Envoie d'un email lorsque l'usinage est terminé
31 Jul 2019 09:56 #140991
by julien83
Envoie d'un email lorsque l'usinage est terminé was created by julien83
Bonjour, j'aimerais envoyer un email lorsque l'usinage est terminé.
avez-vous une méthode pour cela.
Merci
Merci
- Dinuka_Shehan
- Thank you received: 26
31 Jul 2019 10:12 #140992
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Envoie d'un email lorsque l'usinage est terminé
Hello, I would like to send an email when the machining is finished.
do you have a method for that.
Thank you
Thank you
31 Jul 2019 22:04 #141052
Replied by andypugh on topic Envoie d'un email lorsque l'usinage est terminé
I think that this should be fairly easy, though I have not seen it done.
Some discussion (with no answer) forum.linuxcnc.org/38-general-linuxcnc-q...ool-change-etc#84147
If you can add an M-code to the end of the G-code file then is seems fairly easy in theory.
If it needs to work for any G-code file without modification then this seems like a job for either a HAL component that monitors program.is-running or possibly a remap.
Moderators: darty367
Time to create page: 0.116 seconds
