PnCConf Wizard doesn't launch
03 Aug 2021 02:04 - 03 Aug 2021 02:05 #216773
by CFE
PnCConf Wizard doesn't launch was created by CFE
Hi all,
I am setting up a computer to control our plasma cutter through a MESA 7i76E card. I got the ethernet connection established between the computer and the card, and I get info about the card when I go "mesaflash --device 7i76e --addr 10.10.10.10 --readhmid" in a terminal. So far, so good. But the PnCConf wizard doesn't launch from the applications menu, and if I try "pncconf" in a terminal then I get the following message :
/usr/bin/pncconf:43: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
from gi.repository import Gtk as gtk
File "/usr/bin/pncconf", line 45, in <module>
import gtk.glade
ModuleNotFoundError: No module named 'gtk.glade'
We have a buildbot installation on buster, master-rtpreempt, 2.9, and I have installed glade with "sudo apt-get install glade" in a terminal. How do we get the PnCConf wizard to work ?
Cheers, Peter
import gtk.glade
Cheers, Peter
Last edit: 03 Aug 2021 02:05 by CFE.
03 Aug 2021 04:42 #216781
Replied by cmorley on topic PnCConf Wizard doesn't launch
Looks like pncconf is broken in master now do to the python2/ python3 change.
I'm not sure why it was partially converted to python3.
This won't be quick to fix - sorry.
03 Aug 2021 11:17 #216801
Replied by rodw on topic PnCConf Wizard doesn't launch
In the absence of pncconf. could you make a new folder under configs and copy these files into it.
This is based on an old example I shared here
forum.linuxcnc.org/47-hal-examples/34072...ranch-gantry-example
But then we went multi spindle so the original hal file is wrong. I think I updated the attached hal file to use spindle.0 but don't have a 7i76e on this PC to test.
Time to learn how to edit hal and ini files. (Just like I had to before pncconf supported the 7i76e)
Please let me know how you get on
03 Aug 2021 12:35 #216807
by BigJohnT
Replied by BigJohnT on topic PnCConf Wizard doesn't launch
My configuration tools all work with Python 3, you should be able to get a working configuration with the 7i76e configuration tool.
gnipsel.com/mesa/index.html
JT
JT
03 Aug 2021 13:29 #216816
by BigJohnT
Another option is to do a git checkout of 2.8 and build a RIP. Then run Pncconf from the RIP to build your configuration. Interesting I can't find any mention of how to build a RIP in the documents...
JT
JT
03 Aug 2021 13:34 #216817
by BigJohnT
03 Aug 2021 14:44 #216837
by bevins
Replied by bevins on topic PnCConf Wizard doesn't launch
What? Pncconf is broken? that blows.
Time to check JT's stuff out. I have another plasma machine next week to do.
Anything else broken we need to know about?
IS 2.8 QTplasmac updated to latest or we need master for that?
- robertspark
- Thank you received: 216
03 Aug 2021 17:16 #216853
by robertspark
Replied by robertspark on topic PnCConf Wizard doesn't launch
could install from *.Deb files of previous buildbot installs too.... that is how I am upgrading to test and downgrade to run stuff.... not happy about changes but heyho such is a development release and the nature of old applications no longer being supported.....
03 Aug 2021 23:16 #216874
by CFE
Replied by CFE on topic PnCConf Wizard doesn't launch
Hi all,
Thank you for the responses. I have used our old computer which is currently driving the plasma cutter to make up configuration files using PnCConf. I will copy them to the new computer and manually edit the ini and hal files, that is for us the path of least trouble.
We are going from using a parallel port setup to the MESA ethernet setup, and I see in the hal files pin and signal names we are not familiar with. Is there a document somewhere which explains which pin/signal does what ? That will be a great help to understand the workings of the hal files for the MESA card.
Cheers, Peter
Cheers, Peter
- Thank you received: 5979
04 Aug 2021 09:08 #216895
Replied by tommylight on topic PnCConf Wizard doesn't launch
There are sim configs included with LinuxCNC for Mesa boards, have a look at those as a starting point.
Time to create page: 0.121 seconds
