GScreen and some understanding gap of hal-widgets
20 Jun 2019 06:25 #137346
Replied by cmorley on topic GScreen and some understanding gap of hal-widgets
Nice consistent button theme!
20 Jun 2019 08:47 #137352
by Reinhard
Replied by Reinhard on topic GScreen and some understanding gap of hal-widgets
Thank you
I found this hint for replacing widgets, but it does not work for me.
I probabely did some mistake, but I'm unable to find it.
I use a togglebutton to replace the dro with a textfield and on retoggle replace the textfield with the dro.
Visual effect is: the dro disappears from screen and all other dros slide topwards. On retoggle the dro fills the original place and all looks like expected.
This is the code:Terminal output is as expected, so the textfield is created and operable
This is the code:
def on_sk03_toggled(self, button):
if (button.get_active()):
self.droX = self.w.dro_x_rel
container = self.droX.parent
# moved to __init__
# self.xTF = gtk.Entry()
self.xTF.set_text(self.droX.get_label())
props = {}
for pspec in gtk.container_class_list_child_properties(container):
props[pspec.name] = container.child_get_property(self.droX, pspec.name)
gtk.Container.remove(container, self.droX)
container.add(self.xTF)
for name, value in props.items():
container.child_set_property(self.xTF, name, value)
print('current x value: ')
print(self.droX.get_label())
else:
print('user entered: ')
print(self.xTF.get_text())
print('droXrel value: ')
container = self.xTF.parent
props = {}
props[pspec.name] = container.child_get_property(self.xTF, pspec.name)
gtk.Container.remove(container, self.xTF)
container.add(self.droX)
container.child_set_property(self.droX, name, value)
current x value:
0.000
user entered:
0.000
droXrel value:
0.000
20 Jun 2019 12:34 #137372
Just a guess, try changing code to:
Chris M
self.xTF.show()
Chris M
20 Jun 2019 15:42 #137394
by Reinhard
Thank you! That did the trick
didn't know, that each widget needs its own show() call.
Actually I have another problem. Homing does not work any more.
I added some print statements to hal_action to verify, that the action gets called and the print statements raised their output to terminal (function entry and mode was checked).
I can't see any other errors, so what could go wrong, that linuxcnc does not home?
I'm stil working with simulation ...
21 Jun 2019 04:03 #137447
If you built the widgets outside of GLADE then you must call show() or show_all()
gscreen calls show_all() after the GLADE widgets are loaded.
homing can fail you are not in the right mode - the details of which I can't remember at the moment. Did you add any code that might have changed the mode?
If you have an MDI widget and type STATUS in it, it will pop a window that displays linuxcnc status so you can we whats going on.
Chris M
Chris M
21 Jun 2019 04:24 #137450
by Reinhard
Hi Chris,
i changed hal_action (on_activate of EMC_Action_Home) like this:and Terminal says:
Therefore I'm confused
def on_activate(self, w):
#if not manual_ok(): return
if ensure_mode(self.stat, self.linuxcnc, linuxcnc.MODE_MANUAL):
print('Action-Home: mode is manual')
else:
print('Action-Home: mode is NOT manual')
21 Jun 2019 05:54 #137454
If you are willing to post your GLADE and handler files - I could look into it for you.
Chris M
Chris M
21 Jun 2019 06:12 #137456
by Reinhard
I enabled Debug output and examined the output.
I did not find the reason, why homing won't work, but found some strange looking things. Don't know, which of them might be important ...
I wanted to put the logs in a code-box, but that box has no line-numbers ...
... so I attach the log
linuxcnc has no path (line 3, 6 and 8)
linuxcnc looses version information (line 17 and 28 / 35)
emcTrajSetAccel looks very strange (line 47 and 48)
line 216 home button was pressed
... and line 288 is the print output from Home-Action (hal_action)
What a great offer! Thank you very much!- I could look into it for you
22 Jun 2019 01:29 #137536
You said you were using a sim config but sent a pncconf config. The pncconf config has no homing sequence info so using home-all (in your GLADE file) won't do anything.
Using your GLADE and handler file with Gscreen's tester sim config, the machine homes xy and z
Chris M
Chris M
22 Jun 2019 08:25 #137568
by Reinhard
Hi Chris,
thank you for that info. That helped my find the missing config lines.
I beg your pardon - there's so much, I don't know.
I wanted to finish screen work before I start with hw-dedication ...
I created configurations for both machine types I'm interested in (Gantry XYYZA and vertical mill with XYZWA).
pncconf does not support any of them, so I created a xyyza and changed the rest manually.
adding core_sim9.hal I thought, I have support for 9 axis.
But when I start gui and press home, the z-axis homes and than I get the error... and I have no idea, what that means.
When I start gui with my pncconf-created config I get the error:
So what's the best way to get a simulation setup for the configurations I want to test?
11 motion stop at referencestatus 7
hm2_pci: rtapi_app_main: No such device (-19)
Time to create page: 0.103 seconds
