MESA 7i95 use 6 axis + generate 0-10V Spindle output
  • mittim
  • mittim's Avatar Topic Author
  • Premium Member
  • Premium Member
17 Jul 2021 13:32 - 17 Jul 2021 13:33 #215165 by mittim
Hello,
I am using a MESA 7i95 card with usage of all 6 axis outputs for moving axis.
I want to run my spindle via 0-10 V. Is there a way to generate PWM with one of the I/O´s and use an converter such as:
www.amazon.de/Digital-Analog-Signal-Tran...verter/dp/B00UIZKYAS
Thanks in advance!
Last edit: 17 Jul 2021 13:33 by mittim.
17 Jul 2021 14:51 #215167 by PCW
Yes, it would need firmware that puts  a PWM gen on P1 like:
File Name: 7i95_p1pwmd.zip
File Size:127 KB
Another option if you are not using both serial expansion connectors
would be to have firmware that  outputs PWM on a serial TX output
  • mittim
  • Premium Member
  • Premium Member
17 Jul 2021 14:53 #215168 by mittim
Thanks alot PCW.
Always appreciate your help on this forum!
24 Aug 2023 04:40 #278846 by vmihalca
Now on my lathe I have a Mesa 7i97, because my previous drives were analog.
Recently I replaced motors & drives with some Delta ASDA-A2, and these have step-dir so I was thinking to buy a 7i95T because I need the 7i97 to do a retrofit for a machine with analog drives.
I have two questions:
- Does the custom firmware applies for 7i95T too?
- Once I switch to step dir, if my drives have auto-tunning and I do the tunning inside the axis drives, do I still need to do PID tunning in linuxcnc? The encoder outputs from the drives will enter mesa.
Right now with analog control, I have the last digit (the micron one) flickering, but I expect that to disappear once I switch to a board that controls the drives with step-dir
  • Moderator
  • Moderator
24 Aug 2023 06:02 #278851 by tommylight
For normal stuff, no custom firmware.
Yes, if the encoders are connected to Mesa, you have to tune the drives first and only after they are good, tune in LinuxCNC.
If it does disappear, something is wrong. That is the PID loop keeping the motor in position.
Time to create page: 0.164 seconds
