Excel file for building the configuration, pinouts etc. ?
- P1-Engineering
- Thank you received: 8
05 Mar 2022 22:31 #236459
by P1-Engineering
Was wondering if there is an Excel file available somewhere which gives you the overview of all the pinouts?.
Think this would help tremendously when building the configuration and starting the wiring.
When building my first controller with Eding CNC I made such an overview, but that was a fairly simple, straight forward, configuration.
With all the possibilites LinuxCNC offers it gets complicated a lot quicker and would like to build the config and the wiring first time right.
If this is not available I would also like to know, because then I will put one together myself and make it available.
General wiring hookups can also be an option in a later stage.
05 Mar 2022 22:39 #236461
by Grotius
Replied by Grotius on topic Excel file for building the configuration, pinouts etc. ?
I think there is none. For every type "mesa, ethercat, parport" etc. it differs.
If you do the config wizzard, your generated output will contain a .hal file. This hal file shows the connections.
You could consider this .hal file as a basis to construct your excel template file.
The following user(s) said Thank You: P1-Engineering
05 Mar 2022 22:42 #236462
by john_f
Replied by john_f on topic Excel file for building the configuration, pinouts etc. ?
I like that idea. Would you consider Libraoffice Calc. instead for those that don't have excel.
05 Mar 2022 23:09 #236467
by Grotius
Libreoffice excel is common used with linux as it is free. So you can just provide a slogan like : sudo apt-get instal libreoffice-excel.
when you are ready to post the file. Users can then just copy past your instruction.
- Thank you received: 6007
05 Mar 2022 23:45 #236468
Replied by tommylight on topic Excel file for building the configuration, pinouts etc. ?
libreoffice-calc
that is the official name of the exel in Linux.
And the package to install is:
sudo apt-get install libreoffice
That will also install the rest of the office suit.
06 Mar 2022 00:09 #236469
Replied by rodw on topic Excel file for building the configuration, pinouts etc. ?
I started by making a table of inputs and outputs. I updated the table before I added a new pin.
Over time, I added a number of other tables for stepper wiring colours etc. Its all in there.
- P1-Engineering
07 Mar 2022 22:52 #236612
by P1-Engineering
Replied by P1-Engineering on topic Excel file for building the configuration, pinouts etc. ?
Ok, I will check what comes out of the configuration!.
- P1-Engineering
07 Mar 2022 22:57 #236613
by P1-Engineering
Linux for me, currently, is only to run the CNC's and 3D printers.
I will check it out, but I'm quite experienced in Excel so if Libraoffice has a very different workflow I will probably not invest the time.I like that idea. Would you consider Libraoffice Calc. instead for those that don't have excel.
07 Apr 2022 05:07 #239500
by tray
Replied by tray on topic Excel file for building the configuration, pinouts etc. ?
Libre Calc is similar to excel, with a similar workflow/interface.
Some math functions are different but similar.
The attached file, I created in Libre Calc, and then zipped for attaching to the forum message.
Time to create page: 0.179 seconds
