Touch screen and conversational control options?
23 Nov 2017 19:51 #102271
by Ross77
Touch screen and conversational control options? was created by Ross77
Hi
Not sure if this is the right section but I'm looking for the best option for a touch screen UI with conversational input. pretty much like Path pilot but without all the setup issues. If there is such a thing?
Its for use on a lathe and I will be using Mesa 5i25 and 7i76 cards.
24 Nov 2017 00:08 #102280
Replied by cmorley on topic Touch screen and conversational control options?
Not having used pilotpath I don't exactly know what makes it so appealing.
Does adding the 'Nativecams' project to one of the stock screens get close?
forum.linuxcnc.org/40-subroutines-and-ng...med?start=480#102057
Also Andiy's lathe macros:
forum.linuxcnc.org/41-guis/26550-lathe-macros
If the stock option in linuxcnc don't fit the bill then one would need to build what one likes.
Gscreen is a screen building infrastructure (The sample screens in linuxcnc are just that samples)
but it takes quite an investment in time.
i am currently working on a qt base screen system that i hope to add some build in macros but thats i biit off yet.
Chris M
Chris M
29 Nov 2017 00:30 #102462
by Ross77
Replied by Ross77 on topic Touch screen and conversational control options?
Thanks Chris,
I have been reading up on Gscreen so will probably give that a try when my touch screen arrives. Im a little confused on how to install it, do I just change the ini file settings as per the wiki and then it works? Where can I find the lathe option?
Sorry for all the questions but new to linux and still getting grips with it. I'm using the latest wheezy 2.7.11 RPTI . is that the best one for a lathe with touch screen and mesa cards? thanks
Lastly will the lathe macros work in Gscreen?
06 Dec 2017 16:58 #102723
Maybe.
You might need to unhide the "run cycle" button, as I don't think that G-screen has the code that tells an embedded tab that it has the focus.
github.com/LinuxCNC/linuxcnc/commit/1bcd...b3ae236486cb45cd0e9e
With Touchy I use this to run the macros using the same "cycle start" button as is used by the Auto tab to start G-code or the MDI tab to run the MDI command.
Replied by andypugh on topic Touch screen and conversational control options?
Maybe.
06 Dec 2017 22:52 #102734
by Ross77
Ok I will give it a try. I've been playing around with Gmoccapy and quite like it so may stick that for a while until I get more familiar with customizing. Ive seen the lathe macros in that Gui so hoping its easy to install.
I tried the macros in axis and couldn't get them to work. displayed fine and changed the values but when I press go I get an error message.
07 Dec 2017 16:56 #102749
by newbynobi
Replied by newbynobi on topic Touch screen and conversational control options?
You may want to use gmoccapy, it is made for the use of touch screens and does support lathes and embedded tabs.
Norbert
Norbert
Time to create page: 0.127 seconds
