Strange subroutine error
- viesturs.lacis
- Thank you received: 3
04 Sep 2021 12:05 #219594
by viesturs.lacis
Strange subroutine error was created by viesturs.lacis
Hello!
I am trying to write some subroutines for ngcgui. The thing is that when I try to create a feature in ngcgui, I get an error that makes absolutely no sense to me. I get that error message only if I check "expand subroutines".
I would appreciate any hints, what exactly am I missing or doing incorrectly. The thing is that I get very similar error for subroutines that I downloaded from this forum.
Here is the subroutine[/code]
[/code][/code][/code][/code]
[/code]
[/code][/code][/code][/code][/code][/code][/code][/code][/code][/code][/code]
[/code]
[code]o<drill1> sub
(info: Drilling bottom edge with horizontal spindle)
#<X_Coord> = #1 (X Coordinate)
#<Y_Coord> = #2 (Y Coordinate)
#<Z_Coord> = #3 (Z Coordinate)
#<Safe_Z> = #4 (=0 Safe Z height)
#<Y_StepBack> = #5 (= 5 Step back from edge along Y)
#<Bore_depth> = #6 (=20 Depth)
#<FeedRate> = #7 (=300 Feedrate mm/min)
#<ToolNumber> = #8 (=1 Tool Number)
#<Peck> = #9 (=6 Peck Increment)
#<X_Park> = #10 (=0 X Park)
#<Y_Park> = #11 (=0 Y Park)
;set global parameters
;#<_remain_depth> = #<Bore_depth>
;#<_temp_depth> = 0
T#<ToolNumber> M6
G43 T#<ToolNumber>
#<remain_depth> = #<Bore_depth>
#<temp_depth> = 0
S100 M3 F#<FeedRate>
G0 Z#<Safe_Z>
G0 X#<X_Coord> Y[#<Y_Coord> - #<Y_StepBack>]
G0 Z#<Z_Coord>
o<y100> while [#<remain_depth>]
o<y1100> if [#<remain_depth> GT #<Peck>]
#<temp_depth> = [#<temp_depth> + #<Peck>]
G1 Y[#<Y_Coord> + #<temp_depth>]
G1 Y#<Y_Coord>
#<remain_depth> = [#<remain_depth> - #<Peck>]
o<y1100> else
#<remain_depth> = 0
G1 Y[#<Y_Coord> + #<Bore_depth>]
G1 Y[#<Y_Coord> - #<Y_StepBack>]
o<y1100> endif
o<y100> endwhile
G0 Z#<Safe_Z>
o<drill1> endsub
[code]Here is the error message:
[code][code][code][code]Near line 57 of
/home/cnc/linuxcnc/nc_files/0.auto.ngc:
57:duplicate O-word label: 'o<001y1100>
while [#<remain_depth>]' - defined in line 52
[/code]
[code][code][code][code]Here is the 0.auto.ngc file that was generated by ngcgui:
[code][code][code][code][code][code][code][code](pyngcgui: FEATURE 210904:14.53.47)
(pyngcgui: files: </home/cnc/linuxcnc/nc_files/ngcgui_lib/utilitysubs/mm_std.ngc,/home/cnc/linuxcnc/nc_files/drill1.ngc,>;)
(pyngcgui: feature line added) #<_feature:> = 0
(pyngcgui: remaining_features line added) #<_remaining_features:> = 0
(pyngcgui: preamble file: /home/cnc/linuxcnc/nc_files/ngcgui_lib/utilitysubs/mm_std.ngc)
g17 (xy plane)
g21 (mm)
g40 (cancel cutter radius compensation)
g49 (cancel tool lengthoffset)
g90 (absolute distance mode)
g94 (units/min feedrate)
g54 (Coordinate system 1 default)
#<tol> = 0.001
g64 p#<tol> (path control stop)
(Positional parameters for /home/cnc/linuxcnc/nc_files/drill1.ngc)
#1 = 50
#2 = 15
#3 = 9
#4 = 0
#5 = 5
#6 = 20
#7 = 300
#8 = 1
#9 = 6
#10 = 0
#11 = 0
(expanded file: /home/cnc/linuxcnc/nc_files/drill1.ngc)
;#<_temp_depth> = 0
T#<ToolNumber> M6
G43 T#<ToolNumber>
#<temp_depth> = 0
G0 Z#<Safe_Z>
G0 Z#<Z_Coord>
o<001y100> while [#<remain_depth>]
o<001y1100> while [#<remain_depth>]
G1 Y#<Y_Coord>
#<remain_depth> = 0
o<001y100> endwhile
G0 Z#<Safe_Z>
(pyngcgui: m2 line added) m2 (g54 activated)
[/code]
- viesturs.lacis
04 Sep 2021 12:08 #219596
by viesturs.lacis
Replied by viesturs.lacis on topic Strange subroutine error
Sorry about those duplications of code tags, no idea, where they came from, I did put them correctly. Firefox version too old in the LinuxCNC iso image?
- Thank you received: 5944
04 Sep 2021 13:17 #219601
Replied by tommylight on topic Strange subroutine error
I would blame the forum editor, it is a bit iffy lately !
- viesturs.lacis
04 Sep 2021 13:50 - 04 Sep 2021 13:50 #219604
by viesturs.lacis
any idea about the subroutine error?
Last edit: 04 Sep 2021 13:50 by viesturs.lacis.
- viesturs.lacis
04 Sep 2021 15:06 #219608
by viesturs.lacis
BTW this subroutine also triggers the same error about duplicate O-word label:
forum.linuxcnc.org/subroutine-library/27...gle3-for-mill-router
I have 2.8.2 version installed
- viesturs.lacis
04 Sep 2021 15:59 #219614
by viesturs.lacis
Forgot to mention, that I did find this thread:
forum.linuxcnc.org/20-g-code/27728-dupli...-version-2-6?start=0
But I get the error also when I call the subroutine more than once without editing. Restarting LinuxCNC between attempts also was tried without success.
05 Sep 2021 14:39 - 05 Sep 2021 14:55 #219672
by dgarrett
Replied by dgarrett on topic Strange subroutine error
I could not reproduce the errror, perhaps
you have inadvertently edited the source file:
and corrupted the original o<y1100> line
Last edit: 05 Sep 2021 14:55 by dgarrett.
- viesturs.lacis
05 Sep 2021 15:23 #219676
by viesturs.lacis
so are you saying that my subroutine works for you?
yes, bad editing of original file that I copied those lines from is completely possible situation as this is my first attempt at writing my own subroutines.
- viesturs.lacis
05 Sep 2021 15:28 #219677
by viesturs.lacis
Just in case the subroutine is lost in that mess of the original post, here is a link:
pastebin.com/VMGbyhKP
05 Sep 2021 17:16 #219683
by dgarrett
now i reproduced, pyngcgui bug fix committed to 2.8 branch (for next release),
(for now use without expanding)
Ref: github.com/LinuxCNC/linuxcnc/commit/2c24928af
Time to create page: 0.119 seconds
