Lathe Macros
- Masiwood123
- Thank you received: 74
16 Nov 2022 14:34 #256862
by Masiwood123
Replied by Masiwood123 on topic Lathe Macros
Andy you are a genius! this worked, somehow, but something is working...I will have to figure out what and how...I had to delete T from the routine (I have nothing entered in the tooltable except what is in your file), only then run the program, something changes the speed revs too..it will take me a while to figure out how it works but this is awesome. Thanks a lot!!
youtube.com/shorts/GSmLgSQ8f7w
16 Nov 2022 15:39 #256864
Replied by andypugh on topic Lathe Macros
It would be better to create a tool table rather than remove the T commands.
(It only needs to contain one tool)
- Masiwood123
16 Nov 2022 15:44 #256866
by Masiwood123
yes i can do it thanks a lot
- hitchhiker
- Thank you received: 9
17 Nov 2022 13:33 #256928
by hitchhiker
Replied by hitchhiker on topic Lathe Macros
hi!
is it possible to load the correct ngc automatic???
it works only for me when i load chamfer.ngc in axis and the hit the play/run button.
thanks
thanks
- Masiwood123
17 Nov 2022 15:58 #256936
by Masiwood123
I'll try to test everything at the weekend and I'll let you know if there's any progress, for now I've only managed to try turning, I need to understand the entered dimensions, which works, although there are explanations next to each entry, the numbers in the css parameters and in the speed parameters are a bit confusing to me.
- hitchhiker
17 Nov 2022 21:48 #256964
by hitchhiker
is it possible to add constant feedrate?
i think the lathe macros are one of the best modification in linuxcnc...
The following user(s) said Thank You: Masiwood123
- Masiwood123
17 Nov 2022 21:51 #256966
by Masiwood123
I agree completely, we have to wait for what the boss Andy has to say about it, and I would like it to be remade, but I don't know how
18 Nov 2022 00:11 #256994
It's possible but I think it's a bad idea.
Or am I misunderstanding?
You mean feed/min rather than feed/rev?is it possible to add constant feedrate?
- hitchhiker
19 Nov 2022 23:20 #257128
by hitchhiker
yes but my biggest question is... when i want to use a macro i must manual load the ngc file... is there a way to load the correct ngc file automatic?! thanks
22 Nov 2022 21:45 #257384
You shouldn't need to load the ngc file, that would be terribly inconvenient.
Where have you put the .ngc files? Are they included in your SUBROUTINE_PATH ?
Time to create page: 0.204 seconds
