While Loop Possible Bug(s)?
- Topic Author
- Thank you received: 1370
30 May 2019 17:04 #135403
Replied by Todd Zuercher on topic While Loop Possible Bug(s)?
No, the debug lines were not skipped, I just happened to have cleared them before taking the screen shot.
- Topic Author
30 May 2019 17:08 #135405
I was testing this in 2.7.14.
I tested the code in the first post on my milling machine it's running master. Can not replicate the error.
Tried with #5=25 and 26, the final circle gets done here.
I made a quick check in the code, and from what I can see it's all standard double-precision math internally.
30 May 2019 18:59 #135414
by MaHa
Replied by MaHa on topic While Loop Possible Bug(s)?
Passing here accidentally, as i am away from the forum anyway, but there is a spiralroutine.
forum.linuxcnc.org/20-g-code/35812-circu...lling-routine#123743
In the meantime a bit auotdated but working and inspiring. Big +++ is the constant feed for any dia.
Only need to modify the the leadinarc and add Z levelling. The recent version is metric only, so dont post it.
Bye for the next few month...
02 Jun 2019 09:30 #135622
by Hakan
Replied by Hakan on topic While Loop Possible Bug(s)?
I think this is a bug actually. Nice exercise to learn about the code.
By switching on TP_DEBUG and recompile one can see in the output that the suggested angle for the failing arc is
"radius = 1.875781250000, angle = 0.000004591468" for the 25 case (that fails), and
"radius = 1.875487290044, angle = 6.283185125288" for the 28 case (that works).
The printout is in tp/blendmath.c, but the angle is not calulcated there.
I assume this is the reason for a very small arc being made instead of a full circle. On the other hand, it could be something else.
- Topic Author
02 Jun 2019 13:49 #135633
I think you hit the nail on the head. Because if you add a p2 to the failing arc it does 1 circle.
03 Jun 2019 06:40 #135700
Replied by andypugh on topic While Loop Possible Bug(s)?
I am still suspecting something funny happening with the sqrt.
I am away from my LinuxCNC machines at the moment (for several days). What happens if you (DEBUG, ...) the input expression to the SQRT. If that is propagating a NaN into the TP then all sorts of wierdness is likely to ensue.
03 Jun 2019 19:43 #135787
by Hakan
I wonder that. It should be sqrt of x^2 + y^2 and that should always be safe.
I am thinking that there is something due to the tool compensation that is in effect. Transitions from one circle to the next and need to make a small move and somethings go wrong (just guessing),
And the format you used "G3 I- J-" is used to program full circles. How can it then do zero circles (or a very small one)?
I didn't see this issue in master so maybe someone has been working on it?
- Topic Author
03 Jun 2019 20:37 #135795
There was/is no tool compensation in effect.
Time to create page: 0.096 seconds
