Java UI for linuxcnc
28 Sep 2019 18:49 #146499 by Reinhard
I'm pretty happy with the result of some weekend-codings ;)
The UI already works as a slave of axis, as well as standalone started from the linuxcnc config selector.
I found the tool definitions in status structure and the position dro change display according to the joint definitions.
What I did not find yet - how are the values from var-file synchronized between linuxcnc-tasks?
The point is, I want to add a page, where the offsets can be edited.
From what I found, the offsets are in the var-file. The status structure contains only the active fixtures - right?
So when I change non active fixtures or coordinate systems, how are they synched?
Do I write the var file from the UI or what is the right way to handle value changes?
I realized that the tool file is read from the linuxcnc-background-process and put into the status structure.
I did not find similar behaviour for the fixtures.
29 Sep 2019 13:55 #146565 by pl7i92
Replied by pl7i92 on topic Java UI for linuxcnc
that is cool so we got anothere Language then the QT
pyqt .....
python ...
so now there will be muliiple patforms to operate on
even android app posible on java to a RT kernal PC like Raspberry
03 Oct 2019 00:42 #146922 by andypugh
Replied by andypugh on topic Java UI for linuxcnc
Most of the important data in LinuxCNC is passed about through the NML interface. Getting to that with Java might be something of a puzzle.
My understanding of the var file (and it isn't a very deep understanding) is that the file is only the persistent store to retain values through restarts.
03 Oct 2019 03:34 #146942 by Reinhard
Replied by Reinhard on topic Java UI for linuxcnc
Hi Andy,
thank you for your attention and support!
Oh yes - its really a puzzle. Guess i spent more time in searching, than in coding :dry:
But after all - the java UI uses NML interface only.
Don't know, whether I got it right - currently the status messages are the only way to retrieve values from hal.
NML-commands works to do anything.
The problem are the plenty informations, that are not part of status messages or fields, that are not updated in status messages ...
I could follow that idiom and read the var-file at startup and than send changes by NML-commands.
I guess, I did not find all ways of information gathering yet.
I.e. qtdragon shows changing feed values during simulated homing - and when I read the status fields, I get always zero as feed value.
I would appreciate it a lot, if someone could shine me a light on how to access uptodate motion values.
08 Mar 2020 13:32 #159468 by tjtr33
Replied by tjtr33 on topic Java UI for linuxcnc
Hello
Sorry I am late to this thread,
but a very long time ago,
Matt Shaver wrote a java based interface to (then ) emc.
The source may be of use, but is not in current distributions.
It may exist back in the ancient Paul Corner BDI installs.
I was looking for that source,
it in the hope that it could be used without X,
by using the linux framebuffer directly.
This would be useful IF it removed some load from the CPU
and placed that load on the GPU of the Raspberry Pi.
So it is very much a niche benefit.
Some work has been done on using the framebuffer for linuxcnc
( the Xmotion gui ) but I just cant get that code to run ( builds fine ).
Best of luck, I will watch this thread more closely now.
Thx TomP
08 Mar 2020 14:59 #159473 by Reinhard
You're welcome :)
The source may be of use, ...
I'm almoust done with my intentions.
I wrote a small native lib to access shared memory and UI works fine so far.
I have more troubles with informations I want to show, but which don't come out of linuxcnc at time or at all. That's the hard part, I did not solve yet.
Well, I omitted gremlin so far.
It's a nice gimmic, but I don't have the expertise to code GL or GLX ...
After all - no professional controller I know about has somewhat like gremlin - I can live without it.
Other UI elements where more important for me, as well as extended tooltable support ...
Currently the UI works in portrait and landscape mode, whereas portrait is my preferred orientation.
But the final test can not start until my hardware is ready and running - and I always have to wait for new items to arrive ...
28 Apr 2020 07:24 #165918 by Reinhard
finally I was able to publish the project at github as JCNCSCreen .
Also available: basic docs .
If someone likes to try, I would be happy about feedback :)
cheers Reinhard
28 Apr 2020 09:11 #165935 by Mike_Eitel
Replied by Mike_Eitel on topic Java UI for linuxcnc
Hi Reinhard
To be honest, i will use it, BUT i think this is a goog job.
Looks to be efficent when u only want a minimalistic screen.
Probably better suited for low power units..
Congratulations Mike
29 Apr 2020 05:09 #166056 by Reinhard
Hi Mike,
thank you for your interest.
I thought about that "minimalistic" - didn't think, that it goes into that drawer ...
On my last job, I travelled with the spindle in a cabin and I missed a moveable terminal a lot.
Now I'm working on a smaller mill with closed housing and stil without moveable terminal.
But this time, terminal contains a wheel and all known stuff from moveable terminals. So I don't miss it at all.
Current terminal looks like (pretty outdated, but so am I ;) ):
... and I'm going to build my terminal following that logic.
Of cause, I want all wheels and buttons be there as hardware controls.
Therefor the buttons in my app are used in the sense of a LED, not as usable buttons.
I hope to be able to manage control without the use of a mouse.
That might look weird in simulation mode, but I hope, its ok in real world.
So the ui-controll needs halui and my app is "just" a visualizer :)
I you miss anything, let me know.
cheers Reinhard
29 Apr 2020 07:03 #166058 by bbsr_5a
Replied by bbsr_5a on topic Java UI for linuxcnc
on thatt machine why dont you go for a XHC_hb06 handheld it holds all you need for movable terminal
and it is supported
Time to create page: 0.290 seconds
