Motors Pulse Not Jogging
30 Mar 2022 16:59 #238753
by Riggorous
Motors Pulse Not Jogging was created by Riggorous
Hey all,
Setting up a new machine, and I cannot get the motors to jog. Both when using pnconf to test or trying to run linuxcnc app they do the same thing. Essentially they are pulsing, they will spin a little but will not jog with the machine. And they only pulse in one direction. Any thoughts? I have tried playing with the settings and nothing seems to make any difference. I am beginning to think it is a wiring error.
Hardware:
Mesa 7i76e
All Drives are Gecko 201x
Main axis motors are nema 34 and z axis is nema 23
This is not my first build, previously had this machine and computer running using DM drivers and recently upgraded to geckos. Trying to set up the new drives and am running in to this problem. Any thoughts? I have the drives wired step -, dir -, and common from all the connectors per a connection sheet I found here.
Hardware:
Mesa 7i76e
- Thank you received: 6006
30 Mar 2022 17:35 #238762
Replied by tommylight on topic Motors Pulse Not Jogging
How are the drives wired to Mesa?
Mesa has differential outputs for step/dir, while Gecko most probably has single ended inputs.
Also make sure the step and dir are wired to their respective place.
30 Mar 2022 18:00 #238771
by Riggorous
Replied by Riggorous on topic Motors Pulse Not Jogging
I have them wired as such.
Mesa TB2 Pin 2(step -) goes to Gecko Pin 9(step)
Mesa TB2 Pin 4(dir -) goes to Gecko Pin 8(dir)
MEsa TB2 Pin 6(+5vp) goes to Gecko Pin 10(Common)
I tried mesa pin 1(gnd) to gecko pin 10 and got no movement or pulse from the motor at all.
30 Mar 2022 18:06 #238773
That seems OK, so set the step time and step space to at least 5000 and test again.
30 Mar 2022 18:07 #238774
by Riggorous
And for more amplifying information, when i say the motors are pulsing, they are basically doing 1 step with 1 click of the button. Holding the +/- button on the app or the testing panel results in one step only. Multiple clicks will result in multiple steps.
30 Mar 2022 18:13 #238778
That usually is due to dir pin on the Mesa going to step pin on the Gecko.
30 Mar 2022 18:15 #238779
by Riggorous
Tried everything from 5000 up to 10000 and no change in behavior.
30 Mar 2022 18:22 #238780
Replied by PCW on topic Motors Pulse Not Jogging
As tommylight said, just getting one step on jog press
or reversals suggests that step/dir are swapped
30 Mar 2022 18:52 #238792
by Riggorous
Yeah...in a very emabarrasing answer to the problem here. I wrote down, and was fully convinced that was how I wired it. It was how I intended to wire it, but I opened up my box and sure enough step/dri were reversed on all plugs. Must of fat fingered it when installing the drives. Fixed the wiring and it works great now, thank you for the help in diagnosing a silly little problem
30 Mar 2022 20:16 #238816
Replied by andypugh on topic Motors Pulse Not Jogging
You might be less embarassed if you consider why so many people immediately thought of that possibilityYeah...in a very emabarrasing answer to the problem here.
Time to create page: 0.403 seconds
