- Configuring LinuxCNC
- PnCConf Wizard
- trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
28 Aug 2021 03:11 #218961
by JJ48_24
Hello.
I am trying to setup my 5i25 7i76 combo but was having some issues getting linux cnc to initilize.}
here is the log
Please let me know if you guys have any ideas on this!
here is the log
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.8.2-11-g6a3d0a434 Machine configuration directory is '/home/max/linuxcnc/configs/my_LinuxCNC_machine' Machine configuration file is 'my_LinuxCNC_machine.ini' INIFILE=/home/max/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=XYZ KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my_LinuxCNC_machine.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script hm2: loading Mesa HostMot2 driver version 0.15 hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 hm2_pci: discovered 5i25 at 0000:06:01.0 hm2/hm2_5i25.0: Low Level init 0.15 hm2/hm2_5i25.0: Smart Serial Firmware Version 43 hm2/hm2_5i25.0: 34 I/O Pins used: hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output) hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output) hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output) hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output) hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input) hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input) hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input) hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:06:01.0 hm2_5i25.0: dropping AnyIO board at 0000:06:01.0 hm2/hm2_5i25.0: unregistered hm2_pci: driver unloaded hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime ./my_LinuxCNC_machine.hal:33: Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977 Stopping realtime threads Unloading hal components RTAPI_PCI: Unmapped 65536 bytes at 0x7fa9ef031000 Note: Using POSIX realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file: /tmp/linuxcnc_info.txt can be posted to a forum or a web site like: http://pastebin.com in order to provide information about the linuxcnc system and configuration. Date: Fri 27 Aug 2021 10:31:46 PM EDT UTC Date: Sat 28 Aug 2021 02:31:46 AM UTC this program: /usr/bin/linuxcnc_info uptime: 22:31:46 up 2:21, 1 user, load average: 0.86, 0.48, 0.38 lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster which linuxcnc: /usr/bin/linuxcnc pwd: /home/max/linuxcnc/configs/my_LinuxCNC_machine USER: max LOGNAME: max HOME: /home/max EDITOR: VISUAL: LANGUAGE: TERM: dumb COLORTERM: DISPLAY: :0.0 DESKTOP: lightdm-xsession display size: 1366x768 pixels (361x203 millimeters) PATH: /usr/bin:/home/max/linuxcnc/configs/my_LinuxCNC_machine/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items: nodename -n: dsl-dhcp-conrtxxahre-76-164-98-226 kernel-name -s: Linux kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.194-2 (2021-06-21) machine -m: x86_64 processor -p: unknown platform -i: unknown oper system -o: GNU/Linux /proc items: cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-17-rt-amd64 root=UUID=28583a68-2fa4-46e9-a847-83b6870757c4 ro initrd=/install/gtk/initrd.gz quiet model name: Intel(R) Pentium(R) D CPU 3.20GHz cores: 2 cpu MHz: 3200.000 parport: 0000-0000 : parport0 0000-0000 : parport0 serial: 0000-0000 : serial Versions: gcc: gcc (Debian 8.3.0-6) 8.3.0 python: Python 2.7.16 git: not_in_PATH git commit: NA tcl: 8.6 tk: 8.6 glade: not_in_PATH glade-gtk2: not_in_PATH linuxcnc_var all: LINUXCNCVERSION: 2.8.2-11-g6a3d0a434 LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples REALTIME: /etc/init.d/realtime RTS: uspace HALLIB_DIR: /usr/share/linuxcnc/hallib dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-===================-=====================-============-===================================================================== un linuxcnc (no description available) un linuxcnc-dev (no description available) un linuxcnc-doc (no description available) ii linuxcnc-doc-en 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (English documentation) ii linuxcnc-doc-es 1:2.8.2.11.g6a3d0a434 all controlador de movimiento para máquinas CNC y robots (Español). ii linuxcnc-doc-fr 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (French documentation) un linuxcnc-sim (no description available) un linuxcnc-sim-dev (no description available) ii linuxcnc-uspace 1:2.8.2.11.g6a3d0a434 amd64 motion controller for CNC machines and robots ii linuxcnc-uspace-dev 1:2.8.2.11.g6a3d0a434 amd64 PC based motion controller for real-time Linux
- Thank you received: 5983
28 Aug 2021 12:12 #218988
Replied by tommylight on topic trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
Usually means there is no field power applied.
28 Aug 2021 16:59 #219024
by JJ48_24
Replied by JJ48_24 on topic trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
As far as I can tell the board is powering on just fine.
28 Aug 2021 17:07 #219025
by bevins
Did you apply field power to the orange connector?
Replied by bevins on topic trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
led's will come on the board whether there is field power or not.As far as I can tell the board is powering on just fine.
The following user(s) said Thank You: JJ48_24
28 Aug 2021 17:10 #219026
by JJ48_24
I see now I am running logic power in but not field power, do I need to keep the logic power connected, or is only field power necessary?
28 Aug 2021 17:12 #219027
Both.
28 Aug 2021 17:14 #219028
by JJ48_24
Thanks for all the help!
28 Aug 2021 19:59 #219044
by JJ48_24
actually just got over to the shop, connected 24v field, and the issue still persists. Any ideas?
28 Aug 2021 20:22 #219045
Replied by PCW on topic trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
If you do not get communication with the 7I76 field I/O section you will not
have any hal pins associated with the field I/O.
Lack of communication could be caused by:
1. No field voltage
2. 7I76. W1 in right hand position
3. No 5V power or mis-matched FPGA card/7I76 cable power options
4. Wrong firmware in FPGA card
5. Bad/loose cable between FPGA card and 7I76
6. 7I76 setup/operate jumper (W3) in setup position
1. No field voltage
28 Aug 2021 23:39 #219053
Wrong plug on the 5i25 ?
- PnCConf Wizard
Time to create page: 0.103 seconds
