PnCConf Wizard doesn't launch
04 Aug 2021 12:13 #216903
by BigJohnT
Replied by BigJohnT on topic PnCConf Wizard doesn't launch
All the sims for Mesa look like very old cards like 5i20 era. I don't see any for the newer cards.
JT
JT
09 Aug 2021 01:14 #217274
by CFE
Replied by CFE on topic PnCConf Wizard doesn't launch
Hi all,
I have manually set up .ini and .hal files to create a basic machine, and I wanted to run PlasmaC/QtPlasmaC configurator. But if I read the QtPlasmaC user guide then QtPlasmaC is now setup with the PnCConf Wizard, which is the very thing that doesn't work. What am I supposed to do now ?
Cheers, Peter
Cheers, Peter
- robertspark
- Thank you received: 216
13 Aug 2021 15:30 #217685
by robertspark
Replied by robertspark on topic PnCConf Wizard doesn't launch
is pncconf working again under master / 2.9 (post python 3
migration)
I ask from curiosity (not need) as I've seen I think Phil kindly pushing a number of updates and I'm updating and rebuilding my RIP daily and did try pncconf last night and could not get it to start.
migration)
13 Aug 2021 20:08 #217702
Also Debian Bullseye is scheduled for release today (14th). It is based on the 5.10 kernel and includes PREEMPT_RT in its distro. Robert and I have built it and I was planning to write a how to once its released. There are no repos on buildbot for bullseye so it has to be RIP but I was able to build the debs and install LCNC to the menus that way. There is a thread documenting how to go about it in the Installing Linuxcnc section now but its a bit messy to follow as it was not written specifically as a how to.
Replied by rodw on topic PnCConf Wizard doesn't launch
Unfortunately, Phill is not the PNCCONF developer. He said in another thread that he had spent some hours on it but gave up as he did not want to learn Glade. I spent a few minutes on it and gave up. Phil also said that he did not want to create and maintain another seperate configurator. There is a conversion tool that converts python2 to python3 quite reliably and I got rid of 1 or 2 errors but I think the real issue is the use of Glade by PNCCONF is not supported. STEPCONF is also broken. Phill, thought that would be a fairly easy fix.is pncconf working again under master / 2.9 (post python 3
migration)
- robertspark
13 Aug 2021 20:25 #217704
by robertspark
thanks Rod, I was just curious as I too was going to have a fiddle with it (pncconf)
I have been fiddling with NativeCam and trying to python3 it (there are a fair few changes with GI repository as some syntax has changed... not just the GTK or GTD but other stuff too (pixbuf got me a bit last night, but I sorted it.... I think .... it doesn't tell me off any more...)
13 Aug 2021 21:47 #217710
Replied by cmorley on topic PnCConf Wizard doesn't launch
Phill is working on a pncconf branch.
It has not been pushed to master yet.
14 Aug 2021 00:37 #217718
by phillc54
Replied by phillc54 on topic PnCConf Wizard doesn't launch
I have pushed the PnCconf changes. I probably missed something but it does at least seem to build configs.
Stepconf was "fixed" several days ago.
The following user(s) said Thank You: robertspark, snowgoer540
14 Aug 2021 01:49 #217722
NOt sure if I did something unexpected but there are a number of errors loading hostmot2. I think pncconf is stuttering...
loadrt hm2_eth board_ip="10.10.10.10, 192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx, num_encoders=3 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx00xxxx"
- robertspark
14 Aug 2021 02:19 #217725
by robertspark
thanks phill I'll give it a go
14 Aug 2021 02:26 #217727
could you post your pncconf file?
Did you pick two mesa cards?I have pushed the PnCconf changes. I probably missed something but it does at least seem to build configs.
NOt sure if I did something unexpected but there are a number of errors loading hostmot2. I think pncconf is stuttering...loadrt hm2_eth board_ip="10.10.10.10, 192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx, num_encoders=3 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx00xxxx"
Time to create page: 0.160 seconds
