New GUI for Emc available for testing...
07 Aug 2010 12:28 - 07 Aug 2010 12:30 #3622
by ynneb
Replied by ynneb on topic Re:New GUI for Emc available for testing...
Ok I have installed mocca and I have seen the screen you have made. I think I am making progress.
Now to make my own screen. Am I right in understanding that this is not a WYSIWYG editor, and we must edit the mocca.xml file, or am I missing something?
I did try and insert <string name ="image" value="mybackgrond.jpg"/> and I had the image in the same folder as the mocca.xml folder but I see no change.
I really want to understand all this, and will produce some "how to" videos for others once I understand.
Any help would be appreciated.
Benny
PS I know it must be frustrating holding hands with people like me, but once I can undestand I will endeavour to make it easier for others to also understand.
Benny
Last edit: 07 Aug 2010 12:30 by ynneb.
08 Aug 2010 05:49 - 08 Aug 2010 05:50 #3627
by ynneb
Last edit: 08 Aug 2010 05:50 by ynneb.
08 Aug 2010 06:30 #3628
by gtom
Replied by gtom on topic Re:New GUI for Emc available for testing...
Wich Version are you using ???
Have you installed a binary or the package or from source ?
the Name of the skins folder reflects the screen-Size it was designed for:
hh_1280x1024 is for a 1280 x 1024 Pixel Screen.
Your screen resolution is 1024 x786 ?
So try to use the default screen so you can see whole screen.
Next open in the default skin folder the file mocca.xml
<?xml version="1.0"?>
<CONFIG>
<Component>
<component name="MainForm" class="TMainForm">
<properties>
<integer name="Height" value="724"/>
<integer name="Width" value="961"/>
<ident name="Color" value="clSilver"/>
</properties>
<children>
<component name="BgImage" class="TImage">
<properties>
<integer name="Left" value="00"/>
<integer name="Height" value="600"/>
<integer name="Top" value="0"/>
<integer name="Width" value="800"/>
<string name="Picture" value="background.jpg"/>
</properties>
The property "Picture" will load the background- image "background.jpg"
With left,top,width & height you can move the picture on the mocca- screen...
regards, Thomas
<CONFIG>
<Component>
<properties>
</properties>
<children>
<properties>
</properties>
regards, Thomas
08 Aug 2010 09:47 - 08 Aug 2010 09:48 #3630
by ynneb
Last edit: 08 Aug 2010 09:48 by ynneb.
08 Aug 2010 12:31 #3632
by gtom
Please try to start mocca from the shell, mocca tells you a lot of stuff when starting,....,
Thomas
Thomas
09 Aug 2010 00:19 #3638
by ynneb
Thanks Tom, I dont know how to run from shell. Linux is not native to me.
I have started to work on a design www.linuxcnc.org/component/option,com_ku...7/lang,english/#3637
03 Dec 2012 18:54 #27138
Anyone know if this screen is copyrighted?
Replied by cmorley on topic Re:New GUI for Emc available for testing...
Here is a screen I did years ago. More than likely not many peoples taste, but it demonstrates having a single BMP/JPG and having transparent buttons and DROs over it. I have found this to be the easiest method for screen design.
I wouldlove to start making screen for EMC using Mocca.
I did install Mocca but now EMC just creashes each time.
04 Dec 2012 02:02 #27149
by tjamscad
I would say no since they are listed here www.machsupport.com/screens.php for download.
Replied by tjamscad on topic Re:New GUI for Emc available for testing...
04 Dec 2012 02:04 #27150
by tjamscad
you can follow it here www.machsupport.com/forum/index.php?topic=421.0
04 Dec 2012 03:14 #27151
by cncbasher
Replied by cncbasher on topic Re:New GUI for Emc available for testing...
Benny did that particular one ( YNNEB)
