Lathe OD Turning
26 Mar 2012 09:48 #18802 by Rick G
Replied by Rick G on topic Re:OD Turning Subroutine
Hey John,
For someone with a slow connection you are keeping busy.
Looks like this one now combines the rough and slow passes.
Rick G
26 Mar 2012 10:39 #18804 by BigJohnT
Replied by BigJohnT on topic Re:OD Turning Subroutine
Yes, but I'm not 100% sure it works all the time...
26 Mar 2012 11:53 - 26 Mar 2012 13:33 #18806 by Rick G
It looks like if the depth of cut and the final diameter come out even it may skip the finish cut?
Perhaps a field with the finish cut depth and add that to the final diameter before running?
Then run the finish cut.
Never mind it looks like it's already there. Maybe it's the new glasses.
Rick G
Last edit: 26 Mar 2012 13:33 by Rick G.
26 Mar 2012 13:41 - 26 Mar 2012 14:07 #18808 by BigJohnT
I did a complete re-write of the OD sub this morning as there were several mistakes in my logic...
This sub will allow you to specify roughing and finishing tools, depth of cut, feed as well as the normal things needed like OD, final diameter, start Z, end Z. If the finish cut is equal to or deeper than the difference between start diameter and final diameter / 2 then the roughing cuts are simply skipped. The roughing cuts are as close as possible to the specified roughing depth and not deeper but evenly divided up so each cut is the same. The finish cut follows the complete profile left to give a wiping cut on the Z shoulder.
And here it is completely re-written and much better behaved...
File Name: od-8e11e70...fdcb.ngc
File Size:2 KB
Enjoy
Last edit: 26 Mar 2012 14:07 by BigJohnT.
27 Mar 2012 10:01 #18835 by Rick G
Cool, I will have to try it when I get back out to the shop.
Rick G
23 Sep 2012 14:57 #24562 by jbunch
Replied by jbunch on topic Re:Lathe OD Turning
Just loaded. When I use this with my .axisrc setup for backtool I receive an error from ngc when I post. Also how woud you add cw ccw selection to each tool.
Jim
24 Sep 2012 02:49 - 24 Sep 2012 02:52 #24573 by JR1050
Replied by JR1050 on topic Re:Lathe OD Turning
While Im addmitting late to this thread,Ive thought about this one my self.I used to own an Ikeagai lathe that didnt have the full g70/g71 ruffing cylces,it had a G94 cycle like your sub above.
For what it is worth,you can use drilling cycles G81 and G83(real handy when you cant get the chips to break,especially when you are boring small holes)as one pass ruffing cyles like so
G0 X.45Z.03
G81R.03F.015Z-1.
G80
This will turn a .45 dia back 1 inch,you substitute G83 and break the chip the value of Q.
Adding to this you can make an incremental sub.
O100 sub
G81R.03F.015Z-1.
G91
G0X-.1
G90G80
endsub (or M99 or however Emc ends a subroutine)
Then call like so
G0 X1.01Z.1
o100 call repeat [5]
This will create a .1 step ruffing cycle that cuts the dia to .51 in .100 steps.
It also looks like this would work
G0 X.1.Z.03
G81R.03F.015Z-1.
G91X-.1L5
G90G80
These are for simple step turning,For what it is worth.....
Last edit: 24 Sep 2012 02:52 by JR1050.
24 Sep 2012 10:50 #24575 by BigJohnT
Replied by BigJohnT on topic Re:Lathe OD Turning
Jim
Use an if statement to select between M3 and M4. You can only pass numbers so use if variable EQ 0 then M3 else M4.
24 Sep 2012 11:02 #24576 by Rick G
Replied by Rick G on topic Re:Lathe OD Turning
What is in your .axisrc ?
Rick G
24 Sep 2012 15:26 #24583 by jbunch
I did a copy and paste from the WIKI on changing axis display for use with backtool. I also have two lines that invert the up arrow and down arrow for the X axis.
Jim
Time to create page: 0.277 seconds
