7i95T PnCConf 1PWM
09 Oct 2023 09:59 - 09 Oct 2023 10:05 #282596
by SOLD
7i95T PnCConf 1PWM was created by SOLD
I download the firmware for 7i95T. I found 7i95t_1pwmd.bin , 7i95t_1pktv2d.bin What should I use to have 1pwm on P1 wiht cina5axisbob? Or where can I find firmware that outputs PWM on a serial TX output?
What linuxcnc version is available Pncconf for 7i95T
Last edit: 09 Oct 2023 10:05 by SOLD.
09 Oct 2023 15:38 #282618
Replied by PCW on topic 7i95T PnCConf 1PWM
7i95t_1pwmd.bin steals one step/dir output for PWM/DIR
What do you actually need the PWM for? If for the analog output
on a 5ABOB, you would need a configuration specifically for that.
I think you need LinuxCNC master or recent 2.9 for 7I95T support
though ol;der version will work, you just get some complaints at startup
and may need to change the card name.
You can use a 7I95 configurations on the 7I95T so older pncconf versions
will work.
will work.
The following user(s) said Thank You: SOLD
10 Oct 2023 05:01 #282662
by SOLD
Replied by SOLD on topic 7i95T PnCConf 1PWM
I use 6 axis on 7i95T. and want to use PWM spindle on P1 with 5ABOB.
Can I use this file? 7i95_p1pwmd.zip form link
forum.linuxcnc.org/38-general-linuxcnc-q...0-10v-spindle-output
or help create a new one for 7I95T+5Abob
10 Oct 2023 05:11 #282663
I can do this is the next day or soor help create a new one for 7I95T+5Abob
10 Oct 2023 08:45 - 10 Oct 2023 08:48 #282676
by SOLD
Thank you for your support.
Last edit: 10 Oct 2023 08:48 by SOLD.
10 Oct 2023 17:43 #282692
7I95T configuration for 5ABOB on expansion connector:
11 Oct 2023 05:02 #282723
by SOLD
I want to know the meaning of 7i95t_1pktv2d.bin
I use 2.8.4 and 2.9.0-pre 1-1094-g1718e100 Checked the Pncconf board name and didn't find 7i95. Am I missing something?7I95T configuration for 5ABOB on expansion connector:
11 Oct 2023 13:58 - 11 Oct 2023 14:10 #282751
I don't think pncconf supports the 7I95/7I95T though you could make a
configuration for say a 7I96S as a start. You would need to change the
card name and the input names and a minimum. You could also try MesaCT.
The 7I95T also needs LinuxCNC 2.9 or greater
7i95t_1pktv2d.bin is firmware the replaces one sserial expansion port with a
PacketUART (for Modbus support)
EDIT:
Looks like someone is adding 7I95T support to pncconf:
forum.linuxcnc.org/39-pncconf/50272-addi...iguration-to-pncconf
EDIT:
Last edit: 11 Oct 2023 14:10 by PCW.
13 Oct 2023 15:24 #282896
by SOLD
I read the thread you recommended. And I've tried using Mesa CT, but Hal and ini are not familiar with it. I will continue to use it.
thank you
thank you
Time to create page: 0.150 seconds
