Java UI for linuxcnc
10 Aug 2021 13:48 #217398 by Reinhard
Replied by Reinhard on topic Java UI for linuxcnc
What Debian version do you have installed?
my app has no os dependencies at all. As soon as you have a working copy of linuxcnc, my app will be working. You only need a jre - nothing more.
I compiled the java stuff with v8 compatibility, so any jre available in decent os will do the job.
My app worked on jessie, buster and it works on bullseye as well. It worked with linuxcnc before 2.8 was released and it works with current master-gtk3 (python3).
I hope you have not felt offended by the fact that I said that I wanna take your project into another direction by using kotlin.
Why should I?
That's the nature of open source. You can do what you want, as long as you mention me as original author.
But - I won't accept any push request regarding kotlin, gradle, maven or whatever tools that will bloat my harddisk. I did not use gradle by intention and don't wonna use it at all.
I'm fine with the stuff I created and the tools I used.
If you like my work, you can use it - if you don't like it, you don't have to use it.
Its a free world :)
I would have appreciated a little feedback about whether you got your copy working - after all that struggling. But you're free not to give any feedback at all.
10 Aug 2021 14:21 #217399 by vmihalca
Replied by vmihalca on topic Java UI for linuxcnc
I did not managed to make the app work for me yet. Was quite busy the last weeks trying to revive my new lathe.
The PR that you saw with kotlin is made by a friend of mine who tried on his machine to see if he can manage to make it work on his arch linux, he told me later he made a pull request.
I haven't wrote a line of code yet about this project. I wanted to get the original app working first.
I had two linux machines, one of them is ubuntu but its the laptop I have from work, and I did not managed yet to setup a debian on that one yet.
The other one was a minipc, which had debian 10 installed. On that machine, I've ended up a bit further than with the one running ubuntu. I've managed to install all the dependencies, and got the correct libraries listed in the ldd command.
However there was something still not working, but I will come back to this later next week once I manage to create a partition and install debian on the work laptop.
I have a question: from your app can you open the already existent utility apps like halscope, hal configuration, etc that the Axis or Gmoccapy are opening for setting up the linuxcnc machine configuration?
There was always annoying to me how hal configration is implemented and I was wondering if the api's used to create that application would be available to be consumed from java.
Thanks,
Vasi
10 Aug 2021 15:28 #217406 by Reinhard
Hi Vasi,
well, first of all try to get your linuxcnc working.
When you compiled a rip-installation successfully, the rest should be a bit of nothing ;)
No, all halapps run natively from linux commandline. I don't see any need or benefit in calling those apps from java environment. I did some tests with accessing hal from java - it was possible, but I abandoned that idea, as I have no need for direct hal access.
Just to clarify: hal means hardware abstraction layer - I have no plans to directly access any hardware. linuxcnc does it good enuf. Anything is possible. Shortcomings of linuxcnc are NOT hardware related. All the bad is in software :(
cheers Reinhard
10 Aug 2021 20:52 #217423 by vmihalca
In my custom qtpyvcp GUI, I have created custom hal pins specific to my app, I made logic in the app that was acting based on the values of those pins and that was very helpful.
How difficult would it be to obtain the same functionality in java?
On my machine I have a touch probe and a tool sensor, and I wanna signal in the software if the sensor is plugged in or not. That's just one usecase.
16 Aug 2021 10:01 #217869 by vmihalca
Hi Reinhard,
I have set up a fresh debian 10 on my minipc. I have pulled out the branch master-gtk3 and successfully ran the following commands.
[code]> git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
> cd linuxcnc-dev/src
> ./autogen.sh
> ./configure --with-realtime=uspace
> make
[/code]
Then I ran
[code]sudo make setuid
[/code] and just to make sure, I ran the linuxcnc tests witch ran fine.
Then I've pulled your code, did all the steps, and reach the following point:
cnc@mindovercnc:~/Work/JCNCScreen/native$ make TestNML
make: 'TestNML' is up to date.
cnc@mindovercnc:~/Work/JCNCScreen/native$ ldd TestNML
    linux-vdso.so.1 (0x00007ffcf17a5000)
    libnml.so.0 => /home/cnc/Work/JCNCScreen/native/lc/lib/libnml.so.0 (0x00007fe46c780000)
    libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007fe46c6d1000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe46c54d000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe46c3ca000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe46c3b0000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe46c1ef000)
    liblinuxcnchal.so.0 => /home/cnc/Work/linuxcnc-dev/lib/liblinuxcnchal.so.0 (0x00007fe46c1de000)
    libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007fe46c1aa000)
    libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007fe46c0ed000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fe46c0e8000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fe46c0c7000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fe46c7e6000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fe46c0bb000)
    libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007fe46bf7a000)
    libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007fe46bd68000)
    libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fe46bd3e000)
    libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007fe46bb3a000)
    libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fe46b932000)
    libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007fe46b918000)
Then I navigated into the runtime folder and tried to run the app:
cnc@mindovercnc:~/Work/JCNCScreen$ cd runtime/
cnc@mindovercnc:~/Work/JCNCScreen/runtime$ java -Djava.library.path=.:./lc/lib -splash:lc/linuxcnc.gif -jar JCNCScreen.jar -base ./exHdr
local check: AppTitle == > JCNCScreen - frontend for linuxCNC <
current directory: /home/cnc/Work/JCNCScreen/runtime/.
populateTree ...
read ToolTable ...
Exception in thread "main" java.lang.UnsatisfiedLinkError: no nml in java.library.path: [., ./lc/lib]
    at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2670)
    at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:830)
    at java.base/java.lang.System.loadLibrary(System.java:1873)
    at de.schwarzrot.system.ErrorReader.<clinit>(Unknown Source)
    at de.schwarzrot.app.LinuxCNCClient.<init>(Unknown Source)
    at de.schwarzrot.app.LinuxCNCClient.main(Unknown Source)
Any idea what I am still missing?
Thanks,
Vasi
16 Aug 2021 14:10 #217886 by Reinhard
Congratulation!
Finally you got it :)
make TestNML
Oh man!
you had a binary from a former installation.
This can't work.
So if you (re)compile linuxcnc, you should run a "make clean" first of all.
Then - if you issue a "make TestNML" only the test-app will be build.
That means, you can't start the java app without having built the library (just "make").
TestNML is an app to test the NML communication. So it serves to check your build environment, as well as to check NML-connection.
So start linuxcnc with axis (without any UI-action in axis) and then start TestNML.
Axis should turn on and home all axis.
If that works, you can continue with the library.
Cheers Reinhard
16 Aug 2021 19:55 #217913 by vmihalca
That message with
was because I previously ran make TestNML
This installation was a clean debian, without any version of linuxcnc installed. So the only install that I have is the one built from master-gtk3 branch.
After reading your last message I was more enlightened a bit so I did the following:
1. in JCNCScreen folder -> ant clean, then ant dist
2. in another terminal window, opened linuxcnc, with a default configuration (axis UI window estopped)
3. switched to native folder then ran ./TestNML which took the Axis UI out of estop, powered on the machine, then homed the machine.
4. Then I navigated into the runtime folder and tried to run the app:cnc@mindovercnc:~/Work/JCNCScreen$ cd runtime/
populateTree ...
read ToolTable ...
Its kinda wierd that TestNML can interact with linuxcnc properly, but this one cannot.
If you notice something that I might be missing, please let me know!
Thanks for your help!
16 Aug 2021 23:34 #217926 by phillc54
Replied by phillc54 on topic Java UI for linuxcnc
A little off topic but you probably should run master branch rather than master-gtk3 as master-gtk3 has been merged into master plus a couple of fixes have been committed as well.
The following user(s) said Thank You: Reinhard
17 Aug 2021 02:14 #217942 by Reinhard
@phillc54
Thank you very much for that info :)
That's a different error from the ones before and it tells, that libnml.so is not found in library path.
You can check it with "ls -l ./lc/lib/libnml.so"
May be you forgot to create the link lc to linuxcnc installation?
17 Aug 2021 07:13 #217959 by vmihalca
Hi Reinhard,
This is the result of the command you told me to run:
cnc@mindovercnc:~/Work/JCNCScreen/native$ ls -l
total 2196
-rw-r--r-- 1 cnc cnc  13994 Aug 16 12:13 de_schwarzrot_system_CommandWriter.cc
-rw-r--r-- 1 cnc cnc  18494 Aug 16 13:13 de_schwarzrot_system_CommandWriter.d
-rw-r--r-- 1 cnc cnc   4546 Aug 16 12:13 de_schwarzrot_system_CommandWriter.h
-rw-r--r-- 1 cnc cnc 223984 Aug 16 13:13 de_schwarzrot_system_CommandWriter.o
-rw-r--r-- 1 cnc cnc   5931 Aug 16 12:13 de_schwarzrot_system_ErrorReader.cc
-rw-r--r-- 1 cnc cnc  18841 Aug 16 13:13 de_schwarzrot_system_ErrorReader.d
-rw-r--r-- 1 cnc cnc    720 Aug 16 12:13 de_schwarzrot_system_ErrorReader.h
-rw-r--r-- 1 cnc cnc 184920 Aug 16 13:13 de_schwarzrot_system_ErrorReader.o
-rw-r--r-- 1 cnc cnc   3241 Aug 16 12:13 de_schwarzrot_system_StatusReader.cc
-rw-r--r-- 1 cnc cnc  18337 Aug 16 13:13 de_schwarzrot_system_StatusReader.d
-rw-r--r-- 1 cnc cnc    935 Aug 16 12:13 de_schwarzrot_system_StatusReader.h
-rw-r--r-- 1 cnc cnc 183368 Aug 16 13:13 de_schwarzrot_system_StatusReader.o
-rwxr-xr-x 1 cnc cnc  81408 Aug 16 13:13 DumpBufDesc
-rw-r--r-- 1 cnc cnc   7271 Aug 16 12:13 dumpBufDesc.cc
-rw-r--r-- 1 cnc cnc  17933 Aug 16 13:13 dumpBufDesc.d
-rw-r--r-- 1 cnc cnc 107616 Aug 16 13:13 dumpBufDesc.o
-rw-r--r-- 1 cnc cnc  12514 Aug 16 12:13 emcDecode.cc
lrwxrwxrwx 1 cnc cnc     28 Aug 16 12:21 lc -> /home/cnc/Work/linuxcnc-dev/
-rw-r--r-- 1 cnc cnc  20262 Aug 16 13:13 libLinuxCNC.map
-rwxr-xr-x 1 cnc cnc 732480 Aug 16 13:13 libLinuxCNC.so
-rw-r--r-- 1 cnc cnc   2000 Aug 16 12:13 Makefile
-rwxr-xr-x 1 cnc cnc    398 Aug 16 12:13 rebuild_header
-rwxr-xr-x 1 cnc cnc 535872 Aug 16 12:33 TestNML
-rw-r--r-- 1 cnc cnc   6111 Aug 16 12:13 TestNML.cc
cnc@mindovercnc:~/Work/JCNCScreen/native$ ls -l ./lc/lib/
total 27788
drwxr-xr-x  2 cnc cnc     4096 Aug 16 11:38 hallib
lrwxrwxrwx  1 cnc cnc       15 Aug 16 17:53 libcanterp.so -> libcanterp.so.0
-rwxr-xr-x  1 cnc cnc   106888 Aug 16 17:53 libcanterp.so.0
-rw-r--r--  1 cnc cnc  4693856 Aug 16 17:52 liblinuxcnc.a
lrwxrwxrwx  1 cnc cnc       19 Aug 16 17:51 liblinuxcnchal.so -> liblinuxcnchal.so.0
-rwxr-xr-x  1 cnc cnc   233664 Aug 16 17:51 liblinuxcnchal.so.0
lrwxrwxrwx  1 cnc cnc       19 Aug 16 17:51 liblinuxcncini.so -> liblinuxcncini.so.0
-rwxr-xr-x  1 cnc cnc   282424 Aug 16 17:51 liblinuxcncini.so.0
lrwxrwxrwx  1 cnc cnc       11 Aug 16 17:51 libnml.so -> libnml.so.0
-rwxr-xr-x  1 cnc cnc  1323824 Aug 16 17:51 libnml.so.0
lrwxrwxrwx  1 cnc cnc       16 Aug 16 17:51 libposemath.so -> libposemath.so.0
-rwxr-xr-x  1 cnc cnc   370424 Aug 16 17:51 libposemath.so.0
lrwxrwxrwx  1 cnc cnc       16 Aug 16 17:53 libpyplugin.so -> libpyplugin.so.0
-rwxr-xr-x  1 cnc cnc   747976 Aug 16 17:53 libpyplugin.so.0
lrwxrwxrwx  1 cnc cnc       13 Aug 16 17:53 librs274.so -> librs274.so.0
-rwxr-xr-x  1 cnc cnc 20470912 Aug 16 17:53 librs274.so.0
lrwxrwxrwx  1 cnc cnc       16 Aug 16 17:53 libtooldata.so -> libtooldata.so.0
-rwxr-xr-x  1 cnc cnc   196712 Aug 16 17:52 libtooldata.so.0
drwxr-xr-x 12 cnc cnc     4096 Aug 16 17:54 python
cnc@mindovercnc:~/Work/JCNCScreen/native$ ls -l ./lc/lib/libnml.so
lrwxrwxrwx 1 cnc cnc 11 Aug 16 17:51 ./lc/lib/libnml.so -> libnml.so.0
Time to create page: 0.161 seconds
