Cant get servo motors to move during configuration
- 42walrustitan
03 Jul 2022 21:19 #246540
by 42walrustitan
Cant get servo motors to move during configuration was created by 42walrustitan
I am a total novice when it come to building and setting up CNC machines. I am trying to set up a CNC router which uses servo motors run by GECKO 320 drives. I am using a Mesa 5i25 card connected to a Mesa 7i76 card to do this. My problem is that during the setup phase I can not get the servo motors to move when using the axis test function of pncconf. I don't know where I should start in trying to fix this. Any help would be appreciated.
- Thank you received: 6006
03 Jul 2022 21:39 #246541
Replied by tommylight on topic Cant get servo motors to move during configuration
Did you wire the ERR pin on the Gecko to +5V encoder power?
Or did you wire it to be enabled by LinuxCNC?
In any case, make a config that roughly fits your machine, save, then start LinuxCNC, you can edit a lot of stuff while LinuxCNC is running using the "Calibration" from the "machine" menu.
- 42walrustitan
03 Jul 2022 22:10 #246544
by 42walrustitan
Replied by 42walrustitan on topic Cant get servo motors to move during configuration
The Drives are enabling correctly and not showing any faults. When i try to run the confiuration it crashes and gives me this error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/shoppc/linuxcnc/configs/K2'
Machine configuration file is 'K2.ini'
INIFILE=/home/shoppc/linuxcnc/configs/K2/K2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./K2.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=7329
Debug file information:
./K2.hal:52: parameter or pin 'hm2_5i25.0.stepgen.00.dirsetup' not found
7329
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d400 (usable)
[ 0.000000] BIOS-e820: 000000000009d400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000009dff000 (usable)
[ 0.000000] BIOS-e820: 0000000009dff000 - 000000000a000000 (reserved)
[ 0.000000] BIOS-e820: 000000000a000000 - 000000000a200000 (usable)
[ 0.000000] BIOS-e820: 000000000a200000 - 000000000a20b000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000000a20b000 - 000000000b000000 (usable)
[ 0.000000] BIOS-e820: 000000000b000000 - 000000000b020000 (reserved)
[ 0.000000] BIOS-e820: 000000000b020000 - 000000004a35e000 (usable)
[ 0.000000] BIOS-e820: 000000004a35e000 - 000000004a636000 (reserved)
[ 0.000000] BIOS-e820: 000000004a636000 - 000000004a673000 (ACPI data)
[ 0.000000] BIOS-e820: 000000004a673000 - 000000004ad59000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000004ad59000 - 000000004bbff000 (reserved)
[ 0.000000] BIOS-e820: 000000004bbff000 - 000000004d000000 (usable)
[ 0.000000] BIOS-e820: 000000004d000000 - 00000000d0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fd100000 - 00000000fd200000 (reserved)
[ 0.000000] BIOS-e820: 00000000fea00000 - 00000000fea10000 (reserved)
[ 0.000000] BIOS-e820: 00000000feb80000 - 00000000fec02000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec10000 - 00000000fec11000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec30000 - 00000000fec31000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed40000 - 00000000fed45000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed80000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fedc2000 - 00000000fedd0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fedd4000 - 00000000fedd6000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000022f340000 (usable)
[ 0.000000] BIOS-e820: 000000022f340000 - 0000000230000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 3.3 present.
[ 0.000000] DMI: ASUS System Product Name/Pro B550M-C, BIOS 1401 12/03/2020
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x4d000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000230000000 aka 8960M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36414000 - 37202000
[ 0.000000] ACPI: RSDP 000f05b0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 4a671728 000C4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.000000] ACPI: FACP 4a665000 00114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI Warning: FADT (revision 6) is longer than ACPI 5.0 version, truncating length 276 to 268 (20120320/tbfadt-294)
[ 0.000000] ACPI: DSDT 4a659000 0BA55 (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 4ad3e000 00040
[ 0.000000] ACPI: SSDT 4a66b000 05419 (v02 AMD Artic 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 4a667000 03AAF (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a666000 000C5 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.000000] ACPI: FIDT 4a658000 0009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 4a642000 00044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.000000] ACPI: MCFG 4a656000 0003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: ASF! 4a655000 00074 (v32 INTEL D865GCH 00000001 TFSM 000F4240)
[ 0.000000] ACPI: HPET 4a654000 00038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: TPM2 4a651000 0004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.000000] ACPI: IVRS 4a650000 000D0 (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 4a64f000 008F4 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 4a64e000 00490 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 4a64d000 00029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 4a64c000 00D53 (v01 AMD ArticIG2 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a64a000 010AC (v01 AMD ArticTPX 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a646000 0381A (v01 AMD ArticN 00000001 INTL 20120913)
[ 0.000000] ACPI: WSMT 4a645000 00028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: APIC 4a644000 0015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 4a643000 000BF (v01 AMD AmdTable 00001000 INTL 20120913)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 344MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0004d000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00009dff
[ 0.000000] 0: 0x0000a000 -> 0x0000a200
[ 0.000000] 0: 0x0000a20b -> 0x0000b000
[ 0.000000] 0: 0x0000b020 -> 0x0004a35e
[ 0.000000] 0: 0x0004bbff -> 0x0004d000
[ 0.000000] On node 0 totalpages: 308416
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5a74200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220930 pages, LIFO batch:31
[ 0.000000] HighMem zone: 689 pages used for memmap
[ 0.000000] HighMem zone: 81072 pages, LIFO batch:15
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x11] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x12] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x13] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x14] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x15] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x16] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x17] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x18] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x19] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x05] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x06] address[0xfec01000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 6, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] 32 Processors exceeds NR_CPUS limit of 8
[ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 72
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000009dff000 - 000000000a000000
[ 0.000000] PM: Registered nosave memory: 000000000a200000 - 000000000a20b000
[ 0.000000] PM: Registered nosave memory: 000000000b000000 - 000000000b020000
[ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:20000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f776d000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 305951
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e25ba44e-ecd0-41d2-92a7-808d15b5def3 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 2523008 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0004d000)
[ 0.000000] Memory: 1199840k/1261568k available (3495k kernel code, 33824k reserved, 1237k data, 416k init, 327044k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:1288 16
[ 0.000000] CPU 0 irqstacks, hard=f5408000 soft=f540a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3193.897 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6387.79 BogoMIPS (lpj=12775588)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.000027] Security Framework initialized
[ 0.000030] AppArmor: AppArmor disabled by boot time parameter
[ 0.000039] Mount-cache hash table entries: 512
[ 0.000151] Initializing cgroup subsys cpuacct
[ 0.000152] Initializing cgroup subsys memory
[ 0.000156] Initializing cgroup subsys devices
[ 0.000157] Initializing cgroup subsys freezer
[ 0.000158] Initializing cgroup subsys net_cls
[ 0.000159] Initializing cgroup subsys blkio
[ 0.000163] Initializing cgroup subsys perf_event
[ 0.000179] CPU: Physical Processor ID: 0
[ 0.000180] CPU: Processor Core ID: 0
[ 0.109187] mce: CPU supports 23 MCE banks
[ 0.109208] LVT offset 1 assigned for vector 0xf9
[ 0.109257] ACPI: Core revision 20120320
[ 0.122001] Enabling APIC mode: Flat. Using 2 I/O APICs
[ 0.123250] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.162860] CPU0: AMD Athlon 200GE with Radeon Vega Graphics stepping 00
[ 0.270419] Performance Events: no PMU driver, software events only.
[ 0.282401] NMI watchdog: disabled (cpu0): hardware events not enabled
[ 0.294389] CPU 1 irqstacks, hard=f54b6000 soft=f54b8000
[ 0.294390] Booting Node 0, Processors #1
[ 0.304351] Initializing CPU#1
[ 0.414721] NMI watchdog: disabled (cpu1): hardware events not enabled
[ 0.422159] CPU 2 irqstacks, hard=f54c8000 soft=f54ca000
[ 0.422160] #2
[ 0.432098] Initializing CPU#2
[ 0.542517] NMI watchdog: disabled (cpu2): hardware events not enabled
[ 0.549972] CPU 3 irqstacks, hard=f54fc000 soft=f54fe000
[ 0.549976] #3
[ 0.559913] Initializing CPU#3
[ 0.670369] NMI watchdog: disabled (cpu3): hardware events not enabled
[ 0.670394] Brought up 4 CPUs
[ 0.670396] Total of 4 processors activated (25551.17 BogoMIPS).
[ 0.670987] devtmpfs: initialized
[ 0.671140] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20afff] (45056 bytes)
[ 0.671143] PM: Registering ACPI NVS region [mem 0x4a673000-0x4ad58fff] (7233536 bytes)
[ 0.671314] dummy:
[ 0.671356] NET: Registered protocol family 16
[ 0.671576] ACPI: bus type pci registered
[ 0.671626] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.671629] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.671630] PCI: Using MMCONFIG for extended config space
[ 0.671631] PCI: Using configuration type 1 for base access
[ 0.672080] bio: create slab <bio-0> at 0
[ 0.672171] ACPI: Added _OSI(Module Device)
[ 0.672173] ACPI: Added _OSI(Processor Device)
[ 0.672174] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.672176] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.674031] ACPI: EC: Look up EC in DSDT
[ 0.676119] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.680674] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.682264] ACPI: Interpreter enabled
[ 0.682268] ACPI: (supports S0 S3 S4 S5)
[ 0.682286] ACPI: Using IOAPIC for interrupt routing
[ 0.682960] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 0.688313] ACPI: No dock devices found.
[ 0.688317] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.688565] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.688819] pci_root PNP0A08:00: host bridge window [io 0x0000-0x03af]
[ 0.688821] pci_root PNP0A08:00: host bridge window [io 0x03e0-0x0cf7]
[ 0.688823] pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df]
[ 0.688824] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.688826] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.688828] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.688829] pci_root PNP0A08:00: host bridge window [mem 0xd0000000-0xfec2ffff]
[ 0.688831] pci_root PNP0A08:00: host bridge window [mem 0xfee00000-0xffffffff]
[ 0.688853] PCI host bridge to bus 0000:00
[ 0.688854] pci_bus 0000:00: root bus resource [io 0x0000-0x03af]
[ 0.688856] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7]
[ 0.688857] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df]
[ 0.688859] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.688860] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.688861] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.688863] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfec2ffff]
[ 0.688865] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff]
[ 0.688874] pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
[ 0.688939] pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
[ 0.689062] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.689122] pci 0000:00:01.2: [1022:15d3] type 01 class 0x060400
[ 0.689185] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.689235] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.689295] pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
[ 0.689361] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.689424] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.689542] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.689665] pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
[ 0.689678] pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
[ 0.689691] pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
[ 0.689704] pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
[ 0.689716] pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
[ 0.689729] pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
[ 0.689742] pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
[ 0.689755] pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
[ 0.689846] pci 0000:01:00.0: [1022:43ee] type 00 class 0x0c0330
[ 0.689866] pci 0000:01:00.0: reg 10: [mem 0xfcfa0000-0xfcfa7fff 64bit]
[ 0.689942] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.689979] pci 0000:01:00.1: [1022:43eb] type 00 class 0x010601
[ 0.690038] pci 0000:01:00.1: reg 24: [mem 0xfcf80000-0xfcf9ffff]
[ 0.690048] pci 0000:01:00.1: reg 30: [mem 0xfcf00000-0xfcf7ffff pref]
[ 0.690079] pci 0000:01:00.1: PME# supported from D3hot D3cold
[ 0.690111] pci 0000:01:00.2: [1022:43e9] type 01 class 0x060400
[ 0.690187] pci 0000:01:00.2: PME# supported from D3hot D3cold
[ 0.698262] pci 0000:00:01.2: PCI bridge to [bus 01-09]
[ 0.698269] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.698273] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcffffff]
[ 0.698354] pci 0000:02:00.0: [1022:43ea] type 01 class 0x060400
[ 0.698438] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.698481] pci 0000:02:02.0: [1022:43ea] type 01 class 0x060400
[ 0.698565] pci 0000:02:02.0: PME# supported from D3hot D3cold
[ 0.698605] pci 0000:02:03.0: [1022:43ea] type 01 class 0x060400
[ 0.698686] pci 0000:02:03.0: PME# supported from D3hot D3cold
[ 0.698727] pci 0000:02:04.0: [1022:43ea] type 01 class 0x060400
[ 0.698808] pci 0000:02:04.0: PME# supported from D3hot D3cold
[ 0.698855] pci 0000:02:08.0: [1022:43ea] type 01 class 0x060400
[ 0.698936] pci 0000:02:08.0: PME# supported from D3hot D3cold
[ 0.698979] pci 0000:02:09.0: [1022:43ea] type 01 class 0x060400
[ 0.699061] pci 0000:02:09.0: PME# supported from D3hot D3cold
[ 0.699117] pci 0000:01:00.2: PCI bridge to [bus 02-09]
[ 0.699123] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.699127] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.699221] pci 0000:03:00.0: [168c:002a] type 00 class 0x028000
[ 0.699257] pci 0000:03:00.0: reg 10: [mem 0xfce00000-0xfce0ffff 64bit]
[ 0.699401] pci 0000:03:00.0: supports D1
[ 0.699402] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[ 0.699450] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.699462] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.699471] pci 0000:02:00.0: bridge window [mem 0xfce00000-0xfcefffff]
[ 0.699567] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060400
[ 0.699718] pci 0000:04:00.0: supports D1 D2
[ 0.699720] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.706248] pci 0000:02:02.0: PCI bridge to [bus 04-05]
[ 0.706258] pci 0000:02:02.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.706388] pci 0000:05:00.0: [2718:5125] type 00 class 0x110000
[ 0.706418] pci 0000:05:00.0: reg 10: [mem 0xfcd00000-0xfcd0ffff]
[ 0.706645] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.706662] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.706748] pci 0000:02:03.0: PCI bridge to [bus 06-06]
[ 0.706822] pci 0000:02:04.0: PCI bridge to [bus 07-07]
[ 0.706897] pci 0000:02:08.0: PCI bridge to [bus 08-08]
[ 0.707000] pci 0000:09:00.0: [10ec:8168] type 00 class 0x020000
[ 0.707026] pci 0000:09:00.0: reg 10: [io 0xf000-0xf0ff]
[ 0.707071] pci 0000:09:00.0: reg 18: [mem 0xfcc04000-0xfcc04fff 64bit]
[ 0.707098] pci 0000:09:00.0: reg 20: [mem 0xfcc00000-0xfcc03fff 64bit]
[ 0.707172] pci 0000:09:00.0: supports D1 D2
[ 0.707174] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.714238] pci 0000:02:09.0: PCI bridge to [bus 09-09]
[ 0.714245] pci 0000:02:09.0: bridge window [io 0xf000-0xffff]
[ 0.714249] pci 0000:02:09.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.714378] pci 0000:0a:00.0: [1002:15dd] type 00 class 0x030000
[ 0.714403] pci 0000:0a:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.714422] pci 0000:0a:00.0: reg 18: [mem 0xe0000000-0xe01fffff 64bit pref]
[ 0.714435] pci 0000:0a:00.0: reg 20: [io 0xe000-0xe0ff]
[ 0.714448] pci 0000:0a:00.0: reg 24: [mem 0xfcb00000-0xfcb7ffff]
[ 0.714503] pci 0000:0a:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.714569] pci 0000:0a:00.1: [1002:15de] type 00 class 0x040300
[ 0.714586] pci 0000:0a:00.1: reg 10: [mem 0xfcb88000-0xfcb8bfff]
[ 0.714693] pci 0000:0a:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.714734] pci 0000:0a:00.2: [1022:15df] type 00 class 0x108000
[ 0.714774] pci 0000:0a:00.2: reg 18: [mem 0xfca00000-0xfcafffff]
[ 0.714808] pci 0000:0a:00.2: reg 24: [mem 0xfcb8c000-0xfcb8dfff]
[ 0.714902] pci 0000:0a:00.3: [1022:15e0] type 00 class 0x0c0330
[ 0.714926] pci 0000:0a:00.3: reg 10: [mem 0xfc900000-0xfc9fffff 64bit]
[ 0.715024] pci 0000:0a:00.3: PME# supported from D0 D3hot D3cold
[ 0.715068] pci 0000:0a:00.4: [1022:15e1] type 00 class 0x0c0330
[ 0.715092] pci 0000:0a:00.4: reg 10: [mem 0xfc800000-0xfc8fffff 64bit]
[ 0.715190] pci 0000:0a:00.4: PME# supported from D0 D3hot D3cold
[ 0.715235] pci 0000:0a:00.6: [1022:15e3] type 00 class 0x040300
[ 0.715253] pci 0000:0a:00.6: reg 10: [mem 0xfcb80000-0xfcb87fff]
[ 0.715359] pci 0000:0a:00.6: PME# supported from D0 D3hot D3cold
[ 0.715434] pci 0000:00:08.1: PCI bridge to [bus 0a-0a]
[ 0.715441] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.715445] pci 0000:00:08.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.715451] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.715465] pci_bus 0000:00: on NUMA node 0
[ 0.715467] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.715539] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.GP17._PRT]
[ 0.715607] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.GPP1._PRT]
[ 0.715838] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.721102] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721147] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721184] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721233] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721275] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721307] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721340] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721372] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721464] vgaarb: device added: PCI:0000:0a:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.721467] vgaarb: loaded
[ 0.721468] vgaarb: bridge control possible 0000:0a:00.0
[ 0.721487] PCI: Using ACPI for IRQ routing
[ 0.727830] PCI: pci_cache_line_size set to 64 bytes
[ 0.727961] reserve RAM buffer: 000000000009d400 - 000000000009ffff
[ 0.727962] reserve RAM buffer: 0000000009dff000 - 000000000bffffff
[ 0.727964] reserve RAM buffer: 000000000a200000 - 000000000bffffff
[ 0.727965] reserve RAM buffer: 000000000b000000 - 000000000bffffff
[ 0.727967] reserve RAM buffer: 000000004a35e000 - 000000004bffffff
[ 0.727968] reserve RAM buffer: 000000004d000000 - 000000004fffffff
[ 0.728053] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.728056] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.730081] Switching to clocksource hpet
[ 0.730164] pnp: PnP ACPI init
[ 0.730171] ACPI: bus type pnp registered
[ 0.730351] pnp 00:00: [bus 00-ff]
[ 0.730353] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.730354] pnp 00:00: [io 0x0000-0x03af window]
[ 0.730356] pnp 00:00: [io 0x03e0-0x0cf7 window]
[ 0.730357] pnp 00:00: [io 0x03b0-0x03df window]
[ 0.730358] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.730359] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.730361] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.730362] pnp 00:00: [mem 0xd0000000-0xfec2ffff window]
[ 0.730363] pnp 00:00: [mem 0xfee00000-0xffffffff window]
[ 0.730365] pnp 00:00: [mem 0x00000000 window]
[ 0.730394] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.730420] pnp 00:01: [mem 0xf0000000-0xf7ffffff]
[ 0.730445] system 00:01: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.730447] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.730452] pnp 00:02: [mem 0xfeb80000-0xfebfffff]
[ 0.730475] system 00:02: [mem 0xfeb80000-0xfebfffff] has been reserved
[ 0.730476] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730502] pnp 00:03: [mem 0x50000000-0xcfffffff window]
[ 0.730531] system 00:03: [mem 0x50000000-0xcfffffff window] has been reserved
[ 0.730532] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730608] pnp 00:04: [mem 0xfd100000-0xfd1fffff]
[ 0.730638] system 00:04: [mem 0xfd100000-0xfd1fffff] has been reserved
[ 0.730640] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730681] pnp 00:05: [dma 4]
[ 0.730682] pnp 00:05: [io 0x0000-0x000f]
[ 0.730684] pnp 00:05: [io 0x0081-0x0083]
[ 0.730685] pnp 00:05: [io 0x0087]
[ 0.730686] pnp 00:05: [io 0x0089-0x008b]
[ 0.730687] pnp 00:05: [io 0x008f]
[ 0.730688] pnp 00:05: [io 0x00c0-0x00df]
[ 0.730705] pnp 00:05: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.730727] pnp 00:06: [io 0x0070-0x0071]
[ 0.730744] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.730749] pnp 00:07: [io 0x0061]
[ 0.730768] pnp 00:07: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.730845] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730846] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730848] pnp 00:08: [io 0x0290-0x029f]
[ 0.730849] pnp 00:08: [io 0x0200-0x021f]
[ 0.730850] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730887] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.730889] system 00:08: [io 0x0200-0x021f] has been reserved
[ 0.730891] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.731225] pnp 00:09: [io 0x0378-0x037f]
[ 0.731234] pnp 00:09: [irq 5]
[ 0.731236] pnp 00:09: [dma 0 disabled]
[ 0.731348] pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.731592] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.731599] pnp 00:0a: [irq 4]
[ 0.731601] pnp 00:0a: [dma 0 disabled]
[ 0.731635] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.731786] pnp 00:0b: [io 0x0010-0x001f]
[ 0.731788] pnp 00:0b: [io 0x0022-0x003f]
[ 0.731789] pnp 00:0b: [io 0x0063]
[ 0.731790] pnp 00:0b: [io 0x0065]
[ 0.731791] pnp 00:0b: [io 0x0067-0x006f]
[ 0.731792] pnp 00:0b: [io 0x0072-0x007f]
[ 0.731793] pnp 00:0b: [io 0x0080]
[ 0.731794] pnp 00:0b: [io 0x0084-0x0086]
[ 0.731795] pnp 00:0b: [io 0x0088]
[ 0.731796] pnp 00:0b: [io 0x008c-0x008e]
[ 0.731797] pnp 00:0b: [io 0x0090-0x009f]
[ 0.731798] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.731799] pnp 00:0b: [io 0x00b1]
[ 0.731801] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.731802] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.731803] pnp 00:0b: [io 0x040b]
[ 0.731804] pnp 00:0b: [io 0x04d6]
[ 0.731805] pnp 00:0b: [io 0x0c00-0x0c01]
[ 0.731806] pnp 00:0b: [io 0x0c14]
[ 0.731807] pnp 00:0b: [io 0x0c50-0x0c51]
[ 0.731808] pnp 00:0b: [io 0x0c52]
[ 0.731809] pnp 00:0b: [io 0x0c6c]
[ 0.731810] pnp 00:0b: [io 0x0c6f]
[ 0.731811] pnp 00:0b: [io 0x0cd8-0x0cdf]
[ 0.731812] pnp 00:0b: [io 0x0800-0x089f]
[ 0.731813] pnp 00:0b: [io 0x0b00-0x0b0f]
[ 0.731814] pnp 00:0b: [io 0x0b20-0x0b3f]
[ 0.731815] pnp 00:0b: [io 0x0900-0x090f]
[ 0.731816] pnp 00:0b: [io 0x0910-0x091f]
[ 0.731818] pnp 00:0b: [io 0x0060-0x005f disabled]
[ 0.731819] pnp 00:0b: [io 0x0064-0x0063 disabled]
[ 0.731820] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.731821] pnp 00:0b: [mem 0xfec01000-0xfec01fff]
[ 0.731823] pnp 00:0b: [mem 0xfedc0000-0xfedc0fff]
[ 0.731824] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.731825] pnp 00:0b: [mem 0xfed80000-0xfed8ffff]
[ 0.731826] pnp 00:0b: [mem 0xfec10000-0xfec10fff]
[ 0.731827] pnp 00:0b: [mem 0x00000000-0xffffffff disabled]
[ 0.731828] pnp 00:0b: [mem 0xff000000-0xffffffff]
[ 0.731884] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.731886] system 00:0b: [io 0x040b] has been reserved
[ 0.731887] system 00:0b: [io 0x04d6] has been reserved
[ 0.731889] system 00:0b: [io 0x0c00-0x0c01] has been reserved
[ 0.731890] system 00:0b: [io 0x0c14] has been reserved
[ 0.731892] system 00:0b: [io 0x0c50-0x0c51] has been reserved
[ 0.731893] system 00:0b: [io 0x0c52] has been reserved
[ 0.731895] system 00:0b: [io 0x0c6c] has been reserved
[ 0.731896] system 00:0b: [io 0x0c6f] has been reserved
[ 0.731897] system 00:0b: [io 0x0cd8-0x0cdf] has been reserved
[ 0.731899] system 00:0b: [io 0x0800-0x089f] has been reserved
[ 0.731901] system 00:0b: [io 0x0b00-0x0b0f] has been reserved
[ 0.731902] system 00:0b: [io 0x0b20-0x0b3f] has been reserved
[ 0.731903] system 00:0b: [io 0x0900-0x090f] has been reserved
[ 0.731905] system 00:0b: [io 0x0910-0x091f] has been reserved
[ 0.731907] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.731909] system 00:0b: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.731910] system 00:0b: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.731912] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.731913] system 00:0b: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.731915] system 00:0b: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.731917] system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
[ 0.731918] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.732536] pnp 00:0c: [irq 0 disabled]
[ 0.732544] pnp 00:0c: [irq 8]
[ 0.732545] pnp 00:0c: [mem 0xfed00000-0xfed003ff]
[ 0.732574] pnp 00:0c: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.732584] pnp: PnP ACPI: found 13 devices
[ 0.732585] ACPI: ACPI bus type pnp unregistered
[ 0.732587] PnPBIOS: Disabled by ACPI PNP
[ 0.769251] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.769256] pci 0000:02:00.0: bridge window [mem 0xfce00000-0xfcefffff]
[ 0.769266] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.769275] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.769291] pci 0000:02:02.0: PCI bridge to [bus 04-05]
[ 0.769296] pci 0000:02:02.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.769305] pci 0000:02:03.0: PCI bridge to [bus 06-06]
[ 0.769318] pci 0000:02:04.0: PCI bridge to [bus 07-07]
[ 0.769331] pci 0000:02:08.0: PCI bridge to [bus 08-08]
[ 0.769344] pci 0000:02:09.0: PCI bridge to [bus 09-09]
[ 0.769347] pci 0000:02:09.0: bridge window [io 0xf000-0xffff]
[ 0.769352] pci 0000:02:09.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.769361] pci 0000:01:00.2: PCI bridge to [bus 02-09]
[ 0.769364] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.769369] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.769378] pci 0000:00:01.2: PCI bridge to [bus 01-09]
[ 0.769380] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.769385] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcffffff]
[ 0.769394] pci 0000:00:08.1: PCI bridge to [bus 0a-0a]
[ 0.769397] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.769401] pci 0000:00:08.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.769405] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.769513] pci_bus 0000:00: resource 4 [io 0x0000-0x03af]
[ 0.769514] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7]
[ 0.769516] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df]
[ 0.769517] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff]
[ 0.769518] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff]
[ 0.769520] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff]
[ 0.769521] pci_bus 0000:00: resource 10 [mem 0xd0000000-0xfec2ffff]
[ 0.769522] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff]
[ 0.769524] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.769525] pci_bus 0000:01: resource 1 [mem 0xfcc00000-0xfcffffff]
[ 0.769526] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.769528] pci_bus 0000:02: resource 1 [mem 0xfcc00000-0xfcefffff]
[ 0.769529] pci_bus 0000:03: resource 1 [mem 0xfce00000-0xfcefffff]
[ 0.769530] pci_bus 0000:04: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.769532] pci_bus 0000:05: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.769533] pci_bus 0000:09: resource 0 [io 0xf000-0xffff]
[ 0.769535] pci_bus 0000:09: resource 1 [mem 0xfcc00000-0xfccfffff]
[ 0.769536] pci_bus 0000:0a: resource 0 [io 0xe000-0xefff]
[ 0.769537] pci_bus 0000:0a: resource 1 [mem 0xfc800000-0xfcbfffff]
[ 0.769539] pci_bus 0000:0a: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.769651] NET: Registered protocol family 2
[ 0.769785] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.770018] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.770152] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.770223] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.770224] TCP: reno registered
[ 0.770226] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.770229] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.770328] NET: Registered protocol family 1
[ 0.770427] pci 0000:0a:00.0: Boot video device
[ 0.770827] PCI: CLS 64 bytes, default 64
[ 0.770853] Unpacking initramfs...
[ 0.969223] Freeing initrd memory: 14264k freed
[ 0.971765] audit: initializing netlink socket (disabled)
[ 0.971778] type=2000 audit(1656755094.864:1): initialized
[ 0.980864] highmem bounce pool size: 64 pages
[ 0.980871] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.981291] VFS: Disk quotas dquot_6.5.2
[ 0.981329] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.981420] msgmni has been set to 1732
[ 0.981698] alg: No test for stdrng (krng)
[ 0.981781] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.981797] io scheduler noop registered
[ 0.981801] io scheduler deadline registered
[ 0.981825] io scheduler cfq registered (default)
[ 0.982389] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.982400] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.982402] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.982887] GHES: HEST is not enabled!
[ 0.982895] isapnp: Scanning for PnP cards...
[ 1.343286] isapnp: No Plug & Play device found
[ 1.343328] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.364049] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.385120] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.386560] Linux agpgart interface v0.103
[ 1.386671] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.389539] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.389548] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.389702] mousedev: PS/2 mouse device common for all mice
[ 1.389743] rtc_cmos 00:06: RTC can wake from S4
[ 1.389952] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.390012] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.390445] TCP: cubic registered
[ 1.390545] NET: Registered protocol family 10
[ 1.390903] Mobile IPv6
[ 1.390906] NET: Registered protocol family 17
[ 1.390911] Registering the dns_resolver key type
[ 1.390979] Using IPI No-Shortcut mode
[ 1.391122] PM: Hibernation image not present or could not be loaded.
[ 1.391133] registered taskstats version 1
[ 1.392263] rtc_cmos 00:06: setting system clock to 2022-07-02 09:44:55 UTC (1656755095)
[ 1.392541] Freeing unused kernel memory: 416k freed
[ 1.392654] Write protecting the kernel text: 3496k
[ 1.392673] Write protecting the kernel read-only data: 984k
[ 1.401950] udevd[58]: starting version 175
[ 1.421017] SCSI subsystem initialized
[ 1.423291] libata version 3.00 loaded.
[ 1.423819] ahci 0000:01:00.1: version 3.0
[ 1.423896] ahci: SSS flag set, parallel bus scan disabled
[ 1.423960] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.423964] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs apst
[ 1.425126] scsi0 : ahci
[ 1.426769] scsi1 : ahci
[ 1.427698] usbcore: registered new interface driver usbfs
[ 1.427716] usbcore: registered new interface driver hub
[ 1.427895] scsi2 : ahci
[ 1.429782] scsi3 : ahci
[ 1.429859] usbcore: registered new device driver usb
[ 1.430350] scsi4 : ahci
[ 1.430576] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.430635] r8169 0000:09:00.0: (unregistered net_device): unknown MAC, using family default
[ 1.430924] r8169 0000:09:00.0: eth0: RTL8168b/8111b at 0xf8032000, f0:2f:74:b2:f0:71, XID 14100800 IRQ 29
[ 1.430928] r8169 0000:09:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.431586] scsi5 : ahci
[ 1.431640] ata1: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80100 irq 29
[ 1.431650] ata2: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80180 irq 29
[ 1.431654] ata3: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80200 irq 29
[ 1.431658] ata4: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80280 irq 29
[ 1.431661] ata5: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80300 irq 29
[ 1.431664] ata6: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80380 irq 29
[ 1.431740] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.431760] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.442166] microcode: CPU0: patch_level=0x08101016
[ 1.454909] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.455108] microcode: CPU1: patch_level=0x08101016
[ 1.456462] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.456677] microcode: CPU2: patch_level=0x08101016
[ 1.458475] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.458682] microcode: CPU3: patch_level=0x08101016
[ 1.460235] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.460451] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.486769] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.486771] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.486773] usb usb1: Product: xHCI Host Controller
[ 1.486775] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.486776] usb usb1: SerialNumber: 0000:01:00.0
[ 1.486850] xHCI xhci_add_endpoint called for root hub
[ 1.486851] xHCI xhci_check_bandwidth called for root hub
[ 1.486869] hub 1-0:1.0: USB hub found
[ 1.486884] hub 1-0:1.0: 10 ports detected
[ 1.487046] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.487051] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.487125] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.487127] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.487128] usb usb2: Product: xHCI Host Controller
[ 1.487129] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.487130] usb usb2: SerialNumber: 0000:01:00.0
[ 1.487186] xHCI xhci_add_endpoint called for root hub
[ 1.487187] xHCI xhci_check_bandwidth called for root hub
[ 1.487202] hub 2-0:1.0: USB hub found
[ 1.487209] hub 2-0:1.0: 4 ports detected
[ 1.487466] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.487476] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 3
[ 1.487732] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.487734] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.487736] usb usb3: Product: xHCI Host Controller
[ 1.487737] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.487739] usb usb3: SerialNumber: 0000:0a:00.3
[ 1.487812] xHCI xhci_add_endpoint called for root hub
[ 1.487815] xHCI xhci_check_bandwidth called for root hub
[ 1.487851] hub 3-0:1.0: USB hub found
[ 1.487861] hub 3-0:1.0: 4 ports detected
[ 1.488177] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.488183] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 4
[ 1.488231] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.488233] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.488235] usb usb4: Product: xHCI Host Controller
[ 1.488236] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.488238] usb usb4: SerialNumber: 0000:0a:00.3
[ 1.488326] xHCI xhci_add_endpoint called for root hub
[ 1.488328] xHCI xhci_check_bandwidth called for root hub
[ 1.488360] hub 4-0:1.0: USB hub found
[ 1.488369] hub 4-0:1.0: 4 ports detected
[ 1.489619] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[ 1.489626] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 5
[ 1.489874] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.489876] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.489878] usb usb5: Product: xHCI Host Controller
[ 1.489879] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.489881] usb usb5: SerialNumber: 0000:0a:00.4
[ 1.489963] xHCI xhci_add_endpoint called for root hub
[ 1.489965] xHCI xhci_check_bandwidth called for root hub
[ 1.489984] hub 5-0:1.0: USB hub found
[ 1.489988] hub 5-0:1.0: 1 port detected
[ 1.490035] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[ 1.490039] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 6
[ 1.490066] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.490068] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.490070] usb usb6: Product: xHCI Host Controller
[ 1.490072] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.490073] usb usb6: SerialNumber: 0000:0a:00.4
[ 1.490138] xHCI xhci_add_endpoint called for root hub
[ 1.490139] xHCI xhci_check_bandwidth called for root hub
[ 1.490159] hub 6-0:1.0: USB hub found
[ 1.490163] hub 6-0:1.0: 1 port detected
[ 1.852301] usb 1-7: new low-speed USB device number 2 using xhci_hcd
[ 1.946375] usb 1-7: New USB device found, idVendor=0461, idProduct=4d22
[ 1.946379] usb 1-7: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.946381] usb 1-7: Product: USB Optical Mouse
[ 1.946517] usb 1-7: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.968106] Refined TSC clocksource calibration: 3193.979 MHz.
[ 1.968115] Switching to clocksource tsc
[ 1.976079] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.007248] ata1.00: ATA-8: TOSHIBA MQ01ABD050V, AX0D1Q, max UDMA/100
[ 2.007254] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.009001] ata1.00: configured for UDMA/100
[ 2.009140] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD0 AX0D PQ: 0 ANSI: 5
[ 2.115915] usb 1-8: new low-speed USB device number 3 using xhci_hcd
[ 2.276749] usb 1-8: New USB device found, idVendor=1a2c, idProduct=0021
[ 2.276755] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.276758] usb 1-8: Product: USB Keykoard
[ 2.276761] usb 1-8: Manufacturer: USB
[ 2.276932] usb 1-8: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.276939] usb 1-8: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.327422] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.646947] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.966194] ata4: SATA link down (SStatus 0 SControl 300)
[ 3.992273] ata5: failed to resume link (SControl 0)
[ 3.992293] ata5: SATA link down (SStatus 0 SControl 0)
[ 5.018523] ata6: failed to resume link (SControl 0)
[ 5.018542] ata6: SATA link down (SStatus 0 SControl 0)
[ 5.023238] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 5.023242] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 5.023289] sd 0:0:0:0: [sda] Write Protect is off
[ 5.023293] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.023314] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.034423] input: USB Optical Mouse as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-7/1-7:1.0/input/input0
[ 5.034548] generic-usb 0003:0461:4D22.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:01:00.0-7/input0
[ 5.045461] input: USB USB Keykoard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.0/input/input1
[ 5.045538] generic-usb 0003:1A2C:0021.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:01:00.0-8/input0
[ 5.143652] sda: sda1 sda2 < sda5 >
[ 5.144144] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.145577] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 15.039611] generic-usb 0003:1A2C:0021.0003: usb_submit_urb(ctrl) failed: -1
[ 15.039810] generic-usb 0003:1A2C:0021.0003: timeout initializing reports
[ 15.039945] input: USB USB Keykoard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.1/input/input2
[ 15.040050] generic-usb 0003:1A2C:0021.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:01:00.0-8/input1
[ 15.040079] usbcore: registered new interface driver usbhid
[ 15.040082] usbhid: USB HID core driver
[ 20.127531] PM: Starting manual resume from disk
[ 20.127535] PM: Hibernation image partition 8:5 present
[ 20.127536] PM: Looking for hibernation image.
[ 20.160163] PM: Image not found (code -22)
[ 20.160166] PM: Hibernation image not present or could not be loaded.
[ 20.260432] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 23.285703] udevd[432]: starting version 175
[ 23.587515] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 23.587519] ACPI: Power Button [PWRB]
[ 23.587567] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 23.587570] ACPI: Power Button [PWRF]
[ 24.127554] wmi: Mapper loaded
[ 24.964160] parport_pc 00:09: reported by Plug and Play ACPI
[ 24.964242] parport0: PC-style at 0x378, irq 5 [PCSPP]
[ 24.982365] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input5
[ 24.982426] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input6
[ 24.982476] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input7
[ 24.982714] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 25.039449] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input8
[ 25.039514] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input9
[ 25.039574] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input10
[ 25.039634] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input11
[ 25.039687] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input12
[ 25.050963] asus_wmi: ASUS WMI generic driver loaded
[ 25.052949] asus_wmi: Initialization: 0x0
[ 25.052971] asus_wmi: BIOS WMI version: 0.9
[ 25.053091] asus_wmi: SFUN value: 0x0
[ 25.053341] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input13
[ 25.183997] cfg80211: Calling CRDA to update world regulatory domain
[ 26.023381] ath: EEPROM regdomain: 0x60
[ 26.023383] ath: EEPROM indicates we should expect a direct regpair map
[ 26.023385] ath: Country alpha2 being used: 00
[ 26.023386] ath: Regpair used: 0x60
[ 26.121616] cfg80211: World regulatory domain updated:
[ 26.121618] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 26.121621] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.121623] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.121624] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.121626] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121628] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121629] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 26.121631] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121632] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 26.150077] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 26.150294] Registered led device: ath9k-phy0
[ 26.150297] ieee80211 phy0: Atheros AR9280 Rev:2 mem=0xf8600000, irq=28
[ 28.059460] Adding 12400636k swap on /dev/sda5. Priority:-1 extents:1 across:12400636k
[ 28.070029] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 28.517975] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 28.647711] loop: module loaded
[ 29.934125] RPC: Registered named UNIX socket transport module.
[ 29.934128] RPC: Registered udp transport module.
[ 29.934129] RPC: Registered tcp transport module.
[ 29.934131] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 30.034289] FS-Cache: Loaded
[ 30.074754] NFS: Registering the id_resolver key type
[ 30.074819] FS-Cache: Netfs 'nfs' registered for caching
[ 30.079966] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 32.273047] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 34.203425] Bluetooth: Core ver 2.16
[ 34.203443] NET: Registered protocol family 31
[ 34.203445] Bluetooth: HCI device and connection manager initialized
[ 34.203448] Bluetooth: HCI socket layer initialized
[ 34.203450] Bluetooth: L2CAP socket layer initialized
[ 34.203455] Bluetooth: SCO socket layer initialized
[ 34.417282] Bluetooth: RFCOMM TTY layer initialized
[ 34.417289] Bluetooth: RFCOMM socket layer initialized
[ 34.417292] Bluetooth: RFCOMM ver 1.11
[ 34.581849] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 34.581853] Bluetooth: BNEP filters: protocol multicast
[ 35.202195] lp0: using parport0 (interrupt-driven).
[ 35.463014] ppdev: user-space parallel port driver
[ 37.698404] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 37.709297] r8169 0000:09:00.0: eth0: link down
[ 37.709524] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 46.285635] wlan0: authenticate with 3c:37:86:62:59:f2
[ 46.299060] wlan0: send auth to 3c:37:86:62:59:f2 (try 1/3)
[ 46.301475] wlan0: authenticated
[ 46.312168] wlan0: associate with 3c:37:86:62:59:f2 (try 1/3)
[ 46.316111] wlan0: RX AssocResp from 3c:37:86:62:59:f2 (capab=0x1411 status=0 aid=9)
[ 46.323493] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 46.323547] wlan0: associated
[ 46.323576] cfg80211: Calling CRDA for country: US
[ 46.326279] ath: regdomain 0x8348 updated by CountryIE
[ 46.326281] ath: EEPROM regdomain: 0x8348
[ 46.326282] ath: EEPROM indicates we should expect a country code
[ 46.326284] ath: doing EEPROM country->regdmn map search
[ 46.326285] ath: country maps to regdmn code: 0x3a
[ 46.326286] ath: Country alpha2 being used: US
[ 46.326287] ath: Regpair used: 0x3a
[ 46.326351] cfg80211: Regulatory domain changed to country: US
[ 46.326355] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 46.326360] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 46.326364] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 46.326368] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 46.326377] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[ 46.326379] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 46.326380] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 57.028238] wlan0: no IPv6 routers present
[ 109.165293] I-pipe: head domain RTAI registered.
[ 109.165297] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 109.165405] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 109.165410] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[ 109.165413] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 109.165416] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 444250
[ 109.193096] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 109.193131] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 109.193135] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[ 109.193137] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[ 109.193139] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 109.212880] RTAI[math]: loaded.
[ 672.181845] RTAI[math]: unloaded.
[ 672.182799] SCHED releases registered named ALIEN PEDV$D
[ 672.185552] RTAI[malloc]: unloaded.
[ 672.284192] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 672.285871] I-pipe: head domain RTAI unregistered.
[ 672.285961] RTAI[hal]: unmounted.
[25485.967458] I-pipe: head domain RTAI registered.
[25485.967463] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[25485.967561] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[25485.967564] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[25485.967566] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[25485.967569] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1143750
[25486.039530] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[25486.039562] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[25486.039565] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[25486.039568] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[25486.039569] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[25486.092531] RTAI[math]: loaded.
[25486.993735] hm2: loading Mesa HostMot2 driver version 0.15
[25487.026604] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[25487.026641] hm2_pci: discovered 5i25 at 0000:05:00.0
[25487.027053] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[25487.029385] hm2/hm2_5i25.0: 34 I/O Pins used:
[25487.029387] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[25487.029388] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[25487.029390] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[25487.029392] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[25487.029393] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[25487.029394] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[25487.029396] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[25487.029398] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[25487.029400] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[25487.029402] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[25487.029404] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[25487.029406] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[25487.029407] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[25487.029409] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[25487.029410] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[25487.029411] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[25487.029413] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[25487.029414] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[25487.029416] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[25487.029417] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[25487.029418] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[25487.029420] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[25487.029421] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[25487.029422] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[25487.029424] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[25487.029425] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[25487.029426] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[25487.029428] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[25487.029429] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[25487.029430] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[25487.029432] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[25487.029433] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[25487.029434] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[25487.029436] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[25487.029481] hm2/hm2_5i25.0: registered
[25487.029482] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[25516.303208] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[25516.303214] hm2/hm2_5i25.0: unregistered
[25516.303271] hm2_pci: driver unloaded
[25516.306784] hm2: unloading
[25516.337805] RTAI[math]: unloaded.
[25516.338849] SCHED releases registered named ALIEN PEDV$D
[25516.340656] RTAI[malloc]: unloaded.
[25516.440147] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[25516.441821] I-pipe: head domain RTAI unregistered.
[25516.441935] RTAI[hal]: unmounted.
[96685.431057] I-pipe: head domain RTAI registered.
[96685.431062] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[96685.431149] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[96685.431153] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[96685.431155] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[96685.431158] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1538000
[96685.434783] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[96685.434807] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[96685.434810] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[96685.434812] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[96685.434813] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[96685.438862] RTAI[math]: loaded.
[97116.946018] RTAI[math]: unloaded.
[97116.947054] SCHED releases registered named ALIEN PEDV$D
[97116.949482] RTAI[malloc]: unloaded.
[97117.046676] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97117.048084] I-pipe: head domain RTAI unregistered.
[97117.048197] RTAI[hal]: unmounted.
[97245.657308] I-pipe: head domain RTAI registered.
[97245.657313] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97245.657388] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97245.657391] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97245.657393] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97245.657394] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1548000
[97245.660988] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97245.661014] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97245.661017] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97245.661019] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97245.661020] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97245.666586] RTAI[math]: loaded.
[97245.686584] config string '0 out'
[97335.632082] RTAI[math]: unloaded.
[97335.633166] SCHED releases registered named ALIEN PEDV$D
[97335.634953] RTAI[malloc]: unloaded.
[97335.734456] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97335.735943] I-pipe: head domain RTAI unregistered.
[97335.736066] RTAI[hal]: unmounted.
[97395.695972] I-pipe: head domain RTAI registered.
[97395.695975] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97395.696062] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97395.696066] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97395.696068] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97395.696070] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1557250
[97395.700165] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97395.700189] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97395.700191] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97395.700193] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97395.700195] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97395.705500] RTAI[math]: loaded.
[97395.720963] hm2: loading Mesa HostMot2 driver version 0.15
[97395.722165] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97395.722197] hm2_pci: discovered 5i25 at 0000:05:00.0
[97395.722616] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97395.724818] hm2/hm2_5i25.0: 34 I/O Pins used:
[97395.724821] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97395.724822] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97395.724824] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97395.724826] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97395.724827] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97395.724828] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97395.724829] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97395.724831] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97395.724833] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97395.724835] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97395.724837] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97395.724838] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97395.724839] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97395.724841] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97395.724842] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97395.724843] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97395.724844] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97395.724845] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97395.724846] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97395.724848] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97395.724849] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97395.724850] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97395.724851] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97395.724853] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97395.724854] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97395.724855] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97395.724856] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97395.724858] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97395.724859] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97395.724860] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97395.724861] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97395.724862] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97395.724864] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97395.724865] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97395.724901] hm2/hm2_5i25.0: registered
[97395.724902] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[97414.942438] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[97414.942443] hm2/hm2_5i25.0: unregistered
[97414.942487] hm2_pci: driver unloaded
[97414.943783] hm2: unloading
[97414.974250] RTAI[math]: unloaded.
[97414.975403] SCHED releases registered named ALIEN PEDV$D
[97414.977830] RTAI[malloc]: unloaded.
[97415.076893] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97415.078379] I-pipe: head domain RTAI unregistered.
[97415.078493] RTAI[hal]: unmounted.
[97467.779811] I-pipe: head domain RTAI registered.
[97467.779973] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97467.780048] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97467.780051] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97467.780054] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97467.780057] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1541500
[97467.784360] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97467.784387] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97467.784390] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97467.784392] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97467.784393] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97467.787974] RTAI[math]: loaded.
[97467.953828] hm2: loading Mesa HostMot2 driver version 0.15
[97467.955039] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97467.955156] hm2_pci: discovered 5i25 at 0000:05:00.0
[97467.955574] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97467.957667] hm2/hm2_5i25.0: 34 I/O Pins used:
[97467.957670] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97467.957672] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97467.957673] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97467.957675] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97467.957676] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97467.957677] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97467.957679] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97467.957681] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97467.957683] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97467.957684] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97467.957686] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97467.957687] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97467.957689] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97467.957690] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97467.957691] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97467.957692] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97467.957693] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97467.957695] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97467.957696] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97467.957697] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97467.957698] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97467.957699] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97467.957700] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97467.957702] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97467.957703] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97467.957704] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97467.957705] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97467.957706] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97467.957708] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97467.957709] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97467.957710] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97467.957711] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97467.957712] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97467.957713] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97467.957749] hm2/hm2_5i25.0: registered
[97467.957751] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[97477.808592] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[97477.808601] hm2/hm2_5i25.0: unregistered
[97477.808658] hm2_pci: driver unloaded
[97477.809816] hm2: unloading
[97477.840875] RTAI[math]: unloaded.
[97477.841940] SCHED releases registered named ALIEN PEDV$D
[97477.845198] RTAI[malloc]: unloaded.
[97477.942394] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97477.943951] I-pipe: head domain RTAI unregistered.
[97477.944065] RTAI[hal]: unmounted.
[97490.949285] I-pipe: head domain RTAI registered.
[97490.949290] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97490.949349] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97490.949352] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97490.949354] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97490.949357] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1447250
[97490.953648] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97490.953674] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97490.953677] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97490.953679] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97490.953680] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97490.961563] RTAI[math]: loaded.
[97490.976875] hm2: loading Mesa HostMot2 driver version 0.15
[97490.978068] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97490.978109] hm2_pci: discovered 5i25 at 0000:05:00.0
[97490.978529] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97490.980717] hm2/hm2_5i25.0: 34 I/O Pins used:
[97490.980720] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97490.980721] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97490.980723] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97490.980724] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97490.980725] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97490.980727] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97490.980728] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97490.980730] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97490.980732] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97490.980733] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97490.980735] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97490.980737] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97490.980738] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97490.980739] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97490.980741] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97490.980742] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97490.980743] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97490.980744] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97490.980745] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97490.980747] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97490.980748] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97490.980749] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97490.980750] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97490.980751] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97490.980753] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97490.980754] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97490.980755] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97490.980756] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97490.980758] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97490.980759] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97490.980760] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97490.980761] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97490.980762] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97490.980763] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97490.980799] hm2/hm2_5i25.0: registered
[97490.980800] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99042.486509] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99042.486514] hm2/hm2_5i25.0: unregistered
[99042.486551] hm2_pci: driver unloaded
[99042.487838] hm2: unloading
[99042.593516] RTAI[math]: unloaded.
[99042.594669] SCHED releases registered named ALIEN PEDV$D
[99042.596577] RTAI[malloc]: unloaded.
[99042.692789] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99042.694399] I-pipe: head domain RTAI unregistered.
[99042.694517] RTAI[hal]: unmounted.
[99348.481854] I-pipe: head domain RTAI registered.
[99348.481859] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99348.481932] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99348.481935] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99348.481938] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99348.481941] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1520500
[99348.486293] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99348.486319] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99348.486321] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99348.486323] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99348.486325] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99348.490454] RTAI[math]: loaded.
[99348.501390] config string '0 out'
[99356.968398] spurious APIC interrupt on CPU#2, should never happen.
[99356.968401] spurious APIC interrupt on CPU#3, should never happen.
[99356.968404] spurious APIC interrupt on CPU#0, should never happen.
[99356.970582] RTAI[math]: unloaded.
[99356.971658] SCHED releases registered named ALIEN PEDV$D
[99356.974379] RTAI[malloc]: unloaded.
[99357.072427] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99357.074131] I-pipe: head domain RTAI unregistered.
[99357.074245] RTAI[hal]: unmounted.
[99419.687448] I-pipe: head domain RTAI registered.
[99419.687451] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99419.687523] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99419.687525] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99419.687527] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99419.687529] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1236250
[99419.691370] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99419.691396] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99419.691399] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99419.691401] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99419.691402] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99419.696075] RTAI[math]: loaded.
[99419.710961] hm2: loading Mesa HostMot2 driver version 0.15
[99419.712164] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99419.712197] hm2_pci: discovered 5i25 at 0000:05:00.0
[99419.712602] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99419.714714] hm2/hm2_5i25.0: 34 I/O Pins used:
[99419.714715] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99419.714717] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99419.714718] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99419.714719] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99419.714720] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99419.714722] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99419.714723] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99419.714725] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99419.714727] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99419.714728] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99419.714730] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99419.714731] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99419.714732] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99419.714733] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99419.714735] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99419.714736] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99419.714737] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99419.714738] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99419.714739] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99419.714740] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99419.714741] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99419.714742] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99419.714743] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99419.714744] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99419.714746] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99419.714747] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99419.714748] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99419.714749] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99419.714750] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99419.714751] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99419.714752] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99419.714753] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99419.714754] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99419.714755] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99419.714791] hm2/hm2_5i25.0: registered
[99419.714793] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99494.630147] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99494.630152] hm2/hm2_5i25.0: unregistered
[99494.630193] hm2_pci: driver unloaded
[99494.631416] hm2: unloading
[99494.664151] RTAI[math]: unloaded.
[99494.665196] SCHED releases registered named ALIEN PEDV$D
[99494.667680] RTAI[malloc]: unloaded.
[99494.764584] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99494.766234] I-pipe: head domain RTAI unregistered.
[99494.766350] RTAI[hal]: unmounted.
[99628.853538] I-pipe: head domain RTAI registered.
[99628.853542] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99628.853624] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99628.853627] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99628.853629] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99628.853631] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1405250
[99628.858328] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99628.858355] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99628.858357] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99628.858359] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99628.858361] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99628.863584] RTAI[math]: loaded.
[99629.005763] hm2: loading Mesa HostMot2 driver version 0.15
[99629.006997] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99629.007033] hm2_pci: discovered 5i25 at 0000:05:00.0
[99629.007466] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99629.009821] hm2/hm2_5i25.0: 34 I/O Pins used:
[99629.009823] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99629.009824] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99629.009826] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99629.009827] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99629.009828] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99629.009829] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99629.009831] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99629.009832] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99629.009834] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99629.009836] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99629.009837] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99629.009839] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99629.009840] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99629.009841] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99629.009842] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99629.009843] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99629.009844] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99629.009845] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99629.009847] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99629.009848] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99629.009849] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99629.009850] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99629.009851] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99629.009852] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99629.009853] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99629.009854] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99629.009855] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99629.009857] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99629.009858] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99629.009859] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99629.009860] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99629.009861] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99629.009862] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99629.009863] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99629.009905] hm2/hm2_5i25.0: registered
[99629.009906] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99629.011027] config string '0 out'
[99629.388632] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99629.388637] hm2/hm2_5i25.0: unregistered
[99629.388668] hm2_pci: driver unloaded
[99629.389659] hm2: unloading
[99631.487805] RTAI[math]: unloaded.
[99631.489066] SCHED releases registered named ALIEN PEDV$D
[99631.490425] RTAI[malloc]: unloaded.
[99631.586703] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99631.588550] I-pipe: head domain RTAI unregistered.
[99631.588668] RTAI[hal]: unmounted.
[99649.133862] I-pipe: head domain RTAI registered.
[99649.133866] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99649.133945] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99649.133947] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99649.133949] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99649.133951] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1557250
[99649.137657] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99649.137689] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99649.137692] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99649.137695] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99649.137698] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99649.141872] RTAI[math]: loaded.
[99649.285488] hm2: loading Mesa HostMot2 driver version 0.15
[99649.286605] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99649.286644] hm2_pci: discovered 5i25 at 0000:05:00.0
[99649.287079] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99649.289290] hm2/hm2_5i25.0: 34 I/O Pins used:
[99649.289292] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99649.289294] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99649.289295] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99649.289296] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99649.289298] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99649.289299] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99649.289300] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99649.289302] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99649.289303] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99649.289305] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99649.289307] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99649.289308] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99649.289309] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99649.289310] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99649.289311] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99649.289313] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99649.289314] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99649.289315] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99649.289316] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99649.289317] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99649.289318] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99649.289319] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99649.289320] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99649.289321] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99649.289323] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99649.289324] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99649.289325] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99649.289326] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99649.289327] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99649.289328] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99649.289329] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99649.289330] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99649.289331] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99649.289332] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99649.289374] hm2/hm2_5i25.0: registered
[99649.289375] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99649.290415] config string '0 out'
[99649.421447] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99649.421452] hm2/hm2_5i25.0: unregistered
[99649.421484] hm2_pci: driver unloaded
[99649.422499] hm2: unloading
[99651.488335] RTAI[math]: unloaded.
[99651.489623] SCHED releases registered named ALIEN PEDV$D
[99651.492804] RTAI[malloc]: unloaded.
[99651.589010] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99651.591046] I-pipe: head domain RTAI unregistered.
[99651.591174] RTAI[hal]: unmounted.
[100837.588736] I-pipe: head domain RTAI registered.
[100837.588740] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[100837.588810] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[100837.588812] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[100837.588814] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[100837.588816] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1387000
[100837.593908] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[100837.593935] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[100837.593938] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[100837.593940] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[100837.593941] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[100837.599800] RTAI[math]: loaded.
[100837.615588] hm2: loading Mesa HostMot2 driver version 0.15
[100837.616822] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[100837.616855] hm2_pci: discovered 5i25 at 0000:05:00.0
[100837.617272] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[100837.619326] hm2/hm2_5i25.0: 34 I/O Pins used:
[100837.619328] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[100837.619330] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[100837.619331] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[100837.619333] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[100837.619334] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[100837.619335] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[100837.619337] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[100837.619339] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[100837.619341] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[100837.619343] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[100837.619344] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[100837.619346] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[100837.619347] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[100837.619348] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[100837.619349] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[100837.619351] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[100837.619352] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[100837.619353] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[100837.619354] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[100837.619356] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[100837.619357] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[100837.619358] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[100837.619359] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[100837.619363] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[100837.619367] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[100837.619368] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[100837.619369] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[100837.619370] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[100837.619372] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[100837.619373] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[100837.619374] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[100837.619375] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[100837.619376] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[100837.619377] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[100837.619425] hm2/hm2_5i25.0: registered
[100837.619427] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[101040.681142] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[101040.681153] hm2/hm2_5i25.0: unregistered
[101040.681618] hm2_pci: driver unloaded
[101040.684289] hm2: unloading
[101040.716775] RTAI[math]: unloaded.
[101040.717846] SCHED releases registered named ALIEN PEDV$D
[101040.721163] RTAI[malloc]: unloaded.
[101040.818249] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[101040.820071] I-pipe: head domain RTAI unregistered.
[101040.820193] RTAI[hal]: unmounted.
[101108.237826] I-pipe: head domain RTAI registered.
[101108.237829] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[101108.237919] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[101108.237922] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[101108.237924] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[101108.237927] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1215000
[101108.241593] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[101108.241618] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[101108.241621] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[101108.241623] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[101108.241624] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[101108.246492] RTAI[math]: loaded.
[101108.256826] config string '0 out'
[101216.272928] RTAI[math]: unloaded.
[101216.273999] SCHED releases registered named ALIEN PEDV$D
[101216.276612] RTAI[malloc]: unloaded.
[101216.375301] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[101216.376779] I-pipe: head domain RTAI unregistered.
[101216.376893] RTAI[hal]: unmounted.
[102115.465707] I-pipe: head domain RTAI registered.
[102115.465710] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[102115.465794] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[102115.465796] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[102115.465798] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[102115.465800] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1544750
[102115.470283] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[102115.470312] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[102115.470315] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[102115.470317] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[102115.470318] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[102115.479558] RTAI[math]: loaded.
[102115.494619] hm2: loading Mesa HostMot2 driver version 0.15
[102115.495783] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[102115.495818] hm2_pci: discovered 5i25 at 0000:05:00.0
[102115.496221] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[102115.498322] hm2/hm2_5i25.0: 34 I/O Pins used:
[102115.498325] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[102115.498327] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[102115.498328] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[102115.498330] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[102115.498331] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[102115.498332] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[102115.498334] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[102115.498336] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[102115.498337] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[102115.498339] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[102115.498340] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[102115.498342] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[102115.498343] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[102115.498344] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[102115.498345] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[102115.498346] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[102115.498348] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[102115.498349] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[102115.498350] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[102115.498351] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[102115.498352] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[102115.498353] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[102115.498354] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[102115.498355] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[102115.498356] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[102115.498358] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[102115.498359] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[102115.498360] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[102115.498361] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[102115.498363] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[102115.498364] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[102115.498365] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[102115.498366] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[102115.498367] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[102115.498404] hm2/hm2_5i25.0: registered
[102115.498405] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[102140.145781] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[102140.145787] hm2/hm2_5i25.0: unregistered
[102140.146047] hm2_pci: driver unloaded
[102140.148121] hm2: unloading
[102140.178311] RTAI[math]: unloaded.
[102140.179363] SCHED releases registered named ALIEN PEDV$D
[102140.181618] RTAI[malloc]: unloaded.
[102140.277705] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[102140.279295] I-pipe: head domain RTAI unregistered.
[102140.279415] RTAI[hal]: unmounted.
[105641.519348] I-pipe: head domain RTAI registered.
[105641.519351] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[105641.519429] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[105641.519432] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[105641.519433] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[105641.519435] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1547500
[105641.523412] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[105641.523436] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[105641.523439] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[105641.523441] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[105641.523442] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[105641.527894] RTAI[math]: loaded.
[105641.571033] hm2: loading Mesa HostMot2 driver version 0.15
[105641.572218] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[105641.572253] hm2_pci: discovered 5i25 at 0000:05:00.0
[105641.572691] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[105641.575056] hm2/hm2_5i25.0: 34 I/O Pins used:
[105641.575058] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[105641.575060] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[105641.575061] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[105641.575062] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[105641.575064] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[105641.575065] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[105641.575066] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[105641.575068] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[105641.575069] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[105641.575071] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[105641.575073] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[105641.575074] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[105641.575075] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[105641.575076] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[105641.575077] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[105641.575079] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[105641.575080] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[105641.575081] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[105641.575082] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[105641.575083] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[105641.575084] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[105641.575085] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[105641.575086] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[105641.575087] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[105641.575088] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[105641.575090] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[105641.575091] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[105641.575092] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[105641.575093] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[105641.575094] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[105641.575095] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[105641.575096] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[105641.575097] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[105641.575098] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[105641.575140] hm2/hm2_5i25.0: registered
[105641.575141] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[105641.708588] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[105641.708593] hm2/hm2_5i25.0: unregistered
[105641.708625] hm2_pci: driver unloaded
[105641.709628] hm2: unloading
[105643.775577] RTAI[math]: unloaded.
[105643.776877] SCHED releases registered named ALIEN PEDV$D
[105643.779088] RTAI[malloc]: unloaded.
[105643.877310] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[105643.879041] I-pipe: head domain RTAI unregistered.
[105643.879154] RTAI[hal]: unmounted.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/shoppc/linuxcnc/configs/K2'
Machine configuration file is 'K2.ini'
INIFILE=/home/shoppc/linuxcnc/configs/K2/K2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./K2.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=7329
Debug file information:
./K2.hal:52: parameter or pin 'hm2_5i25.0.stepgen.00.dirsetup' not found
7329
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d400 (usable)
[ 0.000000] BIOS-e820: 000000000009d400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000009dff000 (usable)
[ 0.000000] BIOS-e820: 0000000009dff000 - 000000000a000000 (reserved)
[ 0.000000] BIOS-e820: 000000000a000000 - 000000000a200000 (usable)
[ 0.000000] BIOS-e820: 000000000a200000 - 000000000a20b000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000000a20b000 - 000000000b000000 (usable)
[ 0.000000] BIOS-e820: 000000000b000000 - 000000000b020000 (reserved)
[ 0.000000] BIOS-e820: 000000000b020000 - 000000004a35e000 (usable)
[ 0.000000] BIOS-e820: 000000004a35e000 - 000000004a636000 (reserved)
[ 0.000000] BIOS-e820: 000000004a636000 - 000000004a673000 (ACPI data)
[ 0.000000] BIOS-e820: 000000004a673000 - 000000004ad59000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000004ad59000 - 000000004bbff000 (reserved)
[ 0.000000] BIOS-e820: 000000004bbff000 - 000000004d000000 (usable)
[ 0.000000] BIOS-e820: 000000004d000000 - 00000000d0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fd100000 - 00000000fd200000 (reserved)
[ 0.000000] BIOS-e820: 00000000fea00000 - 00000000fea10000 (reserved)
[ 0.000000] BIOS-e820: 00000000feb80000 - 00000000fec02000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec10000 - 00000000fec11000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec30000 - 00000000fec31000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed40000 - 00000000fed45000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed80000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fedc2000 - 00000000fedd0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fedd4000 - 00000000fedd6000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000022f340000 (usable)
[ 0.000000] BIOS-e820: 000000022f340000 - 0000000230000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 3.3 present.
[ 0.000000] DMI: ASUS System Product Name/Pro B550M-C, BIOS 1401 12/03/2020
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x4d000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000230000000 aka 8960M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36414000 - 37202000
[ 0.000000] ACPI: RSDP 000f05b0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 4a671728 000C4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.000000] ACPI: FACP 4a665000 00114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI Warning: FADT (revision 6) is longer than ACPI 5.0 version, truncating length 276 to 268 (20120320/tbfadt-294)
[ 0.000000] ACPI: DSDT 4a659000 0BA55 (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 4ad3e000 00040
[ 0.000000] ACPI: SSDT 4a66b000 05419 (v02 AMD Artic 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 4a667000 03AAF (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a666000 000C5 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.000000] ACPI: FIDT 4a658000 0009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 4a642000 00044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.000000] ACPI: MCFG 4a656000 0003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: ASF! 4a655000 00074 (v32 INTEL D865GCH 00000001 TFSM 000F4240)
[ 0.000000] ACPI: HPET 4a654000 00038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: TPM2 4a651000 0004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.000000] ACPI: IVRS 4a650000 000D0 (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 4a64f000 008F4 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 4a64e000 00490 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 4a64d000 00029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 4a64c000 00D53 (v01 AMD ArticIG2 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a64a000 010AC (v01 AMD ArticTPX 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 4a646000 0381A (v01 AMD ArticN 00000001 INTL 20120913)
[ 0.000000] ACPI: WSMT 4a645000 00028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: APIC 4a644000 0015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 4a643000 000BF (v01 AMD AmdTable 00001000 INTL 20120913)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 344MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0004d000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00009dff
[ 0.000000] 0: 0x0000a000 -> 0x0000a200
[ 0.000000] 0: 0x0000a20b -> 0x0000b000
[ 0.000000] 0: 0x0000b020 -> 0x0004a35e
[ 0.000000] 0: 0x0004bbff -> 0x0004d000
[ 0.000000] On node 0 totalpages: 308416
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5a74200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220930 pages, LIFO batch:31
[ 0.000000] HighMem zone: 689 pages used for memmap
[ 0.000000] HighMem zone: 81072 pages, LIFO batch:15
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x11] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x12] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x13] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x14] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x15] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x16] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x17] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x18] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x19] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1a] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1b] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1c] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1d] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1e] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x1f] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x05] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x06] address[0xfec01000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 6, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] 32 Processors exceeds NR_CPUS limit of 8
[ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 72
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000009dff000 - 000000000a000000
[ 0.000000] PM: Registered nosave memory: 000000000a200000 - 000000000a20b000
[ 0.000000] PM: Registered nosave memory: 000000000b000000 - 000000000b020000
[ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:20000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f776d000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 305951
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e25ba44e-ecd0-41d2-92a7-808d15b5def3 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 2523008 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0004d000)
[ 0.000000] Memory: 1199840k/1261568k available (3495k kernel code, 33824k reserved, 1237k data, 416k init, 327044k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:1288 16
[ 0.000000] CPU 0 irqstacks, hard=f5408000 soft=f540a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3193.897 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6387.79 BogoMIPS (lpj=12775588)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.000027] Security Framework initialized
[ 0.000030] AppArmor: AppArmor disabled by boot time parameter
[ 0.000039] Mount-cache hash table entries: 512
[ 0.000151] Initializing cgroup subsys cpuacct
[ 0.000152] Initializing cgroup subsys memory
[ 0.000156] Initializing cgroup subsys devices
[ 0.000157] Initializing cgroup subsys freezer
[ 0.000158] Initializing cgroup subsys net_cls
[ 0.000159] Initializing cgroup subsys blkio
[ 0.000163] Initializing cgroup subsys perf_event
[ 0.000179] CPU: Physical Processor ID: 0
[ 0.000180] CPU: Processor Core ID: 0
[ 0.109187] mce: CPU supports 23 MCE banks
[ 0.109208] LVT offset 1 assigned for vector 0xf9
[ 0.109257] ACPI: Core revision 20120320
[ 0.122001] Enabling APIC mode: Flat. Using 2 I/O APICs
[ 0.123250] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.162860] CPU0: AMD Athlon 200GE with Radeon Vega Graphics stepping 00
[ 0.270419] Performance Events: no PMU driver, software events only.
[ 0.282401] NMI watchdog: disabled (cpu0): hardware events not enabled
[ 0.294389] CPU 1 irqstacks, hard=f54b6000 soft=f54b8000
[ 0.294390] Booting Node 0, Processors #1
[ 0.304351] Initializing CPU#1
[ 0.414721] NMI watchdog: disabled (cpu1): hardware events not enabled
[ 0.422159] CPU 2 irqstacks, hard=f54c8000 soft=f54ca000
[ 0.422160] #2
[ 0.432098] Initializing CPU#2
[ 0.542517] NMI watchdog: disabled (cpu2): hardware events not enabled
[ 0.549972] CPU 3 irqstacks, hard=f54fc000 soft=f54fe000
[ 0.549976] #3
[ 0.559913] Initializing CPU#3
[ 0.670369] NMI watchdog: disabled (cpu3): hardware events not enabled
[ 0.670394] Brought up 4 CPUs
[ 0.670396] Total of 4 processors activated (25551.17 BogoMIPS).
[ 0.670987] devtmpfs: initialized
[ 0.671140] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20afff] (45056 bytes)
[ 0.671143] PM: Registering ACPI NVS region [mem 0x4a673000-0x4ad58fff] (7233536 bytes)
[ 0.671314] dummy:
[ 0.671356] NET: Registered protocol family 16
[ 0.671576] ACPI: bus type pci registered
[ 0.671626] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.671629] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.671630] PCI: Using MMCONFIG for extended config space
[ 0.671631] PCI: Using configuration type 1 for base access
[ 0.672080] bio: create slab <bio-0> at 0
[ 0.672171] ACPI: Added _OSI(Module Device)
[ 0.672173] ACPI: Added _OSI(Processor Device)
[ 0.672174] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.672176] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.674031] ACPI: EC: Look up EC in DSDT
[ 0.676119] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.680674] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.682264] ACPI: Interpreter enabled
[ 0.682268] ACPI: (supports S0 S3 S4 S5)
[ 0.682286] ACPI: Using IOAPIC for interrupt routing
[ 0.682960] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 0.688313] ACPI: No dock devices found.
[ 0.688317] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.688565] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.688819] pci_root PNP0A08:00: host bridge window [io 0x0000-0x03af]
[ 0.688821] pci_root PNP0A08:00: host bridge window [io 0x03e0-0x0cf7]
[ 0.688823] pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df]
[ 0.688824] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.688826] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.688828] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.688829] pci_root PNP0A08:00: host bridge window [mem 0xd0000000-0xfec2ffff]
[ 0.688831] pci_root PNP0A08:00: host bridge window [mem 0xfee00000-0xffffffff]
[ 0.688853] PCI host bridge to bus 0000:00
[ 0.688854] pci_bus 0000:00: root bus resource [io 0x0000-0x03af]
[ 0.688856] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7]
[ 0.688857] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df]
[ 0.688859] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.688860] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.688861] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.688863] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfec2ffff]
[ 0.688865] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff]
[ 0.688874] pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
[ 0.688939] pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
[ 0.689062] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.689122] pci 0000:00:01.2: [1022:15d3] type 01 class 0x060400
[ 0.689185] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.689235] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.689295] pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
[ 0.689361] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.689424] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.689542] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.689665] pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
[ 0.689678] pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
[ 0.689691] pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
[ 0.689704] pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
[ 0.689716] pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
[ 0.689729] pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
[ 0.689742] pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
[ 0.689755] pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
[ 0.689846] pci 0000:01:00.0: [1022:43ee] type 00 class 0x0c0330
[ 0.689866] pci 0000:01:00.0: reg 10: [mem 0xfcfa0000-0xfcfa7fff 64bit]
[ 0.689942] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.689979] pci 0000:01:00.1: [1022:43eb] type 00 class 0x010601
[ 0.690038] pci 0000:01:00.1: reg 24: [mem 0xfcf80000-0xfcf9ffff]
[ 0.690048] pci 0000:01:00.1: reg 30: [mem 0xfcf00000-0xfcf7ffff pref]
[ 0.690079] pci 0000:01:00.1: PME# supported from D3hot D3cold
[ 0.690111] pci 0000:01:00.2: [1022:43e9] type 01 class 0x060400
[ 0.690187] pci 0000:01:00.2: PME# supported from D3hot D3cold
[ 0.698262] pci 0000:00:01.2: PCI bridge to [bus 01-09]
[ 0.698269] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.698273] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcffffff]
[ 0.698354] pci 0000:02:00.0: [1022:43ea] type 01 class 0x060400
[ 0.698438] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.698481] pci 0000:02:02.0: [1022:43ea] type 01 class 0x060400
[ 0.698565] pci 0000:02:02.0: PME# supported from D3hot D3cold
[ 0.698605] pci 0000:02:03.0: [1022:43ea] type 01 class 0x060400
[ 0.698686] pci 0000:02:03.0: PME# supported from D3hot D3cold
[ 0.698727] pci 0000:02:04.0: [1022:43ea] type 01 class 0x060400
[ 0.698808] pci 0000:02:04.0: PME# supported from D3hot D3cold
[ 0.698855] pci 0000:02:08.0: [1022:43ea] type 01 class 0x060400
[ 0.698936] pci 0000:02:08.0: PME# supported from D3hot D3cold
[ 0.698979] pci 0000:02:09.0: [1022:43ea] type 01 class 0x060400
[ 0.699061] pci 0000:02:09.0: PME# supported from D3hot D3cold
[ 0.699117] pci 0000:01:00.2: PCI bridge to [bus 02-09]
[ 0.699123] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.699127] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.699221] pci 0000:03:00.0: [168c:002a] type 00 class 0x028000
[ 0.699257] pci 0000:03:00.0: reg 10: [mem 0xfce00000-0xfce0ffff 64bit]
[ 0.699401] pci 0000:03:00.0: supports D1
[ 0.699402] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[ 0.699450] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.699462] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.699471] pci 0000:02:00.0: bridge window [mem 0xfce00000-0xfcefffff]
[ 0.699567] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060400
[ 0.699718] pci 0000:04:00.0: supports D1 D2
[ 0.699720] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.706248] pci 0000:02:02.0: PCI bridge to [bus 04-05]
[ 0.706258] pci 0000:02:02.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.706388] pci 0000:05:00.0: [2718:5125] type 00 class 0x110000
[ 0.706418] pci 0000:05:00.0: reg 10: [mem 0xfcd00000-0xfcd0ffff]
[ 0.706645] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.706662] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.706748] pci 0000:02:03.0: PCI bridge to [bus 06-06]
[ 0.706822] pci 0000:02:04.0: PCI bridge to [bus 07-07]
[ 0.706897] pci 0000:02:08.0: PCI bridge to [bus 08-08]
[ 0.707000] pci 0000:09:00.0: [10ec:8168] type 00 class 0x020000
[ 0.707026] pci 0000:09:00.0: reg 10: [io 0xf000-0xf0ff]
[ 0.707071] pci 0000:09:00.0: reg 18: [mem 0xfcc04000-0xfcc04fff 64bit]
[ 0.707098] pci 0000:09:00.0: reg 20: [mem 0xfcc00000-0xfcc03fff 64bit]
[ 0.707172] pci 0000:09:00.0: supports D1 D2
[ 0.707174] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.714238] pci 0000:02:09.0: PCI bridge to [bus 09-09]
[ 0.714245] pci 0000:02:09.0: bridge window [io 0xf000-0xffff]
[ 0.714249] pci 0000:02:09.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.714378] pci 0000:0a:00.0: [1002:15dd] type 00 class 0x030000
[ 0.714403] pci 0000:0a:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.714422] pci 0000:0a:00.0: reg 18: [mem 0xe0000000-0xe01fffff 64bit pref]
[ 0.714435] pci 0000:0a:00.0: reg 20: [io 0xe000-0xe0ff]
[ 0.714448] pci 0000:0a:00.0: reg 24: [mem 0xfcb00000-0xfcb7ffff]
[ 0.714503] pci 0000:0a:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.714569] pci 0000:0a:00.1: [1002:15de] type 00 class 0x040300
[ 0.714586] pci 0000:0a:00.1: reg 10: [mem 0xfcb88000-0xfcb8bfff]
[ 0.714693] pci 0000:0a:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.714734] pci 0000:0a:00.2: [1022:15df] type 00 class 0x108000
[ 0.714774] pci 0000:0a:00.2: reg 18: [mem 0xfca00000-0xfcafffff]
[ 0.714808] pci 0000:0a:00.2: reg 24: [mem 0xfcb8c000-0xfcb8dfff]
[ 0.714902] pci 0000:0a:00.3: [1022:15e0] type 00 class 0x0c0330
[ 0.714926] pci 0000:0a:00.3: reg 10: [mem 0xfc900000-0xfc9fffff 64bit]
[ 0.715024] pci 0000:0a:00.3: PME# supported from D0 D3hot D3cold
[ 0.715068] pci 0000:0a:00.4: [1022:15e1] type 00 class 0x0c0330
[ 0.715092] pci 0000:0a:00.4: reg 10: [mem 0xfc800000-0xfc8fffff 64bit]
[ 0.715190] pci 0000:0a:00.4: PME# supported from D0 D3hot D3cold
[ 0.715235] pci 0000:0a:00.6: [1022:15e3] type 00 class 0x040300
[ 0.715253] pci 0000:0a:00.6: reg 10: [mem 0xfcb80000-0xfcb87fff]
[ 0.715359] pci 0000:0a:00.6: PME# supported from D0 D3hot D3cold
[ 0.715434] pci 0000:00:08.1: PCI bridge to [bus 0a-0a]
[ 0.715441] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.715445] pci 0000:00:08.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.715451] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.715465] pci_bus 0000:00: on NUMA node 0
[ 0.715467] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.715539] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.GP17._PRT]
[ 0.715607] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.GPP1._PRT]
[ 0.715838] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.721102] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721147] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721184] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721233] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721275] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721307] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721340] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721372] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.721464] vgaarb: device added: PCI:0000:0a:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.721467] vgaarb: loaded
[ 0.721468] vgaarb: bridge control possible 0000:0a:00.0
[ 0.721487] PCI: Using ACPI for IRQ routing
[ 0.727830] PCI: pci_cache_line_size set to 64 bytes
[ 0.727961] reserve RAM buffer: 000000000009d400 - 000000000009ffff
[ 0.727962] reserve RAM buffer: 0000000009dff000 - 000000000bffffff
[ 0.727964] reserve RAM buffer: 000000000a200000 - 000000000bffffff
[ 0.727965] reserve RAM buffer: 000000000b000000 - 000000000bffffff
[ 0.727967] reserve RAM buffer: 000000004a35e000 - 000000004bffffff
[ 0.727968] reserve RAM buffer: 000000004d000000 - 000000004fffffff
[ 0.728053] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.728056] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.730081] Switching to clocksource hpet
[ 0.730164] pnp: PnP ACPI init
[ 0.730171] ACPI: bus type pnp registered
[ 0.730351] pnp 00:00: [bus 00-ff]
[ 0.730353] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.730354] pnp 00:00: [io 0x0000-0x03af window]
[ 0.730356] pnp 00:00: [io 0x03e0-0x0cf7 window]
[ 0.730357] pnp 00:00: [io 0x03b0-0x03df window]
[ 0.730358] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.730359] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.730361] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.730362] pnp 00:00: [mem 0xd0000000-0xfec2ffff window]
[ 0.730363] pnp 00:00: [mem 0xfee00000-0xffffffff window]
[ 0.730365] pnp 00:00: [mem 0x00000000 window]
[ 0.730394] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.730420] pnp 00:01: [mem 0xf0000000-0xf7ffffff]
[ 0.730445] system 00:01: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.730447] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.730452] pnp 00:02: [mem 0xfeb80000-0xfebfffff]
[ 0.730475] system 00:02: [mem 0xfeb80000-0xfebfffff] has been reserved
[ 0.730476] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730502] pnp 00:03: [mem 0x50000000-0xcfffffff window]
[ 0.730531] system 00:03: [mem 0x50000000-0xcfffffff window] has been reserved
[ 0.730532] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730608] pnp 00:04: [mem 0xfd100000-0xfd1fffff]
[ 0.730638] system 00:04: [mem 0xfd100000-0xfd1fffff] has been reserved
[ 0.730640] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.730681] pnp 00:05: [dma 4]
[ 0.730682] pnp 00:05: [io 0x0000-0x000f]
[ 0.730684] pnp 00:05: [io 0x0081-0x0083]
[ 0.730685] pnp 00:05: [io 0x0087]
[ 0.730686] pnp 00:05: [io 0x0089-0x008b]
[ 0.730687] pnp 00:05: [io 0x008f]
[ 0.730688] pnp 00:05: [io 0x00c0-0x00df]
[ 0.730705] pnp 00:05: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.730727] pnp 00:06: [io 0x0070-0x0071]
[ 0.730744] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.730749] pnp 00:07: [io 0x0061]
[ 0.730768] pnp 00:07: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.730845] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730846] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730848] pnp 00:08: [io 0x0290-0x029f]
[ 0.730849] pnp 00:08: [io 0x0200-0x021f]
[ 0.730850] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.730887] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.730889] system 00:08: [io 0x0200-0x021f] has been reserved
[ 0.730891] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.731225] pnp 00:09: [io 0x0378-0x037f]
[ 0.731234] pnp 00:09: [irq 5]
[ 0.731236] pnp 00:09: [dma 0 disabled]
[ 0.731348] pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.731592] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.731599] pnp 00:0a: [irq 4]
[ 0.731601] pnp 00:0a: [dma 0 disabled]
[ 0.731635] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.731786] pnp 00:0b: [io 0x0010-0x001f]
[ 0.731788] pnp 00:0b: [io 0x0022-0x003f]
[ 0.731789] pnp 00:0b: [io 0x0063]
[ 0.731790] pnp 00:0b: [io 0x0065]
[ 0.731791] pnp 00:0b: [io 0x0067-0x006f]
[ 0.731792] pnp 00:0b: [io 0x0072-0x007f]
[ 0.731793] pnp 00:0b: [io 0x0080]
[ 0.731794] pnp 00:0b: [io 0x0084-0x0086]
[ 0.731795] pnp 00:0b: [io 0x0088]
[ 0.731796] pnp 00:0b: [io 0x008c-0x008e]
[ 0.731797] pnp 00:0b: [io 0x0090-0x009f]
[ 0.731798] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.731799] pnp 00:0b: [io 0x00b1]
[ 0.731801] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.731802] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.731803] pnp 00:0b: [io 0x040b]
[ 0.731804] pnp 00:0b: [io 0x04d6]
[ 0.731805] pnp 00:0b: [io 0x0c00-0x0c01]
[ 0.731806] pnp 00:0b: [io 0x0c14]
[ 0.731807] pnp 00:0b: [io 0x0c50-0x0c51]
[ 0.731808] pnp 00:0b: [io 0x0c52]
[ 0.731809] pnp 00:0b: [io 0x0c6c]
[ 0.731810] pnp 00:0b: [io 0x0c6f]
[ 0.731811] pnp 00:0b: [io 0x0cd8-0x0cdf]
[ 0.731812] pnp 00:0b: [io 0x0800-0x089f]
[ 0.731813] pnp 00:0b: [io 0x0b00-0x0b0f]
[ 0.731814] pnp 00:0b: [io 0x0b20-0x0b3f]
[ 0.731815] pnp 00:0b: [io 0x0900-0x090f]
[ 0.731816] pnp 00:0b: [io 0x0910-0x091f]
[ 0.731818] pnp 00:0b: [io 0x0060-0x005f disabled]
[ 0.731819] pnp 00:0b: [io 0x0064-0x0063 disabled]
[ 0.731820] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.731821] pnp 00:0b: [mem 0xfec01000-0xfec01fff]
[ 0.731823] pnp 00:0b: [mem 0xfedc0000-0xfedc0fff]
[ 0.731824] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.731825] pnp 00:0b: [mem 0xfed80000-0xfed8ffff]
[ 0.731826] pnp 00:0b: [mem 0xfec10000-0xfec10fff]
[ 0.731827] pnp 00:0b: [mem 0x00000000-0xffffffff disabled]
[ 0.731828] pnp 00:0b: [mem 0xff000000-0xffffffff]
[ 0.731884] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.731886] system 00:0b: [io 0x040b] has been reserved
[ 0.731887] system 00:0b: [io 0x04d6] has been reserved
[ 0.731889] system 00:0b: [io 0x0c00-0x0c01] has been reserved
[ 0.731890] system 00:0b: [io 0x0c14] has been reserved
[ 0.731892] system 00:0b: [io 0x0c50-0x0c51] has been reserved
[ 0.731893] system 00:0b: [io 0x0c52] has been reserved
[ 0.731895] system 00:0b: [io 0x0c6c] has been reserved
[ 0.731896] system 00:0b: [io 0x0c6f] has been reserved
[ 0.731897] system 00:0b: [io 0x0cd8-0x0cdf] has been reserved
[ 0.731899] system 00:0b: [io 0x0800-0x089f] has been reserved
[ 0.731901] system 00:0b: [io 0x0b00-0x0b0f] has been reserved
[ 0.731902] system 00:0b: [io 0x0b20-0x0b3f] has been reserved
[ 0.731903] system 00:0b: [io 0x0900-0x090f] has been reserved
[ 0.731905] system 00:0b: [io 0x0910-0x091f] has been reserved
[ 0.731907] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.731909] system 00:0b: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.731910] system 00:0b: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.731912] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.731913] system 00:0b: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.731915] system 00:0b: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.731917] system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
[ 0.731918] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.732536] pnp 00:0c: [irq 0 disabled]
[ 0.732544] pnp 00:0c: [irq 8]
[ 0.732545] pnp 00:0c: [mem 0xfed00000-0xfed003ff]
[ 0.732574] pnp 00:0c: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.732584] pnp: PnP ACPI: found 13 devices
[ 0.732585] ACPI: ACPI bus type pnp unregistered
[ 0.732587] PnPBIOS: Disabled by ACPI PNP
[ 0.769251] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.769256] pci 0000:02:00.0: bridge window [mem 0xfce00000-0xfcefffff]
[ 0.769266] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.769275] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.769291] pci 0000:02:02.0: PCI bridge to [bus 04-05]
[ 0.769296] pci 0000:02:02.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.769305] pci 0000:02:03.0: PCI bridge to [bus 06-06]
[ 0.769318] pci 0000:02:04.0: PCI bridge to [bus 07-07]
[ 0.769331] pci 0000:02:08.0: PCI bridge to [bus 08-08]
[ 0.769344] pci 0000:02:09.0: PCI bridge to [bus 09-09]
[ 0.769347] pci 0000:02:09.0: bridge window [io 0xf000-0xffff]
[ 0.769352] pci 0000:02:09.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.769361] pci 0000:01:00.2: PCI bridge to [bus 02-09]
[ 0.769364] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.769369] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.769378] pci 0000:00:01.2: PCI bridge to [bus 01-09]
[ 0.769380] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.769385] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcffffff]
[ 0.769394] pci 0000:00:08.1: PCI bridge to [bus 0a-0a]
[ 0.769397] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.769401] pci 0000:00:08.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.769405] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.769513] pci_bus 0000:00: resource 4 [io 0x0000-0x03af]
[ 0.769514] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7]
[ 0.769516] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df]
[ 0.769517] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff]
[ 0.769518] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff]
[ 0.769520] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff]
[ 0.769521] pci_bus 0000:00: resource 10 [mem 0xd0000000-0xfec2ffff]
[ 0.769522] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff]
[ 0.769524] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.769525] pci_bus 0000:01: resource 1 [mem 0xfcc00000-0xfcffffff]
[ 0.769526] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.769528] pci_bus 0000:02: resource 1 [mem 0xfcc00000-0xfcefffff]
[ 0.769529] pci_bus 0000:03: resource 1 [mem 0xfce00000-0xfcefffff]
[ 0.769530] pci_bus 0000:04: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.769532] pci_bus 0000:05: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.769533] pci_bus 0000:09: resource 0 [io 0xf000-0xffff]
[ 0.769535] pci_bus 0000:09: resource 1 [mem 0xfcc00000-0xfccfffff]
[ 0.769536] pci_bus 0000:0a: resource 0 [io 0xe000-0xefff]
[ 0.769537] pci_bus 0000:0a: resource 1 [mem 0xfc800000-0xfcbfffff]
[ 0.769539] pci_bus 0000:0a: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.769651] NET: Registered protocol family 2
[ 0.769785] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.770018] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.770152] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.770223] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.770224] TCP: reno registered
[ 0.770226] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.770229] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.770328] NET: Registered protocol family 1
[ 0.770427] pci 0000:0a:00.0: Boot video device
[ 0.770827] PCI: CLS 64 bytes, default 64
[ 0.770853] Unpacking initramfs...
[ 0.969223] Freeing initrd memory: 14264k freed
[ 0.971765] audit: initializing netlink socket (disabled)
[ 0.971778] type=2000 audit(1656755094.864:1): initialized
[ 0.980864] highmem bounce pool size: 64 pages
[ 0.980871] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.981291] VFS: Disk quotas dquot_6.5.2
[ 0.981329] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.981420] msgmni has been set to 1732
[ 0.981698] alg: No test for stdrng (krng)
[ 0.981781] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.981797] io scheduler noop registered
[ 0.981801] io scheduler deadline registered
[ 0.981825] io scheduler cfq registered (default)
[ 0.982389] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.982400] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.982402] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.982887] GHES: HEST is not enabled!
[ 0.982895] isapnp: Scanning for PnP cards...
[ 1.343286] isapnp: No Plug & Play device found
[ 1.343328] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.364049] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.385120] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.386560] Linux agpgart interface v0.103
[ 1.386671] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.389539] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.389548] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.389702] mousedev: PS/2 mouse device common for all mice
[ 1.389743] rtc_cmos 00:06: RTC can wake from S4
[ 1.389952] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.390012] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.390445] TCP: cubic registered
[ 1.390545] NET: Registered protocol family 10
[ 1.390903] Mobile IPv6
[ 1.390906] NET: Registered protocol family 17
[ 1.390911] Registering the dns_resolver key type
[ 1.390979] Using IPI No-Shortcut mode
[ 1.391122] PM: Hibernation image not present or could not be loaded.
[ 1.391133] registered taskstats version 1
[ 1.392263] rtc_cmos 00:06: setting system clock to 2022-07-02 09:44:55 UTC (1656755095)
[ 1.392541] Freeing unused kernel memory: 416k freed
[ 1.392654] Write protecting the kernel text: 3496k
[ 1.392673] Write protecting the kernel read-only data: 984k
[ 1.401950] udevd[58]: starting version 175
[ 1.421017] SCSI subsystem initialized
[ 1.423291] libata version 3.00 loaded.
[ 1.423819] ahci 0000:01:00.1: version 3.0
[ 1.423896] ahci: SSS flag set, parallel bus scan disabled
[ 1.423960] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.423964] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs apst
[ 1.425126] scsi0 : ahci
[ 1.426769] scsi1 : ahci
[ 1.427698] usbcore: registered new interface driver usbfs
[ 1.427716] usbcore: registered new interface driver hub
[ 1.427895] scsi2 : ahci
[ 1.429782] scsi3 : ahci
[ 1.429859] usbcore: registered new device driver usb
[ 1.430350] scsi4 : ahci
[ 1.430576] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.430635] r8169 0000:09:00.0: (unregistered net_device): unknown MAC, using family default
[ 1.430924] r8169 0000:09:00.0: eth0: RTL8168b/8111b at 0xf8032000, f0:2f:74:b2:f0:71, XID 14100800 IRQ 29
[ 1.430928] r8169 0000:09:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.431586] scsi5 : ahci
[ 1.431640] ata1: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80100 irq 29
[ 1.431650] ata2: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80180 irq 29
[ 1.431654] ata3: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80200 irq 29
[ 1.431658] ata4: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80280 irq 29
[ 1.431661] ata5: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80300 irq 29
[ 1.431664] ata6: SATA max UDMA/133 abar m131072@0xfcf80000 port 0xfcf80380 irq 29
[ 1.431740] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.431760] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.442166] microcode: CPU0: patch_level=0x08101016
[ 1.454909] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.455108] microcode: CPU1: patch_level=0x08101016
[ 1.456462] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.456677] microcode: CPU2: patch_level=0x08101016
[ 1.458475] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.458682] microcode: CPU3: patch_level=0x08101016
[ 1.460235] microcode: failed to load file amd-ucode/microcode_amd_fam17h.bin
[ 1.460451] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.486769] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.486771] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.486773] usb usb1: Product: xHCI Host Controller
[ 1.486775] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.486776] usb usb1: SerialNumber: 0000:01:00.0
[ 1.486850] xHCI xhci_add_endpoint called for root hub
[ 1.486851] xHCI xhci_check_bandwidth called for root hub
[ 1.486869] hub 1-0:1.0: USB hub found
[ 1.486884] hub 1-0:1.0: 10 ports detected
[ 1.487046] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.487051] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.487125] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.487127] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.487128] usb usb2: Product: xHCI Host Controller
[ 1.487129] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.487130] usb usb2: SerialNumber: 0000:01:00.0
[ 1.487186] xHCI xhci_add_endpoint called for root hub
[ 1.487187] xHCI xhci_check_bandwidth called for root hub
[ 1.487202] hub 2-0:1.0: USB hub found
[ 1.487209] hub 2-0:1.0: 4 ports detected
[ 1.487466] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.487476] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 3
[ 1.487732] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.487734] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.487736] usb usb3: Product: xHCI Host Controller
[ 1.487737] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.487739] usb usb3: SerialNumber: 0000:0a:00.3
[ 1.487812] xHCI xhci_add_endpoint called for root hub
[ 1.487815] xHCI xhci_check_bandwidth called for root hub
[ 1.487851] hub 3-0:1.0: USB hub found
[ 1.487861] hub 3-0:1.0: 4 ports detected
[ 1.488177] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.488183] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 4
[ 1.488231] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.488233] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.488235] usb usb4: Product: xHCI Host Controller
[ 1.488236] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.488238] usb usb4: SerialNumber: 0000:0a:00.3
[ 1.488326] xHCI xhci_add_endpoint called for root hub
[ 1.488328] xHCI xhci_check_bandwidth called for root hub
[ 1.488360] hub 4-0:1.0: USB hub found
[ 1.488369] hub 4-0:1.0: 4 ports detected
[ 1.489619] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[ 1.489626] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 5
[ 1.489874] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.489876] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.489878] usb usb5: Product: xHCI Host Controller
[ 1.489879] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.489881] usb usb5: SerialNumber: 0000:0a:00.4
[ 1.489963] xHCI xhci_add_endpoint called for root hub
[ 1.489965] xHCI xhci_check_bandwidth called for root hub
[ 1.489984] hub 5-0:1.0: USB hub found
[ 1.489988] hub 5-0:1.0: 1 port detected
[ 1.490035] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[ 1.490039] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 6
[ 1.490066] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.490068] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.490070] usb usb6: Product: xHCI Host Controller
[ 1.490072] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.490073] usb usb6: SerialNumber: 0000:0a:00.4
[ 1.490138] xHCI xhci_add_endpoint called for root hub
[ 1.490139] xHCI xhci_check_bandwidth called for root hub
[ 1.490159] hub 6-0:1.0: USB hub found
[ 1.490163] hub 6-0:1.0: 1 port detected
[ 1.852301] usb 1-7: new low-speed USB device number 2 using xhci_hcd
[ 1.946375] usb 1-7: New USB device found, idVendor=0461, idProduct=4d22
[ 1.946379] usb 1-7: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.946381] usb 1-7: Product: USB Optical Mouse
[ 1.946517] usb 1-7: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.968106] Refined TSC clocksource calibration: 3193.979 MHz.
[ 1.968115] Switching to clocksource tsc
[ 1.976079] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.007248] ata1.00: ATA-8: TOSHIBA MQ01ABD050V, AX0D1Q, max UDMA/100
[ 2.007254] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.009001] ata1.00: configured for UDMA/100
[ 2.009140] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD0 AX0D PQ: 0 ANSI: 5
[ 2.115915] usb 1-8: new low-speed USB device number 3 using xhci_hcd
[ 2.276749] usb 1-8: New USB device found, idVendor=1a2c, idProduct=0021
[ 2.276755] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.276758] usb 1-8: Product: USB Keykoard
[ 2.276761] usb 1-8: Manufacturer: USB
[ 2.276932] usb 1-8: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.276939] usb 1-8: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.327422] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.646947] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.966194] ata4: SATA link down (SStatus 0 SControl 300)
[ 3.992273] ata5: failed to resume link (SControl 0)
[ 3.992293] ata5: SATA link down (SStatus 0 SControl 0)
[ 5.018523] ata6: failed to resume link (SControl 0)
[ 5.018542] ata6: SATA link down (SStatus 0 SControl 0)
[ 5.023238] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 5.023242] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 5.023289] sd 0:0:0:0: [sda] Write Protect is off
[ 5.023293] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.023314] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.034423] input: USB Optical Mouse as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-7/1-7:1.0/input/input0
[ 5.034548] generic-usb 0003:0461:4D22.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:01:00.0-7/input0
[ 5.045461] input: USB USB Keykoard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.0/input/input1
[ 5.045538] generic-usb 0003:1A2C:0021.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:01:00.0-8/input0
[ 5.143652] sda: sda1 sda2 < sda5 >
[ 5.144144] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.145577] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 15.039611] generic-usb 0003:1A2C:0021.0003: usb_submit_urb(ctrl) failed: -1
[ 15.039810] generic-usb 0003:1A2C:0021.0003: timeout initializing reports
[ 15.039945] input: USB USB Keykoard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.1/input/input2
[ 15.040050] generic-usb 0003:1A2C:0021.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:01:00.0-8/input1
[ 15.040079] usbcore: registered new interface driver usbhid
[ 15.040082] usbhid: USB HID core driver
[ 20.127531] PM: Starting manual resume from disk
[ 20.127535] PM: Hibernation image partition 8:5 present
[ 20.127536] PM: Looking for hibernation image.
[ 20.160163] PM: Image not found (code -22)
[ 20.160166] PM: Hibernation image not present or could not be loaded.
[ 20.260432] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 23.285703] udevd[432]: starting version 175
[ 23.587515] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 23.587519] ACPI: Power Button [PWRB]
[ 23.587567] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 23.587570] ACPI: Power Button [PWRF]
[ 24.127554] wmi: Mapper loaded
[ 24.964160] parport_pc 00:09: reported by Plug and Play ACPI
[ 24.964242] parport0: PC-style at 0x378, irq 5 [PCSPP]
[ 24.982365] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input5
[ 24.982426] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input6
[ 24.982476] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input7
[ 24.982714] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 25.039449] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input8
[ 25.039514] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input9
[ 25.039574] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input10
[ 25.039634] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input11
[ 25.039687] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input12
[ 25.050963] asus_wmi: ASUS WMI generic driver loaded
[ 25.052949] asus_wmi: Initialization: 0x0
[ 25.052971] asus_wmi: BIOS WMI version: 0.9
[ 25.053091] asus_wmi: SFUN value: 0x0
[ 25.053341] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input13
[ 25.183997] cfg80211: Calling CRDA to update world regulatory domain
[ 26.023381] ath: EEPROM regdomain: 0x60
[ 26.023383] ath: EEPROM indicates we should expect a direct regpair map
[ 26.023385] ath: Country alpha2 being used: 00
[ 26.023386] ath: Regpair used: 0x60
[ 26.121616] cfg80211: World regulatory domain updated:
[ 26.121618] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 26.121621] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.121623] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.121624] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.121626] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121628] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121629] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 26.121631] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.121632] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 26.150077] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 26.150294] Registered led device: ath9k-phy0
[ 26.150297] ieee80211 phy0: Atheros AR9280 Rev:2 mem=0xf8600000, irq=28
[ 28.059460] Adding 12400636k swap on /dev/sda5. Priority:-1 extents:1 across:12400636k
[ 28.070029] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 28.517975] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 28.647711] loop: module loaded
[ 29.934125] RPC: Registered named UNIX socket transport module.
[ 29.934128] RPC: Registered udp transport module.
[ 29.934129] RPC: Registered tcp transport module.
[ 29.934131] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 30.034289] FS-Cache: Loaded
[ 30.074754] NFS: Registering the id_resolver key type
[ 30.074819] FS-Cache: Netfs 'nfs' registered for caching
[ 30.079966] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 32.273047] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 34.203425] Bluetooth: Core ver 2.16
[ 34.203443] NET: Registered protocol family 31
[ 34.203445] Bluetooth: HCI device and connection manager initialized
[ 34.203448] Bluetooth: HCI socket layer initialized
[ 34.203450] Bluetooth: L2CAP socket layer initialized
[ 34.203455] Bluetooth: SCO socket layer initialized
[ 34.417282] Bluetooth: RFCOMM TTY layer initialized
[ 34.417289] Bluetooth: RFCOMM socket layer initialized
[ 34.417292] Bluetooth: RFCOMM ver 1.11
[ 34.581849] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 34.581853] Bluetooth: BNEP filters: protocol multicast
[ 35.202195] lp0: using parport0 (interrupt-driven).
[ 35.463014] ppdev: user-space parallel port driver
[ 37.698404] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 37.709297] r8169 0000:09:00.0: eth0: link down
[ 37.709524] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 46.285635] wlan0: authenticate with 3c:37:86:62:59:f2
[ 46.299060] wlan0: send auth to 3c:37:86:62:59:f2 (try 1/3)
[ 46.301475] wlan0: authenticated
[ 46.312168] wlan0: associate with 3c:37:86:62:59:f2 (try 1/3)
[ 46.316111] wlan0: RX AssocResp from 3c:37:86:62:59:f2 (capab=0x1411 status=0 aid=9)
[ 46.323493] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 46.323547] wlan0: associated
[ 46.323576] cfg80211: Calling CRDA for country: US
[ 46.326279] ath: regdomain 0x8348 updated by CountryIE
[ 46.326281] ath: EEPROM regdomain: 0x8348
[ 46.326282] ath: EEPROM indicates we should expect a country code
[ 46.326284] ath: doing EEPROM country->regdmn map search
[ 46.326285] ath: country maps to regdmn code: 0x3a
[ 46.326286] ath: Country alpha2 being used: US
[ 46.326287] ath: Regpair used: 0x3a
[ 46.326351] cfg80211: Regulatory domain changed to country: US
[ 46.326355] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 46.326360] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 46.326364] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 46.326368] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 46.326377] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[ 46.326379] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 46.326380] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 57.028238] wlan0: no IPv6 routers present
[ 109.165293] I-pipe: head domain RTAI registered.
[ 109.165297] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 109.165405] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 109.165410] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[ 109.165413] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 109.165416] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 444250
[ 109.193096] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 109.193131] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 109.193135] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[ 109.193137] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[ 109.193139] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 109.212880] RTAI[math]: loaded.
[ 672.181845] RTAI[math]: unloaded.
[ 672.182799] SCHED releases registered named ALIEN PEDV$D
[ 672.185552] RTAI[malloc]: unloaded.
[ 672.284192] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 672.285871] I-pipe: head domain RTAI unregistered.
[ 672.285961] RTAI[hal]: unmounted.
[25485.967458] I-pipe: head domain RTAI registered.
[25485.967463] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[25485.967561] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[25485.967564] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[25485.967566] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[25485.967569] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1143750
[25486.039530] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[25486.039562] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[25486.039565] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[25486.039568] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[25486.039569] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[25486.092531] RTAI[math]: loaded.
[25486.993735] hm2: loading Mesa HostMot2 driver version 0.15
[25487.026604] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[25487.026641] hm2_pci: discovered 5i25 at 0000:05:00.0
[25487.027053] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[25487.029385] hm2/hm2_5i25.0: 34 I/O Pins used:
[25487.029387] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[25487.029388] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[25487.029390] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[25487.029392] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[25487.029393] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[25487.029394] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[25487.029396] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[25487.029398] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[25487.029400] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[25487.029402] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[25487.029404] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[25487.029406] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[25487.029407] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[25487.029409] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[25487.029410] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[25487.029411] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[25487.029413] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[25487.029414] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[25487.029416] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[25487.029417] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[25487.029418] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[25487.029420] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[25487.029421] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[25487.029422] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[25487.029424] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[25487.029425] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[25487.029426] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[25487.029428] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[25487.029429] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[25487.029430] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[25487.029432] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[25487.029433] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[25487.029434] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[25487.029436] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[25487.029481] hm2/hm2_5i25.0: registered
[25487.029482] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[25516.303208] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[25516.303214] hm2/hm2_5i25.0: unregistered
[25516.303271] hm2_pci: driver unloaded
[25516.306784] hm2: unloading
[25516.337805] RTAI[math]: unloaded.
[25516.338849] SCHED releases registered named ALIEN PEDV$D
[25516.340656] RTAI[malloc]: unloaded.
[25516.440147] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[25516.441821] I-pipe: head domain RTAI unregistered.
[25516.441935] RTAI[hal]: unmounted.
[96685.431057] I-pipe: head domain RTAI registered.
[96685.431062] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[96685.431149] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[96685.431153] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[96685.431155] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[96685.431158] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1538000
[96685.434783] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[96685.434807] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[96685.434810] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[96685.434812] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[96685.434813] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[96685.438862] RTAI[math]: loaded.
[97116.946018] RTAI[math]: unloaded.
[97116.947054] SCHED releases registered named ALIEN PEDV$D
[97116.949482] RTAI[malloc]: unloaded.
[97117.046676] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97117.048084] I-pipe: head domain RTAI unregistered.
[97117.048197] RTAI[hal]: unmounted.
[97245.657308] I-pipe: head domain RTAI registered.
[97245.657313] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97245.657388] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97245.657391] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97245.657393] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97245.657394] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1548000
[97245.660988] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97245.661014] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97245.661017] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97245.661019] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97245.661020] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97245.666586] RTAI[math]: loaded.
[97245.686584] config string '0 out'
[97335.632082] RTAI[math]: unloaded.
[97335.633166] SCHED releases registered named ALIEN PEDV$D
[97335.634953] RTAI[malloc]: unloaded.
[97335.734456] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97335.735943] I-pipe: head domain RTAI unregistered.
[97335.736066] RTAI[hal]: unmounted.
[97395.695972] I-pipe: head domain RTAI registered.
[97395.695975] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97395.696062] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97395.696066] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97395.696068] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97395.696070] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1557250
[97395.700165] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97395.700189] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97395.700191] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97395.700193] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97395.700195] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97395.705500] RTAI[math]: loaded.
[97395.720963] hm2: loading Mesa HostMot2 driver version 0.15
[97395.722165] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97395.722197] hm2_pci: discovered 5i25 at 0000:05:00.0
[97395.722616] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97395.724818] hm2/hm2_5i25.0: 34 I/O Pins used:
[97395.724821] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97395.724822] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97395.724824] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97395.724826] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97395.724827] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97395.724828] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97395.724829] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97395.724831] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97395.724833] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97395.724835] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97395.724837] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97395.724838] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97395.724839] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97395.724841] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97395.724842] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97395.724843] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97395.724844] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97395.724845] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97395.724846] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97395.724848] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97395.724849] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97395.724850] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97395.724851] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97395.724853] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97395.724854] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97395.724855] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97395.724856] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97395.724858] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97395.724859] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97395.724860] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97395.724861] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97395.724862] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97395.724864] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97395.724865] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97395.724901] hm2/hm2_5i25.0: registered
[97395.724902] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[97414.942438] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[97414.942443] hm2/hm2_5i25.0: unregistered
[97414.942487] hm2_pci: driver unloaded
[97414.943783] hm2: unloading
[97414.974250] RTAI[math]: unloaded.
[97414.975403] SCHED releases registered named ALIEN PEDV$D
[97414.977830] RTAI[malloc]: unloaded.
[97415.076893] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97415.078379] I-pipe: head domain RTAI unregistered.
[97415.078493] RTAI[hal]: unmounted.
[97467.779811] I-pipe: head domain RTAI registered.
[97467.779973] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97467.780048] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97467.780051] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97467.780054] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97467.780057] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1541500
[97467.784360] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97467.784387] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97467.784390] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97467.784392] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97467.784393] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97467.787974] RTAI[math]: loaded.
[97467.953828] hm2: loading Mesa HostMot2 driver version 0.15
[97467.955039] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97467.955156] hm2_pci: discovered 5i25 at 0000:05:00.0
[97467.955574] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97467.957667] hm2/hm2_5i25.0: 34 I/O Pins used:
[97467.957670] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97467.957672] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97467.957673] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97467.957675] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97467.957676] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97467.957677] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97467.957679] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97467.957681] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97467.957683] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97467.957684] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97467.957686] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97467.957687] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97467.957689] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97467.957690] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97467.957691] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97467.957692] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97467.957693] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97467.957695] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97467.957696] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97467.957697] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97467.957698] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97467.957699] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97467.957700] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97467.957702] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97467.957703] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97467.957704] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97467.957705] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97467.957706] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97467.957708] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97467.957709] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97467.957710] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97467.957711] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97467.957712] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97467.957713] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97467.957749] hm2/hm2_5i25.0: registered
[97467.957751] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[97477.808592] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[97477.808601] hm2/hm2_5i25.0: unregistered
[97477.808658] hm2_pci: driver unloaded
[97477.809816] hm2: unloading
[97477.840875] RTAI[math]: unloaded.
[97477.841940] SCHED releases registered named ALIEN PEDV$D
[97477.845198] RTAI[malloc]: unloaded.
[97477.942394] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[97477.943951] I-pipe: head domain RTAI unregistered.
[97477.944065] RTAI[hal]: unmounted.
[97490.949285] I-pipe: head domain RTAI registered.
[97490.949290] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[97490.949349] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[97490.949352] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[97490.949354] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[97490.949357] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1447250
[97490.953648] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[97490.953674] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[97490.953677] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[97490.953679] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[97490.953680] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[97490.961563] RTAI[math]: loaded.
[97490.976875] hm2: loading Mesa HostMot2 driver version 0.15
[97490.978068] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[97490.978109] hm2_pci: discovered 5i25 at 0000:05:00.0
[97490.978529] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[97490.980717] hm2/hm2_5i25.0: 34 I/O Pins used:
[97490.980720] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[97490.980721] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[97490.980723] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[97490.980724] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[97490.980725] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[97490.980727] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[97490.980728] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[97490.980730] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[97490.980732] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[97490.980733] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[97490.980735] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[97490.980737] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[97490.980738] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[97490.980739] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[97490.980741] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[97490.980742] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[97490.980743] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[97490.980744] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[97490.980745] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[97490.980747] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[97490.980748] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[97490.980749] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[97490.980750] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[97490.980751] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[97490.980753] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[97490.980754] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[97490.980755] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[97490.980756] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[97490.980758] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[97490.980759] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[97490.980760] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[97490.980761] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[97490.980762] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[97490.980763] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[97490.980799] hm2/hm2_5i25.0: registered
[97490.980800] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99042.486509] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99042.486514] hm2/hm2_5i25.0: unregistered
[99042.486551] hm2_pci: driver unloaded
[99042.487838] hm2: unloading
[99042.593516] RTAI[math]: unloaded.
[99042.594669] SCHED releases registered named ALIEN PEDV$D
[99042.596577] RTAI[malloc]: unloaded.
[99042.692789] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99042.694399] I-pipe: head domain RTAI unregistered.
[99042.694517] RTAI[hal]: unmounted.
[99348.481854] I-pipe: head domain RTAI registered.
[99348.481859] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99348.481932] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99348.481935] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99348.481938] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99348.481941] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1520500
[99348.486293] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99348.486319] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99348.486321] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99348.486323] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99348.486325] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99348.490454] RTAI[math]: loaded.
[99348.501390] config string '0 out'
[99356.968398] spurious APIC interrupt on CPU#2, should never happen.
[99356.968401] spurious APIC interrupt on CPU#3, should never happen.
[99356.968404] spurious APIC interrupt on CPU#0, should never happen.
[99356.970582] RTAI[math]: unloaded.
[99356.971658] SCHED releases registered named ALIEN PEDV$D
[99356.974379] RTAI[malloc]: unloaded.
[99357.072427] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99357.074131] I-pipe: head domain RTAI unregistered.
[99357.074245] RTAI[hal]: unmounted.
[99419.687448] I-pipe: head domain RTAI registered.
[99419.687451] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99419.687523] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99419.687525] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99419.687527] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99419.687529] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1236250
[99419.691370] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99419.691396] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99419.691399] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99419.691401] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99419.691402] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99419.696075] RTAI[math]: loaded.
[99419.710961] hm2: loading Mesa HostMot2 driver version 0.15
[99419.712164] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99419.712197] hm2_pci: discovered 5i25 at 0000:05:00.0
[99419.712602] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99419.714714] hm2/hm2_5i25.0: 34 I/O Pins used:
[99419.714715] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99419.714717] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99419.714718] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99419.714719] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99419.714720] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99419.714722] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99419.714723] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99419.714725] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99419.714727] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99419.714728] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99419.714730] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99419.714731] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99419.714732] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99419.714733] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99419.714735] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99419.714736] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99419.714737] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99419.714738] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99419.714739] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99419.714740] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99419.714741] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99419.714742] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99419.714743] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99419.714744] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99419.714746] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99419.714747] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99419.714748] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99419.714749] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99419.714750] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99419.714751] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99419.714752] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99419.714753] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99419.714754] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99419.714755] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99419.714791] hm2/hm2_5i25.0: registered
[99419.714793] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99494.630147] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99494.630152] hm2/hm2_5i25.0: unregistered
[99494.630193] hm2_pci: driver unloaded
[99494.631416] hm2: unloading
[99494.664151] RTAI[math]: unloaded.
[99494.665196] SCHED releases registered named ALIEN PEDV$D
[99494.667680] RTAI[malloc]: unloaded.
[99494.764584] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99494.766234] I-pipe: head domain RTAI unregistered.
[99494.766350] RTAI[hal]: unmounted.
[99628.853538] I-pipe: head domain RTAI registered.
[99628.853542] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99628.853624] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99628.853627] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99628.853629] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99628.853631] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1405250
[99628.858328] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99628.858355] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99628.858357] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99628.858359] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99628.858361] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99628.863584] RTAI[math]: loaded.
[99629.005763] hm2: loading Mesa HostMot2 driver version 0.15
[99629.006997] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99629.007033] hm2_pci: discovered 5i25 at 0000:05:00.0
[99629.007466] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99629.009821] hm2/hm2_5i25.0: 34 I/O Pins used:
[99629.009823] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99629.009824] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99629.009826] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99629.009827] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99629.009828] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99629.009829] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99629.009831] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99629.009832] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99629.009834] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99629.009836] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99629.009837] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99629.009839] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99629.009840] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99629.009841] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99629.009842] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99629.009843] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99629.009844] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99629.009845] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99629.009847] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99629.009848] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99629.009849] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99629.009850] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99629.009851] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99629.009852] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99629.009853] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99629.009854] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99629.009855] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99629.009857] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99629.009858] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99629.009859] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99629.009860] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99629.009861] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99629.009862] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99629.009863] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99629.009905] hm2/hm2_5i25.0: registered
[99629.009906] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99629.011027] config string '0 out'
[99629.388632] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99629.388637] hm2/hm2_5i25.0: unregistered
[99629.388668] hm2_pci: driver unloaded
[99629.389659] hm2: unloading
[99631.487805] RTAI[math]: unloaded.
[99631.489066] SCHED releases registered named ALIEN PEDV$D
[99631.490425] RTAI[malloc]: unloaded.
[99631.586703] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99631.588550] I-pipe: head domain RTAI unregistered.
[99631.588668] RTAI[hal]: unmounted.
[99649.133862] I-pipe: head domain RTAI registered.
[99649.133866] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[99649.133945] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[99649.133947] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[99649.133949] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[99649.133951] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1557250
[99649.137657] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[99649.137689] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[99649.137692] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[99649.137695] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[99649.137698] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[99649.141872] RTAI[math]: loaded.
[99649.285488] hm2: loading Mesa HostMot2 driver version 0.15
[99649.286605] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[99649.286644] hm2_pci: discovered 5i25 at 0000:05:00.0
[99649.287079] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[99649.289290] hm2/hm2_5i25.0: 34 I/O Pins used:
[99649.289292] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[99649.289294] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[99649.289295] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[99649.289296] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[99649.289298] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[99649.289299] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[99649.289300] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[99649.289302] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[99649.289303] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[99649.289305] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[99649.289307] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[99649.289308] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[99649.289309] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[99649.289310] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[99649.289311] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[99649.289313] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[99649.289314] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[99649.289315] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[99649.289316] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[99649.289317] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[99649.289318] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[99649.289319] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[99649.289320] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[99649.289321] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[99649.289323] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[99649.289324] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[99649.289325] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[99649.289326] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[99649.289327] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[99649.289328] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[99649.289329] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[99649.289330] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[99649.289331] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[99649.289332] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[99649.289374] hm2/hm2_5i25.0: registered
[99649.289375] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[99649.290415] config string '0 out'
[99649.421447] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[99649.421452] hm2/hm2_5i25.0: unregistered
[99649.421484] hm2_pci: driver unloaded
[99649.422499] hm2: unloading
[99651.488335] RTAI[math]: unloaded.
[99651.489623] SCHED releases registered named ALIEN PEDV$D
[99651.492804] RTAI[malloc]: unloaded.
[99651.589010] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[99651.591046] I-pipe: head domain RTAI unregistered.
[99651.591174] RTAI[hal]: unmounted.
[100837.588736] I-pipe: head domain RTAI registered.
[100837.588740] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[100837.588810] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[100837.588812] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[100837.588814] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[100837.588816] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1387000
[100837.593908] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[100837.593935] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[100837.593938] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[100837.593940] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[100837.593941] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[100837.599800] RTAI[math]: loaded.
[100837.615588] hm2: loading Mesa HostMot2 driver version 0.15
[100837.616822] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[100837.616855] hm2_pci: discovered 5i25 at 0000:05:00.0
[100837.617272] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[100837.619326] hm2/hm2_5i25.0: 34 I/O Pins used:
[100837.619328] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[100837.619330] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[100837.619331] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[100837.619333] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[100837.619334] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[100837.619335] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[100837.619337] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[100837.619339] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[100837.619341] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[100837.619343] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[100837.619344] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[100837.619346] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[100837.619347] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[100837.619348] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[100837.619349] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[100837.619351] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[100837.619352] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[100837.619353] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[100837.619354] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[100837.619356] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[100837.619357] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[100837.619358] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[100837.619359] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[100837.619363] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[100837.619367] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[100837.619368] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[100837.619369] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[100837.619370] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[100837.619372] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[100837.619373] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[100837.619374] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[100837.619375] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[100837.619376] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[100837.619377] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[100837.619425] hm2/hm2_5i25.0: registered
[100837.619427] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[101040.681142] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[101040.681153] hm2/hm2_5i25.0: unregistered
[101040.681618] hm2_pci: driver unloaded
[101040.684289] hm2: unloading
[101040.716775] RTAI[math]: unloaded.
[101040.717846] SCHED releases registered named ALIEN PEDV$D
[101040.721163] RTAI[malloc]: unloaded.
[101040.818249] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[101040.820071] I-pipe: head domain RTAI unregistered.
[101040.820193] RTAI[hal]: unmounted.
[101108.237826] I-pipe: head domain RTAI registered.
[101108.237829] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[101108.237919] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[101108.237922] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[101108.237924] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[101108.237927] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1215000
[101108.241593] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[101108.241618] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[101108.241621] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[101108.241623] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[101108.241624] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[101108.246492] RTAI[math]: loaded.
[101108.256826] config string '0 out'
[101216.272928] RTAI[math]: unloaded.
[101216.273999] SCHED releases registered named ALIEN PEDV$D
[101216.276612] RTAI[malloc]: unloaded.
[101216.375301] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[101216.376779] I-pipe: head domain RTAI unregistered.
[101216.376893] RTAI[hal]: unmounted.
[102115.465707] I-pipe: head domain RTAI registered.
[102115.465710] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[102115.465794] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[102115.465796] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[102115.465798] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[102115.465800] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1544750
[102115.470283] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[102115.470312] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[102115.470315] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[102115.470317] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[102115.470318] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[102115.479558] RTAI[math]: loaded.
[102115.494619] hm2: loading Mesa HostMot2 driver version 0.15
[102115.495783] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[102115.495818] hm2_pci: discovered 5i25 at 0000:05:00.0
[102115.496221] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[102115.498322] hm2/hm2_5i25.0: 34 I/O Pins used:
[102115.498325] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[102115.498327] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[102115.498328] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[102115.498330] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[102115.498331] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[102115.498332] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[102115.498334] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[102115.498336] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[102115.498337] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[102115.498339] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[102115.498340] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[102115.498342] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[102115.498343] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[102115.498344] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[102115.498345] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[102115.498346] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[102115.498348] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[102115.498349] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[102115.498350] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[102115.498351] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[102115.498352] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[102115.498353] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[102115.498354] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[102115.498355] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[102115.498356] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[102115.498358] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[102115.498359] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[102115.498360] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[102115.498361] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[102115.498363] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[102115.498364] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[102115.498365] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[102115.498366] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[102115.498367] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[102115.498404] hm2/hm2_5i25.0: registered
[102115.498405] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[102140.145781] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[102140.145787] hm2/hm2_5i25.0: unregistered
[102140.146047] hm2_pci: driver unloaded
[102140.148121] hm2: unloading
[102140.178311] RTAI[math]: unloaded.
[102140.179363] SCHED releases registered named ALIEN PEDV$D
[102140.181618] RTAI[malloc]: unloaded.
[102140.277705] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[102140.279295] I-pipe: head domain RTAI unregistered.
[102140.279415] RTAI[hal]: unmounted.
[105641.519348] I-pipe: head domain RTAI registered.
[105641.519351] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[105641.519429] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[105641.519432] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 1559452, CLK_FREQ 3193897000, CPU_FREQ 3193897000
[105641.519433] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[105641.519435] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 1559452, 1559452, 1547500
[105641.523412] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[105641.523436] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[105641.523439] RTAI[sched]: hard timer type/freq = APIC/1559452(Hz); default timing: oneshot; linear timed lists.
[105641.523441] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3193897000 hz.
[105641.523442] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[105641.527894] RTAI[math]: loaded.
[105641.571033] hm2: loading Mesa HostMot2 driver version 0.15
[105641.572218] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[105641.572253] hm2_pci: discovered 5i25 at 0000:05:00.0
[105641.572691] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[105641.575056] hm2/hm2_5i25.0: 34 I/O Pins used:
[105641.575058] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[105641.575060] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[105641.575061] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[105641.575062] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[105641.575064] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[105641.575065] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[105641.575066] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[105641.575068] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[105641.575069] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[105641.575071] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[105641.575073] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[105641.575074] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[105641.575075] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[105641.575076] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[105641.575077] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[105641.575079] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[105641.575080] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[105641.575081] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[105641.575082] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[105641.575083] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[105641.575084] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[105641.575085] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[105641.575086] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[105641.575087] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[105641.575088] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[105641.575090] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[105641.575091] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[105641.575092] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[105641.575093] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[105641.575094] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[105641.575095] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[105641.575096] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[105641.575097] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[105641.575098] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[105641.575140] hm2/hm2_5i25.0: registered
[105641.575141] hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
[105641.708588] hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
[105641.708593] hm2/hm2_5i25.0: unregistered
[105641.708625] hm2_pci: driver unloaded
[105641.709628] hm2: unloading
[105643.775577] RTAI[math]: unloaded.
[105643.776877] SCHED releases registered named ALIEN PEDV$D
[105643.779088] RTAI[malloc]: unloaded.
[105643.877310] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[105643.879041] I-pipe: head domain RTAI unregistered.
[105643.879154] RTAI[hal]: unmounted.
03 Jul 2022 22:22 #246545
Replied by PCW on topic Cant get servo motors to move during configuration
Looks like you have the wrong firmware loaded in the 5I25 card (its 7I77 firmware)
You need to re-flash the 5I25 with 7I76 firmware:
sudo mesaflash --device 5i25 --write 5i25_7i76x2.bit
sudo mesaflash --device 5i25 --reload
( 5i25_7i76x2.bit is in the 5i25.zip file: configs/hostmot2/ )
- 42walrustitan
03 Jul 2022 23:00 - 03 Jul 2022 23:40 #246546
by 42walrustitan
Replied by 42walrustitan on topic Cant get servo motors to move during configuration
Where can I faind that file
Last edit: 03 Jul 2022 23:40 by 42walrustitan.
03 Jul 2022 23:20 #246547
freeby.mesanet.com/software/parallel/5i25.zip
is one place
is one place
- 42walrustitan
03 Jul 2022 23:41 #246549
by 42walrustitan
Got it and ran the commands you gave me. The test in the configuration wizard now says that the axis is moving but the machine itself does not seem to move.
- Thank you received: 6006
03 Jul 2022 23:43 #246550
www.cnczone.com/forums/gecko-drives/67931-g320-power-fault.html
I have 4 of them, two of them do this, well one has the resistor so it does not do that anymore.
Replied by tommylight on topic Cant get servo motors to move during configuration
Phu, barely found it:whenver power is aplied the x axis tries to move in one direction.
04 Jul 2022 00:45 - 04 Jul 2022 00:47 #246551
is that the step time is too short (try 5 usec = 5000 ns as a start )
The most common reason step drives don't move ( when step and dir are connected properly)Got it and ran the commands you gave me. The test in the configuration wizard now says that the axis is moving but the machine itself does not seem to move.
Last edit: 04 Jul 2022 00:47 by PCW.
- 42walrustitan
04 Jul 2022 00:56 #246554
by 42walrustitan
So start with 5microsecond pulses and step up from there until the servos move?
Time to create page: 0.127 seconds
