Start Touchy maximised
31 Dec 2014 06:52 #54440
by justinj
Start Touchy maximised was created by justinj
I'm only new to this so apologies in advance if this is a stupid question.
I'm driving my CNC via a touch screen monitor so for a lot of my usage I'll be using Touchy. When I start Touchy it starts windowed and disappears off the right of the screen whilst not touching the bottom (Probably initially designed on a widescreen monitor, mine is a 1280x1024). If I maximise the display it looks and works as expected, however I can't get it to open automatically maximised. I thought it would remember it's position from last run which it doesn't, I've had a look at its .ini file but can't see anything related to window size, position or status. Where do I need to look?
31 Dec 2014 20:57 #54446
by ArcEye
Replied by ArcEye on topic Start Touchy maximised
Hi
The solutions for Axis should work for touchy, which I think still has a pygtk interface
Devilspie is probably the easiest one
www.linuxcnc.org/index.php/english/forum...of-axis-screen#24231
www.linuxcnc.org/index.php/english/forum/21-axis/320-faq
01 Jan 2015 07:36 #54458
by justinj
Unless someone else knows of a built in method to do it I'll use devilspie.
Thanks for the info ArcEye
Replied by justinj on topic Start Touchy maximised
So there's no built in function/setting to modify to do it automatically? I'd have thought there would have been a setting file somewhere else with all it's positioning and size settings.Hi
01 Jan 2015 23:58 #54466
by BigJohnT
Replied by BigJohnT on topic Start Touchy maximised
Odd, Touchy starts out maximized for me...
JT
JT
02 Jan 2015 08:17 #54475
by newbynobi
Replied by newbynobi on topic Start Touchy maximised
@justinj,
Have you taken a look to gmoccapy?
It does offer a settings page to configure different starting options.
Norbert
Norbert
02 Jan 2015 08:29 #54476
by justinj
Happy new year.
I haven't and I just searched it to see what it is and it looks quite nice! It looks like a nice blend of Axis and Touchy. I will definitely give it a shot too! Thanks for pointing it out, when I searched "LinuxCNC touch screen" the only thing that came up was Touchy in the results so I thought that was all I had. Nice to have variety and options@justinj,
Norbert
Happy new year.
Time to create page: 0.079 seconds
