31659-nativecam-is-features examples
18 Jul 2017 17:48 #96012
by jmmontes
31659-nativecam-is-features examples was created by jmmontes
Hi Fern.
First of all thanks a lot for your great work with nativecam.
I have been trying to get familiarized with program preparing several plastic spacers for my mill steppers.
Could you please confirm basic spacer.xml included in nativecam 1.6 is a working example?
I have tried it in LINUXCNCVERSION=2.7.9-38-g140104a and blue progress bar freezes while loading clock does not disappear?
Thanks in advance.
José Miguel
Thanks in advance.
José Miguel
19 Jul 2017 10:41 #96045
by FernV
Hi José
I am running it with no problem in the simulator as I write this. Have you made any changes other than selecting a drill and cutter ?
Fern
Replied by FernV on topic 31659-nativecam-is-features examples
...Could you please confirm basic spacer.xml included in nativecam 1.6 is a working example?
Hi José
Fern
19 Jul 2017 16:38 #96092
by jmmontes
Replied by jmmontes on topic 31659-nativecam-is-features examples
Hi Fern,
I have not even selected drill or cutter.
I copy output when launching lcnc with axis_mm simulator.
Quote.
Machine configuration file is 'axis_mm.ini'
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
task: main loop took 0.013569 seconds
task: main loop took 0.013592 seconds
gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py
NativeCAM info:
inifile = /home/jm/linuxcnc/configs/sim.axis-1/axis_mm.ini
NCAM_DIR = /home/jm/linuxcnc/configs/sim.axis-1/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
[RS274NGC]SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
Real paths:
/home/jm/linuxcnc/configs/sim.axis-1/ncam/my-stuff
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
Using default mill/menu.xml, no mill/menu-custom.xml found
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2327: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Previous work not saved as current work
task: main loop took 0.013271 seconds
task: main loop took 0.014709 seconds
Xlib.protocol.request.QueryExtension
task: main loop took 0.010065 seconds
task: main loop took 0.013747 seconds
task: main loop took 0.013752 seconds
Drill info : diameter = 6.350000, point angle = 118 &0.000000;, point length = 1.907732
task: main loop took 0.011907 seconds
task: main loop took 0.012652 seconds
task: main loop took 0.010047 seconds
Unquote.
For your information wheel demo.xml opens without any error.
José Miguel
file:///home/jm/linuxcnc/configs/sim.axis-1/axis_mm.ini
Quote.
NativeCAM info:
Real paths:
Unquote.
José Miguel
19 Jul 2017 16:47 #96093
by FernV
José
Load the example, read the comment then select Params and read last line
Fern
Fern
19 Jul 2017 18:57 #96096
by jmmontes
Hi Fern,
Example does not open, screen stays as in attached screenshoot, I have to force closing lcnc.
José Miguel
José Miguel
19 Jul 2017 20:23 #96099
by FernV
José,
Fern
- Restart lcnc.
- Uncheck Auto-refresh from NativeCAM Utilities menu
- Open 'basic spacer.xml' example
- Change values in Params for some metric ones
- Click on the Build Button (the one that looks like a gear)
Fern
20 Jul 2017 13:33 #96144
by FernV
Hi José
I have an update for 'basic spacer.xml' here not published yet.
Would you save it in '/home/jm/linuxcnc/configs/sim.axis-1/ncam/catalogs/mill/projects' and see if it works for you
If not you have some other issues
Fern
Fern
20 Jul 2017 17:34 #96155
by jmmontes
Hi again Fern,
Thanks again for your proactivity.
I attach g-code error.
Before asking for your support, I uninstalled ncam, deleted ncam directory in /home/jm and all ncam folders inside /home/jm/linuxcnc/configs, then Installed ncam 1.6 by means of apt-get install.
Take also into account that now my version is linuxcnc 2,7.10 due to last update.
José Miguel
José Miguel
20 Jul 2017 18:28 #96160
by FernV
Hi José
You are not giving me much stuff to help you solve your issue. I think it is something you have not configured well but I need to see more.
I see you are using nativecan stand alone.
I want to see ncam.ngc, the output of the terminal when you run it, the directory and sub-directories content where your inifile is.
I guess you have executed $ ncam -i inifile -c mill -t
because I saw that ncam is in a tab.
Give me everything, so I can help
Fern
Fern
21 Jul 2017 16:02 #96231
by FernV
Time to create page: 0.340 seconds
