Neue Hardware und schlechter Latency Test
- Thank you received: 5942
05 Aug 2023 13:51 #277005
Replied by tommylight on topic Neue Hardware und schlechter Latency Test
3: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
Means nothing is connected to it, but the configuration is OK.
No carrier so the interface is down.
The following user(s) said Thank You: WKS-3D
05 Aug 2023 14:22 #277007
by WKS-3D
Replied by WKS-3D on topic Neue Hardware und schlechter Latency Test
Yes, that's correct. The mesa card is not connected
05 Aug 2023 20:56 #277054
Replied by rodw on topic Neue Hardware und schlechter Latency Test
Great! so next step, typeAnd share the results. This will report the ethernet driver in use to confirm its an Intel device.
also connect the mesa card and type
ping 10.10.10.10
If you get a reply you should be good to go.
sudo apt install ethtool
ethtool -i enps04
ping 10.10.10.10
06 Aug 2023 09:22 #277100
by WKS-3D
I had already posted thgis on page 4, but ok, here again
sudo apt install ethtool ethtool -i enps04And share the results. This will report the ethernet driver in use to confirm its an Intel device. also connect the mesa card and type ping 10.10.10.10 If you get a reply you should be good to go.
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.691 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.306 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.354 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.287 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.364 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.214 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.357 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.351 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.361 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.359 ms
64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=0.360 ms
64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.360 ms
64 bytes from 10.10.10.10: icmp_seq=13 ttl=64 time=0.359 ms
64 bytes from 10.10.10.10: icmp_seq=14 ttl=64 time=0.299 ms
64 bytes from 10.10.10.10: icmp_seq=15 ttl=64 time=0.359 ms
64 bytes from 10.10.10.10: icmp_seq=16 ttl=64 time=0.364 ms
64 bytes from 10.10.10.10: icmp_seq=17 ttl=64 time=0.358 ms
64 bytes from 10.10.10.10: icmp_seq=18 ttl=64 time=0.338 ms
64 bytes from 10.10.10.10: icmp_seq=19 ttl=64 time=0.363 ms
64 bytes from 10.10.10.10: icmp_seq=20 ttl=64 time=0.387 ms
^C
--- 10.10.10.10 ping statistics ---
20 packets transmitted, 20 received, 0% packet loss, time 19525ms
rtt min/avg/max/mdev = 0.214/0.359/0.691/0.084 ms
driver: e1000e
version: 6.1.0-10-rt-amd64
firmware-version: 1.8-0
expansion-rom-version:
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
06 Aug 2023 12:37 #277105
Perfect. It's hard to understand your config from a distance so thanks for going along with me.
Time to create page: 0.139 seconds
