Cant get servo motors to move during configuration
04 Jul 2022 02:28 #246555
Replied by PCW on topic Cant get servo motors to move during configuration
5 usec is usually OK unless you have very slow drives
Also for many low end drives, single ended step/dir
connections are better.
- 42walrustitan
04 Jul 2022 18:52 #246593
by 42walrustitan
Replied by 42walrustitan on topic Cant get servo motors to move during configuration
Gecko 320 are single ended drives. So I have the mesa 7i76 configured for single ended drives. Even with 5usec the servos still dont seem to move. Is there a good way to check if I have messed up the wiring.
04 Jul 2022 19:01 - 04 Jul 2022 19:02 #246594
For single ended you would connect only the STEP-, DIR- and +5V from the 7I76 to the G320
Are you testing with LinuxCNC? I would do that rather than using pncconfs test routine.
Last edit: 04 Jul 2022 19:02 by PCW.
- 42walrustitan
07 Jul 2022 00:48 #246767
by 42walrustitan
Got the motors moving! Turned out that I had everything wired correctly and that there was an issue with the power supply. All sorted now. Tanks for all of the help.
Time to create page: 0.094 seconds
