- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- I'm having trouble calling a subroutine from a separate file.
13 Feb 2019 22:32 #126404
This seems to be a bug in 2.8 / master (if you are not using 2.8 / master then ignore this)
If a subroutine has % at the beginning and end _and_ the loaded G-code file has % at the beginning and end then there is a problem.
If either or both use M2 instead then there is no problem. (probably)
github.com/LinuxCNC/linuxcnc/issues/559
Replied by andypugh on topic I'm having trouble calling a subroutine from a separate file.
Ok, got it back to where I was originally.
No, the path is still good.
There seems to be some sort of critical requirements for the %.
13 Feb 2019 23:10 #126417
by Grotius
Replied by Grotius on topic I'm having trouble calling a subroutine from a separate file.
I was looking yesterday if it could be a github issue, trough the hidden files. Problably not.
Time to create page: 0.124 seconds
