal]: unmounted.
[ 6487.291469] I-pipe: head domain RTAI registered.
[ 6487.291473] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 6487.291517] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6487.291519] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 6487.291520] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6487.291522] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6187250
[ 6487.294648] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6487.294667] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6487.294669] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 6487.294671] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 6487.294672] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6487.299603] RTAI[math]: loaded.
[ 6487.338199] hm2: loading Mesa HostMot2 driver version 0.15
[ 6487.339196] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 6487.339224] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 6487.340087] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 6487.343963] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 6487.346632] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 6487.431499] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 6487.431501] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 6487.431502] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 6487.431504] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 6487.431506] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 6487.431508] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 6487.431509] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 6487.431511] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 6487.431512] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 6487.431514] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 6487.431516] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 6487.431517] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 6487.431519] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 6487.431521] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 6487.431522] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 6487.431524] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 6487.431525] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 6487.431527] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 6487.431529] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 6487.431530] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 6487.431531] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 6487.431532] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 6487.431534] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 6487.431535] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 6487.431536] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 6487.431537] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 6487.431538] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 6487.431540] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 6487.431541] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 6487.431542] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 6487.431543] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 6487.431545] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 6487.431546] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 6487.431547] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 6487.431548] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 6487.431598] hm2/hm2_5i25.0: registered
[ 6487.431599] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 6487.435134] creating ladder-state
[ 6487.623683] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 6487.623686] hm2/hm2_5i25.0: unregistered
[ 6487.623750] hm2_pci: driver unloaded
[ 6487.624846] hm2: unloading
[ 6489.669008] RTAI[math]: unloaded.
[ 6489.669863] SCHED releases registered named ALIEN PEDV$D
[ 6489.671981] RTAI[malloc]: unloaded.
[ 6489.768899] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6489.769808] I-pipe: head domain RTAI unregistered.
[ 6489.769855] RTAI[hal]: unmounted.
[71852.945619] I-pipe: head domain RTAI registered.
[71852.945623] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[71852.945665] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[71852.945667] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[71852.945668] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[71852.945670] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6228750
[71852.948778] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[71852.948794] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[71852.948796] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[71852.948798] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[71852.948799] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[71852.953256] RTAI[math]: loaded.
[71852.991143] hm2: loading Mesa HostMot2 driver version 0.15
[71852.992092] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[71852.992119] hm2_pci: discovered 5i25 at 0000:04:00.0
[71852.992691] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[71852.996610] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[71852.999281] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[71853.083952] hm2/hm2_5i25.0: 34 I/O Pins used:
[71853.083954] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[71853.083956] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[71853.083958] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[71853.083960] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[71853.083961] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[71853.083963] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[71853.083964] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[71853.083966] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[71853.083967] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[71853.083969] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[71853.083971] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[71853.083972] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[71853.083974] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[71853.083976] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[71853.083977] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[71853.083978] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[71853.083980] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[71853.083981] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[71853.083982] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[71853.083983] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[71853.083984] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[71853.083986] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[71853.083987] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[71853.083988] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[71853.083989] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[71853.083991] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[71853.083992] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[71853.083993] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[71853.083994] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[71853.083999] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[71853.084001] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[71853.084003] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[71853.084005] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[71853.084006] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[71853.084048] hm2/hm2_5i25.0: registered
[71853.084050] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[71853.221444] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[71853.221448] hm2/hm2_5i25.0: unregistered
[71853.221476] hm2_pci: driver unloaded
[71853.222349] hm2: unloading
[71855.267451] RTAI[math]: unloaded.
[71855.268319] SCHED releases registered named ALIEN PEDV$D
[71855.270540] RTAI[malloc]: unloaded.
[71855.368913] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[71855.369819] I-pipe: head domain RTAI unregistered.
[71855.369866] RTAI[hal]: unmounted.
[72364.521772] I-pipe: head domain RTAI registered.
[72364.521776] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72364.521818] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72364.521820] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72364.521821] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72364.521823] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6229250
[72364.524953] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72364.524970] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72364.524973] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72364.524975] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72364.524976] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72364.529059] RTAI[math]: loaded.
[72364.567148] hm2: loading Mesa HostMot2 driver version 0.15
[72364.568093] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72364.568120] hm2_pci: discovered 5i25 at 0000:04:00.0
[72364.568707] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72364.572626] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72364.575294] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72364.659961] hm2/hm2_5i25.0: 34 I/O Pins used:
[72364.659963] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72364.659965] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72364.659967] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72364.659968] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72364.659970] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72364.659972] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72364.659973] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72364.659975] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72364.659976] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72364.659978] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72364.659980] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72364.659981] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72364.659983] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72364.659985] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72364.659987] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72364.659989] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72364.659990] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72364.659992] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72364.659993] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72364.659994] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72364.659996] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72364.659997] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72364.659998] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72364.659999] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72364.660001] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72364.660002] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72364.660003] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72364.660004] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72364.660005] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72364.660007] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72364.660008] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72364.660009] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72364.660010] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72364.660012] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72364.660052] hm2/hm2_5i25.0: registered
[72364.660054] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72364.662279] creating ladder-state
[72364.792504] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72364.792507] hm2/hm2_5i25.0: unregistered
[72364.792535] hm2_pci: driver unloaded
[72364.793366] hm2: unloading
[72366.838295] RTAI[math]: unloaded.
[72366.839149] SCHED releases registered named ALIEN PEDV$D
[72366.841437] RTAI[malloc]: unloaded.
[72366.937967] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72366.938917] I-pipe: head domain RTAI unregistered.
[72366.938963] RTAI[hal]: unmounted.
[72461.339397] I-pipe: head domain RTAI registered.
[72461.339401] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72461.339444] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72461.339446] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72461.339447] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72461.339449] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6194250
[72461.342567] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72461.342583] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72461.342585] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72461.342587] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72461.342589] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72461.347017] RTAI[math]: loaded.
[72461.385888] hm2: loading Mesa HostMot2 driver version 0.15
[72461.386892] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72461.386920] hm2_pci: discovered 5i25 at 0000:04:00.0
[72461.387785] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72461.391658] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72461.394327] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72461.479213] hm2/hm2_5i25.0: 34 I/O Pins used:
[72461.479216] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72461.479217] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72461.479219] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72461.479221] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72461.479223] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72461.479224] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72461.479226] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72461.479227] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72461.479229] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72461.479231] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72461.479232] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72461.479234] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72461.479236] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72461.479237] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72461.479239] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72461.479241] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72461.479242] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72461.479244] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72461.479245] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72461.479246] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72461.479247] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72461.479249] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72461.479250] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72461.479251] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72461.479252] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72461.479254] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72461.479255] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72461.479256] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72461.479257] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72461.479258] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72461.479260] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72461.479261] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72461.479262] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72461.479263] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72461.479313] hm2/hm2_5i25.0: registered
[72461.479314] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72461.482897] creating ladder-state
[72461.650091] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72461.650095] hm2/hm2_5i25.0: unregistered
[72461.650124] hm2_pci: driver unloaded
[72461.651005] hm2: unloading
[72463.694523] RTAI[math]: unloaded.
[72463.695375] SCHED releases registered named ALIEN PEDV$D
[72463.697401] RTAI[malloc]: unloaded.
[72463.796971] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72463.797885] I-pipe: head domain RTAI unregistered.
[72463.797932] RTAI[hal]: unmounted.
[72537.926415] I-pipe: head domain RTAI registered.
[72537.926419] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72537.926461] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72537.926463] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72537.926464] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72537.926466] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5435500
[72537.929620] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72537.929636] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72537.929639] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72537.929641] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72537.929642] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72537.933903] RTAI[math]: loaded.
[72537.972639] hm2: loading Mesa HostMot2 driver version 0.15
[72537.973648] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72537.973675] hm2_pci: discovered 5i25 at 0000:04:00.0
[72537.974538] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72537.978414] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72537.981086] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72538.065976] hm2/hm2_5i25.0: 34 I/O Pins used:
[72538.065978] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72538.065980] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72538.065982] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72538.065983] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72538.065985] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72538.065987] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72538.065988] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72538.065990] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72538.065991] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72538.065993] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72538.065995] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72538.065996] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72538.065998] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72538.066000] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72538.066001] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72538.066003] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72538.066004] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72538.066006] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72538.066007] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72538.066008] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72538.066010] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72538.066011] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72538.066012] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72538.066013] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72538.066014] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72538.066016] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72538.066017] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72538.066018] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72538.066019] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72538.066020] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72538.066022] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72538.066023] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72538.066024] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72538.066025] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72538.066075] hm2/hm2_5i25.0: registered
[72538.066076] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72538.069636] creating ladder-state
[72538.261786] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72538.261790] hm2/hm2_5i25.0: unregistered
[72538.261830] hm2_pci: driver unloaded
[72538.262766] hm2: unloading
[72540.306256] RTAI[math]: unloaded.
[72540.307112] SCHED releases registered named ALIEN PEDV$D
[72540.309066] RTAI[malloc]: unloaded.
[72540.405902] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72540.406797] I-pipe: head domain RTAI unregistered.
[72540.406843] RTAI[hal]: unmounted.
[73212.931803] I-pipe: head domain RTAI registered.
[73212.931807] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[73212.931849] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[73212.931851] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[73212.931853] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[73212.931855] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5872750
[73212.934981] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[73212.934997] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[73212.935000] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[73212.935002] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[73212.935003] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[73212.938853] RTAI[math]: loaded.
[73212.976876] hm2: loading Mesa HostMot2 driver version 0.15
[73212.977826] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[73212.977852] hm2_pci: discovered 5i25 at 0000:04:00.0
[73212.978498] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[73212.982419] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[73212.985087] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[73213.069745] hm2/hm2_5i25.0: 34 I/O Pins used:
[73213.069748] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[73213.069750] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[73213.069752] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[73213.069754] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[73213.069755] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[73213.069757] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[73213.069758] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[73213.069760] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[73213.069761] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[73213.069763] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[73213.069765] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[73213.069766] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[73213.069768] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[73213.069770] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[73213.069771] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[73213.069773] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[73213.069774] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[73213.069776] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[73213.069777] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[73213.069778] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[73213.069780] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[73213.069781] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[73213.069782] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[73213.069783] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[73213.069785] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[73213.069786] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[73213.069787] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[73213.069788] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[73213.069789] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[73213.069791] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[73213.069792] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[73213.069793] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[73213.069794] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[73213.069796] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[73213.069838] hm2/hm2_5i25.0: registered
[73213.069840] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[73213.199287] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[73213.199290] hm2/hm2_5i25.0: unregistered
[73213.199320] hm2_pci: driver unloaded
[73213.200151] hm2: unloading
[73215.241794] RTAI[math]: unloaded.
[73215.242664] SCHED releases registered named ALIEN PEDV$D
[73215.244686] RTAI[malloc]: unloaded.
[73215.343753] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[73215.344665] I-pipe: head domain RTAI unregistered.
[73215.344711] RTAI[hal]: unmounted.
[74069.654705] I-pipe: head domain RTAI registered.
[74069.654709] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[74069.654751] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[74069.654753] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[74069.654755] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[74069.654757] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5948500
[74069.657897] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[74069.657913] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[74069.657915] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[74069.657917] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[74069.657919] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[74069.667361] RTAI[math]: loaded.
[74069.705261] hm2: loading Mesa HostMot2 driver version 0.15
[74069.706219] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[74069.706246] hm2_pci: discovered 5i25 at 0000:04:00.0
[74069.706892] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[74069.710760] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[74069.713435] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[74069.798135] hm2/hm2_5i25.0: 34 I/O Pins used:
[74069.798137] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[74069.798138] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[74069.798140] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[74069.798142] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[74069.798144] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[74069.798145] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[74069.798147] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[74069.798148] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[74069.798150] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[74069.798152] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[74069.798153] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[74069.798155] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[74069.798157] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[74069.798158] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[74069.798160] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[74069.798162] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[74069.798163] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[74069.798165] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[74069.798166] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[74069.798167] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[74069.798168] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[74069.798170] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[74069.798171] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[74069.798172] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[74069.798173] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[74069.798175] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[74069.798176] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[74069.798177] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[74069.798178] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[74069.798180] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[74069.798181] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[74069.798182] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[74069.798183] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[74069.798184] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[74069.798227] hm2/hm2_5i25.0: registered
[74069.798228] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[74069.927277] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[74069.927281] hm2/hm2_5i25.0: unregistered
[74069.927310] hm2_pci: driver unloaded
[74069.928144] hm2: unloading
[74071.969253] RTAI[math]: unloaded.
[74071.970108] SCHED releases registered named ALIEN PEDV$D
[74071.972494] RTAI[malloc]: unloaded.
[74072.069748] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[74072.070652] I-pipe: head domain RTAI unregistered.
[74072.070700] RTAI[hal]: unmounted.
This means that the field-power to the 7i76 is not connected. The smart-serial part of the 7i76 is powered by the field power, so without field power the 7i76 GPIO won't show up../test4.hal:27: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
[ 4754.124265] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort <<<<<<<<<<<<<<< Missing TX0
[ 4754.124266] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort <<<<<<<<<<<<<<< Missing RX0
and./test4.hal:27: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
Indicate that LinuxCNC did not find the 7I77s digital I/O section. (but did find the analog section and something
plugged into the 7I77s sserial expansion connector). Do you have field power on the 7I77s orange connector?
- mjones@welfab.ca
- mjones@welfab.ca
Field power is always separate
