new pnc.config won't load in linuxcnc
- mjones@welfab.ca
22 Jul 2021 14:40 #215585
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic new pnc.config won't load in linuxcnc
the two yellow leds for power are on.
Here is the requested line.
loadrt hm2_pci config=" num_encoders=5 num_pwmgens=0 num_stepgens=0 sserial_port_0=00000x"
- mjones@welfab.ca
22 Jul 2021 14:45 #215586
by mjones@welfab.ca
here are screenshots of how i am setting up in pnc.config
22 Jul 2021 14:50 #215587
Replied by PCW on topic new pnc.config won't load in linuxcnc
OK that looks ok (other than that all the 7I76 stepgens are disabled)
Did you verify the firmware with
sudo mesaflash --device 5i25 --readhmid
- mjones@welfab.ca
22 Jul 2021 14:57 #215588
by mjones@welfab.ca
no i didn't but just did. this is what it sent back.
hard@hard:~$ sudo mesaflash --device 5i25 --readhmid
[sudo] password for hard:
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 8 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort StepGen 0 Dir/Table2 (Out)
14 18 IOPort StepGen 0 Step/Table1 (Out)
2 19 IOPort StepGen 1 Dir/Table2 (Out)
15 20 IOPort StepGen 1 Step/Table1 (Out)
3 21 IOPort StepGen 2 Dir/Table2 (Out)
16 22 IOPort StepGen 2 Step/Table1 (Out)
4 23 IOPort StepGen 3 Dir/Table2 (Out)
17 24 IOPort StepGen 3 Step/Table1 (Out)
5 25 IOPort StepGen 4 Dir/Table2 (Out)
6 26 IOPort StepGen 4 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort MuxedQCount 3 MuxQ-IDX (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-A (In)
hard@hard:~$ ^C
hard@hard:~$
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 3
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
hard@hard:~$ ^C
hard@hard:~$
22 Jul 2021 15:07 #215590
OK, the firmware looks correct
Is the 7I76 5V power coming from the 6I25 or externally supplied to the 7I76?
- mjones@welfab.ca
22 Jul 2021 15:15 #215592
by mjones@welfab.ca
the 7i76 is externally powered
22 Jul 2021 15:18 #215593
OK so is the 6I25 W1 in the down position?
Also what are the 7I76 jumper positions?
- mjones@welfab.ca
22 Jul 2021 15:36 - 22 Jul 2021 15:37 #215596
by mjones@welfab.ca
w1=left
w2=down
w3=down
w4=up
w5=up
w6=up
w7=down
w8=left
w9=up
w10=left
w11=left
w12=down
w13=left
also 6i25 w1 is down
w2=down
w3=down
w4=up
w5=up
w6=up
w7=down
w8=left
w9=up
w10=left
w11=left
w12=down
w13=left
Last edit: 22 Jul 2021 15:37 by mjones@welfab.ca.
22 Jul 2021 15:55 #215598
No sure I understand, the 7I76 only has 6 jumpers
and they are all right/left orientation
- mjones@welfab.ca
22 Jul 2021 15:58 #215599
by mjones@welfab.ca
its a 7i76E im sure i put that at the beggining
Time to create page: 0.234 seconds
