qtdragon_hd - File not open error
20 May 2023 19:29 #271771
by JohnnyCNC
qtdragon_hd - File not open error was created by JohnnyCNC
Currently I am running QTDragon on 2.8.4 and I want to move to give HD a try.
On a new SSD I just installed Debian 12, LCNC 2.9. I and giving QTDragon_HD. I have the machine (XYZ Mill) moving and homing. I am getting a "file not open" error when pressing the E-Stop button or the "Machine On" button (to turn it off) on the screen. The buttons seem to work except for the error message coming up. And Idea what I might be missing?
20 May 2023 19:33 #271772
Replied by cmorley on topic qtdragon_hd - File not open error
Think in the settings page you'll have 'auto reload program' enabled.
Since you have not ever loaded a program it's probably causing the error.
try unchecking it. Let me know if that changes things,
20 May 2023 23:12 #271782
by JohnnyCNC
Replied by JohnnyCNC on topic qtdragon_hd - File not open error
It was already unchecked. I tried checking it. Tried again, Unchecked it and tried again. No difference either way. I haven't yet loaded a file.
20 May 2023 23:47 - 20 May 2023 23:47 #271783
if you can add -d to the INI line
DISPLAY = qtvcp -d qtdragon_hd
then run from a terminal and post the output that might help me.
Chris
Chris
Last edit: 20 May 2023 23:47 by cmorley.
21 May 2023 00:10 #271784
by JohnnyCNC
21 May 2023 00:25 #271785
It seems the version you have is a little out of date.
I'm sure the problem is the missing paths in the preference file.
from the print out;
[QTvcp.QTVCP.WIDGETS.FILE_MANAGER][DEBUG] lAST FILE PATH: (file_manager.py:205)
This line is now 215 on the current version - I think I fixed this bug already.
Is it impeding you? You could edit the preference file, but I think just loading a file will fix it too.
from the print out;
21 May 2023 01:35 #271789
by JohnnyCNC
Chris,
At this time I'm just starting to migrate to Bookworm and 2.9 with QTDragon_HD. I'm in no hurry at all. The next thing I need to work on is getting my touch screen to work. In just the OS I can tap on say the teminal screen in the task bar and it open. I can put the arrow cursor anywhere on the screen with my finger. If I tap the LinuxCNC shortcut on the screen it selects it meaning it dims the icon but that's it. This all worked with Ubuntu Mint 19 and 2.8.4.
Thank you for your help. I really love the QTDragon screen.
21 May 2023 02:51 #271792
I'm glad you like it.
Persei802 (Jim) made the screen - I just integrate/tweak it for the linuxcnc project.
I'm am so happy Jim donated the screen.
21 May 2023 03:55 #271793
Replied by rodw on topic qtdragon_hd - File not open error
I for one am so happy you are integrating and tweaking it for the Linuxcnc project!I just integrate/tweak it for the linuxcnc project.
21 May 2023 13:03 #271815
by JohnnyCNC
I tried loading a file but that didn't change anything. Perhaps I should switch to master so I am not asking about things that are already fixed. You have enough work to do and don't need to be doing it twice.
What would be the best way to get the latest version of QTDragon_HD?
Time to create page: 0.199 seconds
