- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- I'm having trouble calling a subroutine from a separate file.
06 Feb 2019 01:20 #125779
by bondglen
I have made many subroutines and have never had a problem calling any of them. But these new ones will not function when called from a separate file. If I include them all in one file, everything is fine.
I have 3 subroutines. I set a global parameter and call the first routine. The first subroutine calls the other two subroutines.
I can't get it to work. nothing happens. I am able to call other routines and they work fine.
It seems that the subroutine might be running in the background.
When I run the subroutine, the stop button becomes inactive, like the program has ended.
But changes on the digital I/O pins sometimes cause action!!?? (The subroutines read the digital I/O pins)
I can't figure this one out.
If anybody has any ideas, please let me know.
Thanks,
Glen
Thanks,
Glen
06 Feb 2019 22:24 #125884
by bondglen
Replied by bondglen on topic I'm having trouble calling a subroutine from a separate file.
I gave up trying to make the new subroutines work. Went back to old files that previously work perfectly... they don't work! Apparently I have messed up something in my system.
I'm going to do a new install of LinuxCNC.
Glen
Glen
- Thank you received: 1370
07 Feb 2019 03:30 #125903
Replied by Todd Zuercher on topic I'm having trouble calling a subroutine from a separate file.
Where are you saving your sub files? Is it possible you could have changed the path in your ini file?
07 Feb 2019 22:41 #125958
by bondglen
Ok, got it back to where I was originally.
No, the path is still good.
There seems to be some sort of critical requirements for the %.
If I don't use them, LinuxCNC will hang when I load the file.
If I use them at beginning and end of subroutine file, it doesn't work.
Some files seem to work well with no % at the beginning, and at the end use % and M30.
Got to have the M30.
These subroutines, all of them will work fine when executed with MDI. (% and M30 at the end)
I'm trying to find more info on file format for subroutines.
08 Feb 2019 00:08 - 08 Feb 2019 00:21 #125965
by BigJohnT
Replied by BigJohnT on topic I'm having trouble calling a subroutine from a separate file.
linuxcnc.org/docs/2.7/html/gcode/overvie...de:file-requirements
There is a big difference between wrapping G code with a pair of %% and using M2 to end a file.
Also note that the subroutine file name and the subroutine name must match and the file must be executable and I know I put that in the docs but dang if I an find it now. This is an example subroutine file.
Edit: make sure the SUBROUTINE_PATH = /home/yourusername/linuxcnc/subroutines is a valid path in the [RS274NGC] section of the ini file.
Edit: call the subroutine file like this:
JT
(file somefile.ngc)
o<somefile> sub
G0 X2
o<somefile> endsub
M2
o<somefile> call
M2
JT
Last edit: 08 Feb 2019 00:21 by BigJohnT.
08 Feb 2019 16:34 #126007
by bondglen
I think my path to the subroutines is set ok, because I have other subroutines that are called from a file and they work fine. All my subroutines are in the same directory.
What is the difference in calling from a file and entering the command in MDI?
From MDI everything works good, but when I try to call it from a program file it doesn't work.
The same program will call other subroutines without problems.
08 Feb 2019 21:22 - 08 Feb 2019 21:23 #126018
by BigJohnT
Last edit: 08 Feb 2019 21:23 by BigJohnT.
09 Feb 2019 03:52 #126034
by bondglen
Ok, I made all files executable. It had no effect.
I took one of the subroutines that won't work and began cutting out several lines of code at a time and trying it. Normally, EMC just hangs after trying to load the file. I continued to cut out lines of code until it started working. Here is what I came up with.
o307 while [#5399 EQ 0]
This line of code doesn't work
if I change it to:
o307 while [#5399 NE 0]
it will load.
The preceding line is
M66 P2 L0
So the value of #5399 could be 0 or 1 depending on digital input pin 2.
Maybe I should change the code from EQ 0 to NE 1.
I think it has something to do with the digital input.
if I change it to:
it will load.
M66 P2 L0
09 Feb 2019 11:28 #126045
by BigJohnT
The while loop is working I guess but must not ever be equal 0. You can use a debug statement to see what the variable is just before entering the while loop. Axis for example will run the G code file to plot the path out so while that is going on and the variable is not equal to 0 the interpreter waits forever in the while loop. You can in Axis control the preview
linuxcnc.org/docs/devel/html/gui/axis.html#axis:preview-control
JT
JT
09 Feb 2019 16:30 #126062
by bondglen
Ok, I tried (AXIS,show) and (AXIS, hide), but they didn't do the trick, but when I used (AXIS, stop) everything started working. But no preview on the screen.
So I re-wrote the subroutine that reads the digital pins to get rid of the do/while loops.
The M66 code provides for a 'wait for high', or 'wait for low' on the digital input pins.
So I used M66 L3 Q5000, and M66 L4 Q5000 to get rid of the do/while loops and now have preview back.
Everything works great!
Many thanks, BigJohnT
The following user(s) said Thank You: BigJohnT
Time to create page: 0.295 seconds
